Entropy: Human vs Rock, Heavy Elements & Solids
  • Thread starter bbos
  • Tags
    Entropy
In summary, the concept of entropy is the tendency for a system to move towards disorder and randomness. A human body, with its enormous structural complexity, has greater entropy than a rock which can be structured in a completely random fashion. Heavy elements in the periodic table also have more structural complexity and order due to an increase in protons, neutrons, and electrons, leading to a decrease in entropy. Liquids have more entropy than solids due to the lack of strict stable bonding, allowing for more random movement of atoms. However, entropy is a human invention and the reality is that there are many possible states for a system, with only a few being considered complex or ordered.
bbos
Hi guys, I'm having a discussion with a friend in regards to entropy. I approach the concept of entropy in relation as the tendency for a system to tilt towards the disorder and randomness. with that said,
I state that a human(biological system) possesses less entropy then a rock due to enormous structural complexity and order required to operate, where as a rock can be structured in all random fashion.
I also say that heavy elements within the periodic table becomes more complex and structurally more ordered due to increase in proton, nuetron and electrons, thus more structural complexity equates to decrease in entropy.
Lastly any solid will have less entropy then liquid due to strict stable bonding thus reducing random probability of atoms moving about in the system
can someone confirm these for me thanks
Science news on Phys.org
You're partly right. The number of microstates available to the human body far exceeds those available to a simple piece of rock, hence the human body has greater entropy. For that same reason, liquids have greater entropy than solids, which is what you concluded for different reasons.
Entropy is merely a human invention. The reality is closer to this:
There are many states things can be in, and usually we only want a few. We call these 'complex' or 'ordered', because something about them lines up in the right way to do something for us. The trouble is, there are a lot more states that are not like this out there. We call those the same, and since things change, we see it as more likely to change towards randomness, because to us 111111111 is special, but 1010111011 is not, and to us it is 'the same' as 101010110101.
It's certainly true that liquids have more entropy than their corresponding solids. The http://en.wikipedia.org/wiki/Entropy_of_fusion" is a well-known concept in chemistry.
Similar to what Galap said, I say that entropy isn't directly the tendency for disorder, but rather the statement that we if don't know where something is we assume it to be in the state that has most realizations. In some circumstances this will be the most disordered state.
I will take your human/rock example (we take a rock with the same number of atoms as the human).
The important point is that in the rock there are a lot of possible way to swap atoms while leaving the object still be a rock. So if a bunch of loose atoms randomly come together to form a rock they don't have to take care of their exact position and so they have a huge number of options to assemble themselves into a rock.
However, in the human body you better not swap the liver with the heart. And you better not swap atoms at random too often. So for the same number of (different) atoms to assemble a human body there are far less possibilities to join correctly so that we would still call the result a human body.
Galap's example is similar. If we call one state "100% 1's" and another "50% 1's" then the first has only one realization and the second has a lot.
Liquids have more entropy since the atoms don't have to care about the position. In a solid however there are some additional rules restricting the atoms when forming a valid solid. The atoms have to be at crystal positions.
So to sum up, states with highest entropy have the highest number of allowed realizations. Actually all this (the second law of thermodynamics) assumes that the time evolution of the system is completely homogeneous in space and time which isn't always true! Just as in chaos theory, a real system might have attractors and thus tend towards a state of lower entropy. That is how life developed.
Basically, the more constraints you pose on the positions of the constituents of the objects, the smaller the entropy.
A better comparison would be a human body vs. an equal quantity of water, proteins, calcium phosphate (bone), etc. You're discussing configurational entropy only, so you want to match the composition. Otherwise, human tissue will always have a higher entropy than rock simply because water has a higher molar entropy than a solid mineral.
I say 11111 is special not to us, but to this universe, order and structural complexity has to correspond to a set of laws in this universe in order for it to be considered so, that set of laws is not created by us, but rather discovered nature of the world. thus absolute order and structural complexity exist outside of human intellect, otherwise life wouldn't exist.
Related to Entropy: Human vs Rock, Heavy Elements & Solids
1. What is entropy?
Entropy is a measure of the disorder or randomness within a system. In thermodynamics, it is often described as the amount of energy that is unavailable to do work in a system.
2. How does entropy differ between humans and rocks?
Entropy tends to be higher in human systems compared to rocks, as humans are more complex and have a higher degree of disorder. Rocks, on the other hand, have a lower entropy as they are simpler and have a more ordered structure.
3. How do heavy elements affect entropy?
Heavy elements, such as uranium or plutonium, have a higher degree of entropy due to their complexity. They tend to be more unstable and have a higher chance of undergoing radioactive decay, which increases their entropy.
4. Can entropy be reversed?
In most cases, entropy tends to increase over time as systems become more disordered. However, in some cases, entropy can be reversed through energy input or external forces. For example, a plant can decrease entropy by converting sunlight into chemical energy through photosynthesis.
5. How does entropy relate to solids?
Solids can have both low and high entropy, depending on their structure. For example, a crystalline solid has a more ordered structure and therefore has a lower entropy compared to an amorphous solid, which has a more random structure and higher entropy. Additionally, the entropy of a solid can increase with temperature as the molecules have more energy and are more likely to have disorderly movement.
9K
  • Thermodynamics
12K
  • Thermodynamics
  • General Discussion
