Can piezoelectric concept be used to generate electricity on a large scale
In summary, the conversation discusses the concept of generating electricity through piezoelectric materials and how it can be used in different applications. There is a debate on the efficiency of piezoelectric power generation compared to traditional methods such as coils and magnets. The possibility of using piezoelectric materials in large-scale operations is also mentioned. Additionally, there are discussions on the physics behind electricity generation and the role of electrons in the process. Suggestions for further reading on the topic are also provided.
Wannabegood
I was going through few books and i found out that piezoelectric concept generates good amount of current but not enough power(wattage) ... As I was thinking of making a project on this concept can somebody tell me how can huge amount of voltage as well as current be generated from piezoelectric cells?
I have read in one of the threads somebody claimed that constant pressure cannot be used to generate energy!( Can somebody tell me whether its true?)
Hello WBG,
Kinda backwards on the current voltage thing. Generally, piezo devices move little in the way of charge, but they can develop some fairly high voltages if unloaded (hence peizo lighters in grills & such)
Piezo devices have been used for transformers in special applications (high isolation an laptop back lighting), but for the most part, magnetic transformers have proven more practical.
As for energy due to constant force, trying to lift a box that never raises from the floor doesn't impart energy to the box. It actually has to move upwards. And then again, if the box weighs next to nothing, moving it up a bit doesn't represent much energy. It's the weight and the distance upwards that represents work done to raise the energy imparted to the box.
Constant force on your piezo device will impart energy at the instant the force is applied and the device flexes a bit. Continuing to apply force doesn't impart any more energy. Circuits that use piezo transformers must operate at high frequencies, because each flex imparts very little energy.
A million monkeys and a million old cigarette lighters, perhaps?
Click, click, click
what concept did you have in mind??
what if the piezo material is a ceramic ring in which a rotor type motor is played into effect? the only moving part would be what puts pressure on the ring in the form of rpm (sphere)
Power generation is based on the work done in moving something (force times distance) and you need to 'match' your moving source of energy to the generator. To generate piezoelectric power would involve a really really massive force moving through a very small distance.
The only example of this that I could envisage would be using the movement of the Earth's crust during earthquakes. So you'd need a couple of huge blocks of stone (100s of m square, one in the ground and the other one on top of it. In between would be a large crystal of some piezoelectric material. When an Earthquake happened nearby, the rocks would move relative to each other and you would get a few milliseconds of high power out as the rocks moved relative to each other.
Perhaps a very long bar of piezo material could be moved (twisted or bent). You are always up against the problem of the high mechanical modulus of such materials which aren't matched to real world sources of mechanical work / energy.
One of my classmates made a piezoelectric device that turns sound into electricity. It was his senior design project. He put the crystals in a tube that was a resonant chamber for a certain frequency. He barely got any juice out of it but it was a cool experiment.
Anyway, the way piezos work is that when you bend them, the tend to squeeze charges out of one side. If you bend them back and forth. They can generate a little signal. They won't do anything if you just bend them and leave 'em.
Piezo has two problems - matching the mechanical power in and the electrical power out. It seems that you just can't beat coils and rotating magnets!:smile:
i don't like the term work in physics. its all labor. that being said, the process of using the blocks and a peizo bar is a phase labor and would never work (no idle power) . also piezo crystal are not the way to go , its ceramic. i do however like the novel concept in the sense that out of destruction comes power.
it terms of large-scale operation. it could work, but only with hyrdo-electric operations.
@sophiecentaur : agreed / but there is a way to match this ratio with flying colors by using what i like to call a sphere rotor and ceramic based piezo-ring
"i don't like the term work in physics."
I suspect you just like 'playing'!
"no idle power"
Not sure I understand what you mean but if you can produce charge displacement and a PD, what else do you need?
"sphere rotor and ceramic based piezo-ring" Wouldn't you still have the problem of 'source impedance' and matching, even if you can 'wobble' something wildly?
Peizoelectric material are like electrical sponges. By squeezing the atoms, you displace electrons.But you have to let go for the electrons to 'return back to place'. As proven before, high conductive material are better fit to generate powerful electrical current. Unless you manage to create some quasi superconductive piezoelectroc, and build a good pressure system, it won't be as efficient as a coil/magnet generator.
How could it be superconductiong if, at the same time, you expect it to Polarise?
So, is it true that the magnets in a generator are exciting the electrons in the copper of the windings into outer shells and then they move down the wire as the electricity that we use? If this is true... then aren't the number of electrons in a finite amount of copper... finite? If so then how is a generator able to just continue producing electricity indefinitely? Also wouldn't the mass of the copper windings decrease over time?
You don't change the number of electrons. You just move them all a few mm in one direction or another. Total charge has to stay at zero.
Thanks Sophiecentaur but that makes no sense to me. Can you tell me a good book or website that will give me a good explanation (with graphics) of how generators produce electricity... how it all works...
There's an awful lot to this subject. Q an A doesn't really suit foundation level learning. Best to look in Wiki about the way electric current flows. No "shells" involved, for example.
Have you tried Wiki?
Is it plausible to use a piezo bending generator mounted with an offset rudder, set up in tidal water flows to generate a meaningful amount of power? The offset rudder would cause it to rapidly bend in alternating directions and under great strain.
Or would this still not be as efficient as a typical rotary turbine?
Related to Can piezoelectric concept be used to generate electricity on a large scale
1. Can piezoelectric materials produce enough electricity to power large-scale applications?
Yes, piezoelectric materials have been shown to generate significant amounts of electricity when used in large-scale applications. In fact, some piezoelectric devices can produce up to 10 watts of power, which is enough to power small electronic devices.
2. Is the use of piezoelectric materials a cost-effective way to generate electricity on a large scale?
The cost-effectiveness of using piezoelectric materials for large-scale electricity generation depends on various factors such as the type of material used, the size and design of the application, and the availability of other energy sources. However, research is ongoing to develop more efficient and affordable piezoelectric materials for mass production.
3. Are there any environmental concerns associated with using piezoelectric materials for large-scale electricity generation?
Piezoelectric materials are considered to be environmentally friendly as they do not emit any pollutants or greenhouse gases during the electricity generation process. However, the production of these materials and their disposal can have environmental impacts, but efforts are being made to minimize these effects.
4. Can piezoelectric materials be used to generate electricity from any type of movement?
Piezoelectric materials can generate electricity from various types of movement, such as mechanical stress, vibration, and even human movement. However, the amount of electricity produced may vary depending on the type and intensity of the movement.
5. What are some current applications of piezoelectric materials for large-scale electricity generation?
Some current applications of piezoelectric materials for large-scale electricity generation include energy harvesting from traffic and pedestrian movement, vibration energy harvesting from industrial machinery, and electricity generation from ocean waves and wind power. Research is also being conducted to explore other potential applications such as using piezoelectric materials in footwear to generate electricity from walking.
