Singlet and Triplet Spin States
Actually it's my own long and enjoyable experience that has finally taught me that I can't assume I remember things which I really do remember after all. I try to remember to look before I leap.
joebo
In a system with two spin 1/2 particles ,
We now ask what are the allowed total spin states generated by adding the spins ${\bf S}= {\bf S}_1 + {\bf S}_2$ ,in fact, they are Singlet and Triplet Spin States
\left( \begin{array}{ll} |1,1\rangle & =\uparrow\uparrow\\ |1,0\rangle & =\frac{1}{\sqrt{2}}(\uparrow\downarrow + \downarrow\uparrow)\\ |1,-1\rangle & =\downarrow\downarrow \end{array} \right)\ s=1\ (\mathrm{triplet})
\left(|0,0\rangle=\frac{1}{\sqrt{2}}(\uparrow\downarrow - \downarrow\uparrow)\right)\ s=0\ (\mathrm{singlet})
so, when s=1 and m=0, many people call it state of parallel spin, but i don't think so , and i also don't understand the state . (or s=1,m=0 ) can you help me? thanks!
We now ask what are the allowed total spin states generated by adding the spins [tex]{\bf S}= {\bf S}_1 + {\bf S}_2[/tex] ,in fact, they are Singlet and Triplet Spin States
[tex] \left( \begin{array}{ll} |1,1\rangle & =\uparrow\uparrow\\ |1,0\rangle & =\frac{1}{\sqrt{2}}(\uparrow\downarrow + \downarrow\uparrow)\\ |1,-1\rangle & =\downarrow\downarrow \end{array} \right)\ s=1\ (\mathrm{triplet}) [/tex]
[tex] \left(|0,0\rangle=\frac{1}{\sqrt{2}}(\uparrow\downarrow - \downarrow\uparrow)\right)\ s=0\ (\mathrm{singlet}) [/tex]
First of all, please edit your post to put TeX tags around your formatting, as I have done in this repsonse.
Second, I'm not sure I understand your question, is it just about the sematics? "Parallel spin" is a colloquial (and imprecise) way to refer to the s=1 triplet state, because the m=+1 and m=-1 cases correspond to microstates where the two spins have the same projection on a space-fixed axis. As you point out, this is at best a "fuzzy" way to refer to the m=0 state, which is the symmetric linear combination of the microstates where the spins have opposite projections. The s=0, m=0 state corresponds to the anti-symmetric linear combination of the opposite-projection microstates.
Does that answer your question, or did I miss the point?
The singlet and triplet states are historically important for indicating the existence of "spin".
But if you try to understand the singlet and triplet states as "concrete" things, this may be difficult, I think. (Sorry if I misunderstand you.)
We had better consider these states as "mathematical" systems as SpectraCat shows in #2.
In the case of the triplet state (except the case of [tex]l = 0[/tex]) , the two electrons of the different orbits have the parallel spin to each other.
So the sum of their spins (of electron 1 and 2) is 1. ([tex]S =S_{1}+S_{2}= 1[/tex]).
In this state, this [tex]S[/tex] has three directions (parallel, antiparallel or perpendicular to the orbital angular momentum([tex]l[/tex])).
(Here, the state in which [tex]S[/tex] is perpendicular to [tex]l[/tex] is a little difficult to imagine.)
But actually the magnetic force between the spin-spin interaction is too small.
So why the two separate electrons can make their spin directions the same?
In QM, this is said to be due to the force caused by the "antisymmetry of the Schrodinger equation". (The Stroy of Spin).
For example, when the [tex]S[/tex] is zero, the spin effect vanish, and the normal Zeeman effect is said to be seen.(See this thread)
But actually, even in this state the two electrons of the different orbits are apart from each other. So around the electron 1, the magnetic moment by the electron 1 exist, and the spin-orbital interaction (by the electron 1 itself) can occur. (if you imagine this state concretely).
The spin-orbital interaction means that the spin effect doesn't vanish. This is inconsistent with the fact [tex]S=0[/tex].
So only the "mathematical systems" are good to describe these states.
Thanks, SpectraCat, for fixing the Latex. The triplet states are not hard to visualize because everything they do as a combination of two electrons is no different from what the orbital spin states do with s=1, and in this case we can look at the wave functions of the hydrogen atom for a concrete example.
The +/-1 states have a wave function which goes to zero at the poles and varies around the equator as one cycle of the complex exponential function. The m=0 state has two lobes, positive and negative, in the northern and southern hemispheres. If you play around a little with the geometry and the exponential functions, you can see that the m=0 state is really what you would get as the superposition of plus and minus spin states if you had started out by lining up your states to the x or y-axis instead of the z axis.
I don't remember every discussion I get into on the internet but in fact that one did make a big impression on me. In any event, thank you for not assuming I am totally senile.
Related to Singlet and Triplet Spin States
1. What are singlet and triplet spin states?
Singlet and triplet spin states refer to the different possible orientations of electron spins in a system. In a singlet state, the spins of two electrons are paired and pointing in opposite directions, resulting in a total spin of zero. In a triplet state, the spins of two electrons are aligned in the same direction, resulting in a total spin of one.
2. How do singlet and triplet spin states affect chemical reactions?
The singlet and triplet spin states of molecules can determine their reactivity in chemical reactions. In general, singlet states are more reactive than triplet states because the electrons in a singlet state have a higher probability of interacting with other molecules and initiating a reaction.
3. What is spin crossover and how does it relate to singlet and triplet states?
Spin crossover is the phenomenon in which a molecule switches between different spin states. This can occur in systems with transition metal ions, and the energy difference between singlet and triplet states can determine the stability and reactivity of the molecule.
4. Can singlet and triplet states be observed in everyday life?
Yes, singlet and triplet states can be observed in everyday life, particularly in the fields of chemistry and physics. For example, fluorescent molecules have different singlet and triplet states that determine their emission properties, and magnetic materials have different spin states that determine their magnetic properties.
5. How are singlet and triplet states studied in the laboratory?
Singlet and triplet states are studied using various techniques, including spectroscopy, electron paramagnetic resonance, and magnetic susceptibility measurements. These methods allow scientists to probe the energy levels and transitions between singlet and triplet states in different molecules and materials.
