Vacuum energy in gravitational fields
In summary, this paper discusses the effects of gravitational fields on virtual particle pairs. Robert Caldwell found that if zero-point energy is truly the source of the cosmological constant, then gravitational fields can cause variations in zero-point energy. If this energy is eliminated by restricting the physical space in which the pairs form, then it may not be constant. If we accept a causal agent for dark energy that can be excluded by matter or by bounding very small areas with matter, then we must be prepared to accept that it is not an all-pervasive field of constant density.
turbo
56
Some time back, I asked if there was anyone doing work studying the effects of gravitational fields on virtual particle pairs. Tonight I found this paper (see section 4) - is there someone here who can steer me to similar work?
http://xxx.lanl.gov/abs/astro-ph/0006423
Astronomy news on Phys.org
Exciting paper!
Paper by Robert Caldwell (Dartmouth). Using the Casimir-effect as a model, he calculates that gravitational fields can cause variations in zero-point energy. If zero-point energy is truly the source of the cosmological constant, then it cannot actually be constant.
http://arxiv.org/abs/astro-ph/0209312
I tried to find more about this by looking in Citebase for
articles that cite Caldwell
but I found only two, and this was IMO the more on-topic one:
http://arxiv.org/quant-ph/0210173
"Casimir effect and vacuum energy"
Cyriaque Genet, Astrid Lambrecht, Serge Reynaud
10 pages, IAP Colloquium "On the nature of dark energy"
this cites caldwell right at the end, in the conclusions.
I agree that zero point energy cannot be constant and I would like to
understand better how Caldwell says it is effected by the gravitational field.
Let's hope more articles about this show up. I was disappointed not to find more in Citebase. Glad you found this, turbo.
I was Looking for a Way For Space Travel
http://www.lerc.nasa.gov/WWW/PAO/images/warp/warp31.gif
Zero Point Energy (ZPE), or vacuum fluctuation energy are terms used to describe the random electromagnetic oscillations that are left in a vacuum after all other energy has been removed. If you remove all the energy from a space, take out all the matter, all the heat, all the light... everything -- you will find that there is still some energy left. One way to explain this is from the uncertainty principle from quantum physics that implies that it is impossible to have an absolutely zero energy condition.
http://www.lerc.nasa.gov/WWW/PAO/html/warp/possible.htm
I underlined that statement specifically for you Marcus.
http://wc0.worldcrossing.com/WebX?14@74.8s0EcmXasDc.14@.1dde934e/82
Robert Caldwell is the creator of the model known as "Phantom energy", and he shall do whatever thing to dismiss the possibility that dark energy has constant density
Is there a good reason why dark energy should have a constant density, other than simplifying calculations for physicists? :rolleyes:
If dark energy is really zero-point energy and zero-point energy (as demonstrated the the Casimir effect) can be eliminated from an area by simply restricting the physical space in which virtual pairs can form, then one would expect that massive objects like planets, stars, etc, would be huge voids in the dark energy field. I find it easier to understand variations in dark energy density than to believe that its density must be constant under all curcumstances. If we accept a causal agent for dark energy that can be excluded by matter or by bounding very small areas with matter, then we must be prepared to accept that it is not an all-pervasive field of constant density.
marcus said:
I agree that zero point energy cannot be constant and I would like tounderstand better how Caldwell says it is effected by the gravitational field. Let's hope more articles about this show up. I was disappointed not to find more in Citebase. Glad you found this, turbo.
I was very happy to find this, too and would like to know if there are any other studies in this vein. There is a reason for my madness: If gravitational fields can produce preferred orientations in the alignments of virtual particle pairs, it *may* be possible to exploit that pervasive sea of energy. Perhaps not here on Earth, but how about for space propulsion? I know this is NOT the forum to posit this, but if gravity can orient virtual pairs, and we could produce a boundary that preferentially passes particles in one direction and anti-particles in the opposite direction, or passes either particles or antiparticles while rejecting their opposites, we may be able to create a pressure gradient in zero-point energy across this boundary to use as thrust. :rolleyes: I would love for humans to explore space, but at the expense of the already-existing energy of the vacuum, not by trying to throw reaction mass away.
If virtual pairs cannot be oriented by gravitation, solar wind, etc, then our attempts to break their bonds will probably cost way more energy than we can recover. Preferential orientation of the pairs would make exploitation of ZPE conceivable, if not practical.
I just noticed the title on your post, Sol. If we can create a boundary that exploits possible gradients in the ZPE field (be they preferential pair orientation, field density, etc) we've got a chance of going to the stars.
FAQ: Vacuum energy in gravitational fields
What is vacuum energy in gravitational fields?
Vacuum energy in gravitational fields is a concept in quantum field theory that refers to the energy of the vacuum, or empty space, in the presence of a gravitational field. It is related to the idea that even in seemingly empty space, there are constantly virtual particles popping in and out of existence, giving the vacuum a non-zero energy density.
How does vacuum energy in gravitational fields affect the universe?
Vacuum energy in gravitational fields is thought to contribute to the expansion of the universe. In the early universe, it likely played a role in the period of rapid expansion known as inflation. In the current universe, it may be responsible for the observed acceleration of the universe's expansion.
Can vacuum energy in gravitational fields be observed or measured?
Currently, there is no direct way to observe or measure vacuum energy in gravitational fields. However, it is indirectly observed through its effects on the universe, such as the expansion and acceleration of the universe.
What are some proposed explanations for the value of vacuum energy in gravitational fields?
There are several theories that attempt to explain the observed value of vacuum energy in gravitational fields, including the anthropic principle, supersymmetry, and various models of quantum gravity. However, the true explanation is still unknown and remains a subject of ongoing research.
Is vacuum energy in gravitational fields related to dark energy?
Yes, vacuum energy in gravitational fields is often equated with dark energy, as they share similar properties and effects on the universe. However, the exact relationship between the two is still a topic of debate among scientists.
