Difference between Surface Waves and Lateral Waves
In summary, transverse waves are the only type that are possible with electromagnetic radiation. Surface waves are similar to longitudinal waves but they only propagate in one direction. Practical uses? Well, understanding the orientation of waves in EM communication is important, as is understanding the phenomenon of polarisation.
Ionito
Related to the Electromagnetism area, what is the difference between Surface Waves and Lateral Waves? Also: practical uses?
Well, they are similar in that the motion of oscillation is perpendicular to the motion of the wave. Think of a surface wave on water for example. The water only goes up and down but the wave travels outward. A lateral wave is analogous to waving a rope back and forth. The rope only moves left and right but the wave travels outward.
There's one other type of wave that you didn't ask about. The longitudinal wave. Sound is a good example for it. Air compresses and stretches along the direction of the wave's motion.
In EM, they don't use the word lateral. They call it transverse. The Electric and magnetic field vectors are perpendicular to the direction of the wave. Because of the laws of physics, only transverse waves are possible for EM radiation.
Practical uses? It's important to understand the possible orientations of EM wave oscillation if you want transmit and receive through an antenna.
Hi Okefenokee, Thanks for the reply!
I read (Barlow, 1962, Radio Surface Waves) that it is possible to use surface waves for communication. There is an example for sea water surface. On the other hand, I also read about Lateral waves in "King, 1980, Antennas in Matter" for soil and water subsurface communication. For this one, there are explicit examples of transmitting below the water surface (up direction), the waves propagating in the air-interface just above the water surface (lateral/radial direction), and the waves propagating again down to the water (down direction). I would like to know if the "lateral" part of the propagation is related to "surface waves" mentioned previoulsly.
Both of these are transverse waves.
The rope is however a good analogy because it demonstrates another phenomenon.
Polarisation.
In wave terms (this has nothing to do with charges and ions) it simple means that the wave particles are constrained to only vibrate in certain positions.
You can waggle the rope up and down or side to side (lateral waves), or if you are clever at any angle to the horizontal you chose.
This is an example of plane polarisation, the rope is constrained to waggle in a vertical, horizontal or intermediate plane.
If you now start rotating the rope in a circle, like a skipping rope, and at the same time waggle it up and down, the up and down waggle transmits as a helix down the line.
this is known as circular polarisation.
The whole of the transmitting medium participates in all of the above waves.
But it is perfectly possible for only part of a medium (usually the surface) to participate - These are of course surface waves.
Now as Oke has mentioned there are two principal modes of action by the particles of the medium. Which one occurs or can occur depends upon the medium itself.
The two modes correspond to transverse and normal forces (stresses) in mechanics or if you like shear and tension/compression.
Now a fluid cannot support shear in the body of the fluid, only at the surface, so can only transmit normal or pressure waves, such as sound.
As we note from the ocean it can support transverse or shear waves at its surface.
Solids, on the other hand, can support both types through the body and at the surface. Surface Acoutic wave devices for instance are surface pressure waves.
Electromagnetic waves are transverse waves. I suspect some of the surface waves you are asking about are 'guided waves'. A guided wave propagates within a guiding 'channel' which provides physical boundaries that reflect the wave energy beckwards and forwards between them, keeping the wave inside the channel.
Some frequencies of radio work like this. A normal radio wave propagates out in all directions, but certain frequencies are reflected from the ionosphere, back to the ground, where they are reflected back up again and so on.
In this case the direct transverse electromagnetic wave is called the surface wave and the reflected wave the sky wave.
Electromagnetic waves can also be polarised. Hence the lateral waves you were asking about, these are polarised transverse waves. Naturally antennae have to be correctly oriented to sync with the polarisation.
Hope this all helps.
Oh, the surface wave you are talking about is actually a low frequency radio wave that diffracts around the surface of the earth. The wave is really transverse like any other EM wave but it acts similarly to a "surface wave" under the right conditions. Your Barlow fellow must have found some ideal conditions for diffracting radio waves over sea water.
I'm not sure what King is talking about. Maybe he found some path so that the wave can refract through the water-air boundary, bend back to the water's surface by diffraction after traveling some distance, and then refract back through the water-air boundary. That's only a wild guess on my part though.
Can you contact King? It would be best to get it from the horse's mouth, so to speak.
What about gravitational waves if they exist?.
The moving particles in the diagrams move in many directions under the influence of the waves.
The waves must have a longitudinal component ,strong /weaker attraction ,if they are from
binary star pair observed edge on as each star moves toward the observer then away.
Longitudinal (compression) waves in matter are much faster than transverse waves in matter so how fast is the longitudinal component of a gravitational wave compared with electromagnetic waves which are all transverse?.
Related to Difference between Surface Waves and Lateral Waves
What are surface waves?
Surface waves are a type of seismic wave that travels along the surface of the Earth. They are created by the interaction of P-waves and S-waves with the Earth's surface.
What are lateral waves?
Lateral waves, also known as Love waves, are a type of seismic wave that travels along the Earth's surface. They are named after the British mathematician A.E.H. Love, who first described their properties.
How do surface waves and lateral waves differ?
The main difference between surface waves and lateral waves is their mode of propagation. Surface waves travel along the surface of the Earth, while lateral waves travel just below the surface. Additionally, surface waves have both vertical and horizontal particle motion, while lateral waves only have horizontal particle motion.
Which type of seismic wave causes the most damage?
Surface waves are the most damaging type of seismic wave. This is because they travel along the surface of the Earth, causing the ground to move in a rolling motion, which can lead to significant damage to buildings and structures.
Can surface waves and lateral waves be measured?
Yes, surface waves and lateral waves can be measured using seismometers. These instruments record the amplitude and frequency of the waves, providing valuable information about the location and magnitude of an earthquake.
  • Electrical Engineering
