Calculating the Angle at Which a Marble Falls Off a Smooth Sphere
  • Thread starter dibilo
  • Tags
    Ball Fall
In summary, the force of gravity has components mgcos(\theta) and mgsin(\theta) in the normal and tangential directions, respectively.2. Normal reactionThis is a force that the plane exerts on the body in contact with it. It always acts in the normal direction to the plane, but it's magnitude is not a priori obvious. All we know is that it acts in such a direction as to prevent the body from penetrating the plane.3. The reason why I asked you to be careful about the radius in the term for centripetal acceleration is that this term involves the angular velocity of the particle, \omega.Now, recall that the C.M moves in a circular orbit.The angular velocity
dibilo
47
a small marble of mass m resting on the top of a smooth sphere of radius R. you nudge the marbles slightly and it starts rolling down the side. at what point (at what angle) on the sphere does the marble fall off the sphere?
ans: 48deg
after reading my guess is that the marble will fall off when "a" (acceleration of marble) is equal or greater then mg
therefore mg=a
am i heading the right direction? what formula can i use... i can only think of a=v^2/R
Careful!
The ball will fall off when the normal force acting upon the small marble is zero, that is, when the component of gravity along the normal yields the required centripetal acceleration by itself.
Hints for the solution:
1. The mechanical energy of the system is conserved.
How should you express this fact?
2. The marble is ROLLING!
How does this relate the angular velocity of the marble with the rate of change of its angular position on the sphere?
3. The C.M of the marble moves in a circular (segment) orbit.
Good luck!
Wouldn't the big sphere also start rolling?
It may well do so, but that's a nasty version of this exercise.
I don't think that version was intended, that is, we assume the big sphere to remain at rest through some effect.
how do i compare when i don't know the size of marble?
and about conservation of energy really have no idea how to link the two.. for all i know potential energy (mgh) was converted to kinetic(1/2mv^2).. but i didnt have enough info (i think ) to do anything with them.
but thanks a lot for pointing out the N=0 part ... now i got at start, N=mg then at falling off, N=mgcos[tex]\theta[/tex]=0
pls offer me more hints.. thanks :)
1. Let the radius of the marble be given by r, and use this in calculations
(the marble has some radius, we just don't know it's value!)
If necessary, you may make your final answer independent of r by assuming that the marble radius is much less than the sphere's radius (do this only at the very end).
2. Conservation of energy:
a)Let the angle that the C.M of the marble makes to the vertical be termed [tex]\theta[/tex]
Clearly, by geometry, this could be used to determine the potential energy of the marble at some [tex]\theta[/tex]-value (right?)
b)Now, the C.M moves in a CIRCULAR orbit.
How is therefore the C.M's speed connected to the time derivative of [tex]\theta[/tex]?
c) Rolling:
The point on the marble in contact with the sphere must have zero velocity.
4. It is absolutely untrue that N=mg (or mgcos(s)) in general. Think over it
For a particle sliding on a spherical shell, it will leave the surface at an angle of acos(2/3). That can be found from both Lagrangian techniques and conservation of energy and momentum. I forget the exact answer for a particle rolling on a sphere. I believe that the problem is done in Marion and Thorndike (sic) amongst other mechanics books and possibly the Schaum's outline in Theoretical Mechanics.
dt
thx for all the replies.. i got it pretty much figured out... except for one point.
how do i get the equation
mgcos[tex]\theta[/tex]-N=mv^2/r
isnt mgcos[tex]\theta[/tex] the normal force when the marble falls off?
i mean if that's so then what's N then in this case.. someone pls explain thanks :)
1. N is the normal force, mgcos(w) is the component of gravity along the surface normal. When N is 0 (N=0), that component of gravity equals m*centripetal acceleration
2. Be careful about what the radius in the centripetal acceleration term should be
Aha, a much simpler version of arildno's teaser...
dibilo, I think your doubt is a result of the common misconception - that is often a result of poor teaching - that the normal reaction is the same as the weight or it's normal component.
This is not true. The normal reaction is the force of interaction between the surfaces and you find it to be the negative of the resultant of the normal components of other forces on the body - in the frame where the surfaces of contact have no acceleration along the normal direction.
Have I just made things a lot worse ?
wow u hit the nail right on the head about my lecturer.. no one in my class understands him... fortunately there's pf. back to main topic... ok so N is the reaction force by the surface on the object acting on it this part is quite clear and mgcos[tex]\theta[/tex] is the so call weight of the object right?
i have a little doubt here. if we consider a block on a slope with friction, we know N is mgcos[tex]\theta[/tex] and weight is mg which is downwards. how is this different from this question.
OK, a bit to sort out here:
1. Weight:
This is equal to mg, acting downwards.
However, it's "downwards" is not always the convenient direction to think weight in terms with!
For example, on a slope, the two most convenient directions are a)tangential to the slope, b)normal to the slope.
But, "downwards" is rarely coincident with either of these directions in space; rather, "downwards" must be seen as having components in both directions; a normal component, and a tangential component.
To be specific, let a sloping plane make angle [tex]\theta[/tex] to the horizontal (normal to "downwards")
We use [tex]\vec{i}[/tex] to be a unit vector in the horizontal direction, wheres [tex]\vec{j}[/tex] is a unit vector in the "upwards" direction.
Also, let [tex]\vec{t}[/tex] be a unit vector in the tangential direction to the sloping plane, while [tex]\vec{n}[/tex] is a unit vector in the normal direction of the sloping plane ("normal" meaning in a direction at right angles to the plane)
We have the following relation for the tangent vector:
[tex]\vec{t}=\cos\theta\vec{i}+\sin\theta\vec{j}[/tex]
Since [tex]\vec{n}[/tex] is normal to the tangent, we may write:
[tex]\vec{n}=-\sin\theta\vec{i}+\cos\theta\vec{j}[/tex]
We now proceed to invert these relations, that is, express [tex]\vec{i},\vec{j}[/tex] in terms of [tex]\vec{t},\vec{n}[/tex]
By the choices we've made, we get:
[tex]\vec{i}=\cos\theta\vec{t}-\sin\theta\vec{n}[/tex]
[tex]\vec{j}=\sin\theta\vec{t}+\cos\theta\vec{n}[/tex]
The weight of an object of mass m, [tex]\vec{W}[/tex] is in the downwards direction, so clearly we have:
[tex]\vec{W}=-mg\vec{j}[/tex]
Hence, expressed in terms of vectors [tex]\vec{t},\vec{n}[/tex] the weight
has the form (substituting for [tex]\vec{j}[/tex]):
[tex]\vec{W}=-mg\sin\theta\vec{t}-mg\cos\theta\vec{n}[/tex]
It is crucial that you understand this, so I'll stop here at the moment.
Please post any questions you might have.
dibilo,
Try and get yourself a copy of Resnick & Halliday - it's worth it.
i refer to this equation again. mgcos[tex]\theta[/tex]-N=mv^2/r
1] is my drawing true?... in this equation are you using a different set of x-y coordinates?
2]if yes shouldn't my N be mgcos[tex]\theta[/tex] and weight = mg? (i can get it if i use the radius as my hypothenis but i doubt i am correct.)
3]if no how do u derive mgcos[tex]\theta[/tex]
pls explain as comprehensively as possible. any help is greatly appreciated... i really what to understand this concept rather then getting the equation from a text .. thanks again
[tex]mg\cos\theta[/tex] is first and foremost the component of gravity along the normal.
On the straight slope, the object in contact with the slope cannot move or accelerate into the slope.
Hence, by Newton's 2.law in the normal direction, the component of gravity must be off-set by an equally strong, oppositely directed NORMAL FORCE from the slope.
This implies that on the straight slope, the normal force is of magnitude [tex]mg\cos\theta[/tex]
Are you with me on this?
Please read my previous post.
The crucial difference between the straight slope and the spherical surface case, is that in spherical case, you'll have centripetal acceleration in the normal direction, even if you have no normal velocity.
This is represented by Newton's 2.law in the normal direction:
[tex]N=mg\cos\theta-m\frac{v^{2}}{\mathcal{R}}[/tex]
There you have the expression for N!
Setting N=0 (falling off), we get:
[tex]mg\cos\theta=m\frac{v^{2}}{\mathcal{R}}[/tex]
([tex]\mathcal{R}[/tex] is the radius of curvature)
ok loud and clear.. thanks ;)
to: dibilo
[tex]mgh=\frac{1}{2}mv^2+\frac{1}{2}I\omega^2[\tex]...(1)
[tex]\omegar=v[\tex]...(2) and [tex]I=\frac{2}{5}mr^2[\tex]...(3)
because of conservation of energy, rolling and rotational inertia of the marble. Therefore, [tex]gh=\frac{7}{10}v^2[\tex].
[tex]mg\cos\theta=m\frac{v^2}{R}[\tex] due to N=0 and the centripetal force.
Finally,[tex]\cos\theta=\frac{R-h}{R}[\tex] due to trigonometrical and geometrical properties. Consequently, [tex]\cos\theta=\frac{10}{17}.
=> theta~53.968...
If you want to get theta~48 degrees=> [tex]mgh=\frac{1}{2}mv^2[tex], but that case the marble is not rolling.
wisky40
I don't know what is wrong with my way of writing latex, once again I'm sorry.
wisky40
let me see, I'm going to try again...
[tex]mgh=\frac{1}{2}mv^2+\frac{1}{2}I\omega^2[/tex], [tex]\omegar=v[/tex]
and [tex]I=\frac{2}{5}mr^2[/tex]...
[tex]\cos\theta=\frac{R-h}{R}[/tex]
[tex]mg\cos\theta=m\frac{v^2}{R}[/tex]
[tex]\omega{r}=v[/tex]
try all these equations to solve the problem. I hope this works.
wisky40
Related to Calculating the Angle at Which a Marble Falls Off a Smooth Sphere
1. When will the ball fall off?
The ball will fall off when it reaches the end of its trajectory or when it is subjected to a force that causes it to fall.
2. What factors affect when the ball will fall off?
The factors that affect when the ball will fall off include the initial velocity of the ball, the angle at which it is thrown, and the presence of any external forces such as air resistance or gravity.
3. Can we predict when the ball will fall off?
Yes, we can use mathematical equations and principles of physics to predict when the ball will fall off. However, there may be some variables that can affect the accuracy of the prediction.
4. How can we control when the ball will fall off?
We can control when the ball will fall off by adjusting the initial velocity and angle at which it is thrown, as well as by minimizing the effects of external forces such as air resistance.
5. Is the timing of when the ball falls off consistent?
The timing of when the ball falls off may not be consistent due to the presence of unpredictable variables such as wind or uneven surfaces. However, if all other factors remain constant, the timing should be consistent.
