Writing a polynomial in terms of other polynomials (Hermite, Legendre, Laguerre)
In summary: I don't know if you can see it)Regardless, my answer is wrong. I don't know why.And I don't understand what you mean by calculating the five integrals.Thanks for your help!In summary, the conversation involved a student seeking help with a problem involving deriving polynomials in terms of orthogonal functions. The student initially tried using a linear algebra method, but the professor suggested using the equation f(x)=\sum_{n=1}a_n\phi_n(x) and the correct inner product for the Laguerre polynomials, which led to a simpler solution. Another method for solving the problem was also suggested, involving calculating five integrals. However, the student encountered some errors in their calculations and sought clarification on
PhysicsMark
91
The first 3 parts of this 4 part problem were to derive the first 5 Hermite polynomials (thanks vela), The first 5 Legendre polynomials, and the first 5 Laguerre polynomials. Here is the last part:
Write the polynomial [tex]2x^4-x^3+3x^2+5x+2[/tex] in terms of each of the sets of orthogonal functions: Legendre polynomials, Hermite polynomials and Laguerre polynomials.
[tex]P_0 = 1[/tex]
[tex]P_1 = x[/tex]
[tex]P_2 = \frac{1}{2}(3x^2-1)[/tex]
[tex]P_3 = \frac{1}{2}(5x^3-3x)[/tex]
[tex]P_4 = \frac{1}{6}(35x^4-30x^2+3)[/tex]
Hermite polynomials
[tex]H_0=1[/tex]
[tex]H_1=2x[/tex]
[tex]H_2=4x^2-2[/tex]
[tex]H_3=8x^3-12x[/tex]
[tex]H_4=16x^4-48x^2+12[/tex]
[tex]L_0=1[/tex]
[tex]L_1=-x+1[/tex]
[tex]L_2=\frac{1}{2}(x^2-4x+2)[/tex]
[tex]L_3=\frac{1}{6}(-x^3+9x^2-18x+6)[/tex]
[tex]L_4=\frac{1}{24}(x^4-16x^3+72x^2-96x+24)[/tex]
I first started with the Laguerre polynomials. I recognized that the 5th Laguerre polynomial was the only one that contained an x^4 term. I then knew that the only way to get an 2x^4 term in the polynomial I am trying to re-write would be to multiply L4 by 48. I then went on to look at the -x^3 term. I realized that since the multiple of L4 (48) couldn't be changed, I would have to multiply L3 by something that would give me the -x^3 term after it was added to the x^3 term in the L4 polynomial. I continued this path until I reached:
[tex]2x^4-x^3+3x^2+5x+2=48L_4-186L_3+276L_2-191L_1+55L_0[/tex]
I was not entirely sure what the question was asking so I took my first result to my professor. He said that the method used was correct (as long as my algebra was correct) but that it is not the method he had intended us to use. He said that I needed to use the equation:
[tex]f(x)=\sum_{n=1}a_n\phi_n(x)[/tex]
Where phi is either the Legendre, Hermite or Laguerre polynomials.
I went back through my notes and tutorial and found a way to express the coefficients a_n. However, the method used to find a_n was for periodic functions, namely the example shown was for the orthogonal set of sine and cosine.
I attempted to model a new solution based on the one for cosine and sine. I do not think that my new attempt is correct because while it yields the correct coefficients (at least for the L0 & L1) of the Laguerre polynomials, it seems a more complicated method then my first attempt. Also, I believe that trying to solve for the coefficients in the way I did is just a re-hashing of deriving the original polynomials.
What I did was I took the equation:
and multiplied both sides by phi_m and then integrated both sides. Using orthogonality relationships I came up with:
[tex]a_n=\int_{0}^{\infty}f(x)\phi_n(x)dx[/tex]
For the Laguerre polynomials (normalized to 1)
Eventually this just boiled down to a similar linear algebra problem that I am supposed to avoid. Does anyone see another way?
That's not the correct inner product for the Laguerre polynomials. You need the weighting function w(x)=e-x in there. Other than that detail, though, your method is correct.
Thanks for the response.
If,
[tex]a_n=\int_{0}^{\infty}f(x)\phi_n(x)e^{-x}dx[/tex]
For the laguerre polynomials is correct, then does this say:
[tex]a_4=\int_{0}^{\infty}(2x^4-x^3+3x^2+5x+2)(\frac{1}{24}x^4-\frac{2}{3}x^3+3x^2-4x+1)e^{-x}dx[/tex]
I tried the above equation. I ended up having 9 integrals that looked like:
[tex]\int_{0}^{\infty}cx^{(m+n)}e^{-x}dx[/tex]
where c is a constant and the quantity (m+n) is the power of x. Based off of previous results, I used the relationship:
[tex]\int_{0}^{\infty}x^{(m+n)}e^{-x}dx=(m+n)![/tex]
I input the product of the two polynomials into maple and then applied the above equation for the different values of (m+n) and got back that
[tex]a_4=\frac{-349}{24}[/tex]
I feel fairly certain that the coefficient of of L4 must be 48.
I just evaluated that integral in Mathematica, and it was equal to 48.
This is the product of f(x) and L4(x):
[tex]2-3 x-11 x^2+\frac{2 x^3}{3}+\frac{47 x^4}{4}-\frac{307 x^5}{24}+\frac{163 x^6}{24}-\frac{11 x^7}{8}+\frac{x^8}{12}[/tex]
so you get
[tex]2(0!)-3(1!)-11(2!)+\frac{2}{3}(3!)+\frac{47}{4}(4!)-\frac{307}{24}(5!)+\frac{163}{24}(6!)-\frac{11}{8}(7!)+\frac{1}{12}(8!) = 48[/tex]
It occurs to me you can save yourself quite a bit of work if you just calculate the five integrals
[tex]I_n = \int_0^\infty x^n f(x) e^{-x} dx[/tex]
for n=0, 1, 2, 3, 4. Then, for instance,
[tex]a_4 = \int_0^\infty L_4(x) f(x) e^{-x} dx = \frac{1}{24}(I_4 - 16 I_3 + 72 I_2 - 96 I_1 + 24 I_0) [/tex]
Wow. Thanks. I must have made a mistake along the line. I haven't found it yet, but I agree with your post. Thank you for doubling checking and taking the time to evaluate the integral. Thanks again, I seem to make a ton of algebraic / input mistakes.
[tex]a_4 = \int_-1^\1 L_4(x) f(x) e^{-x} dx = \frac{1}{24}(I_4 - 16 I_3 + 72 I_2 - 96 I_1 + 24 I_0) [/tex]
Hey, Vela. When I did the Hermite polynomial, I used
int ( 2x^4-x^3+3x^2+5x+2) ( 16x^4-48x^2+12) (e^-x^2), -inf, inf to calculate the a4, but I got a different number from linear algebra. (e^-x^2 is the weight function for Hermite polynomial)
You need to take into account how the Hermite polynomials are normalized, namely
[tex]\int_{-\infty}^\infty H_n(x)H_n(x)e^{-x^2} dx = n!~2^n \sqrt{\pi}[/tex]
Did you do that?
Okay, thanks.
FAQ: Writing a polynomial in terms of other polynomials (Hermite, Legendre, Laguerre)
What are Hermite, Legendre, and Laguerre polynomials?
Hermite, Legendre, and Laguerre polynomials are three types of special functions used in mathematics. They are often used to solve differential equations and are named after the mathematicians who first studied them.
Why would I need to write a polynomial in terms of other polynomials?
Writing a polynomial in terms of other polynomials can make it easier to manipulate and solve. It can also help reveal patterns and relationships between different polynomials.
How do I write a polynomial in terms of Hermite polynomials?
To write a polynomial in terms of Hermite polynomials, you can use the Hermite polynomial expansion formula. This formula involves a sum of coefficients multiplied by different powers of the Hermite polynomial. You can use this formula to rewrite a polynomial in terms of Hermite polynomials.
Can I write any polynomial in terms of Legendre polynomials?
Yes, any polynomial can be written in terms of Legendre polynomials. This is because Legendre polynomials form a complete set, meaning they can be used to represent any polynomial.
How can Laguerre polynomials be used in real-world applications?
Laguerre polynomials have various real-world applications, such as in physics, engineering, and economics. They can be used to solve problems involving differential equations and to model various physical phenomena.
