Does the Z boson couple to photons?
In summary, the experts in the conversation discuss the possibility of a Feynman rule for the coupling of two Z bosons to a photon. While there is no direct vertex for this interaction in the Standard Model Lagrangian, it can still occur through intermediate states at higher orders. However, any such interactions would be second-order weak and GIM suppressed, and conservation laws would still need to be complied with. Additionally, the self-interaction of gauge bosons in non-abelian gauge theory only allows for interactions between different types of bosons, so there would not be any direct interactions between Z bosons and a photon.
maani
Hi I can't find a Feynman rule for the coupling of two Z bosons to a photon. Does the Z boson couple to a photon at all?
You can get Z+Z -> gamma + gamma.
zz to fermion to 2gamma
zzA is not in the SM lagrangian
That's what I say: the only direct vertex is
W+ + W- => Z0 + Photon
but via intermediate states you can get (nearly) anything you like.
There are no all-neutral gauge boson couplings in the SM.
It's easiest to see this by working in the w1, w2, w3, B basis rather than the W+/-, Z, A basis.
Tom is right, these can appear at loop level, but these will be second-order weak and GIM surpressed. However, you still have to comply with conservation laws. For example, you can't get any electric dipole radiation because the Z is neutral. I need to think more about magnetic dipole and electric quadrupole.
The coupling of gauge bosons self interaction in non-abelian gauge theory is proportional to f_{abc}, i.e. only diffrent bosons can interact. So, no Z-Z-A and no Z-Z-Z interactions. You can also think that photon only couple to charged particles directly.
I do not see how this applies directly. In the el.-weak theory we have U(1)*SU(N); in addition the photon is "mixed" according to the original basis.
Related to Does the Z boson couple to photons?
1. What is the Z boson and how does it interact with other particles?
The Z boson is a subatomic particle that belongs to the electroweak force, one of the four fundamental forces in nature. It is responsible for mediating the weak nuclear force, which is responsible for radioactive decay. The Z boson interacts with other particles through the weak force, but it also has a small coupling to photons, the particles of light.
2. How does the Z boson couple to photons?
The Z boson has a very small coupling to photons, meaning that it has a small probability of interacting with them. This coupling is mediated by the Higgs boson, which gives mass to both the Z boson and the photon. The Z boson can interact with photons through a process called "Higgs-mediated scattering," where the Z boson and a photon exchange a Higgs boson.
3. What is the significance of the Z boson coupling to photons?
The Z boson coupling to photons is significant because it provides evidence for the existence of the Higgs boson and the mechanism by which particles acquire mass. It also helps to explain the symmetry between the weak nuclear force and the electromagnetic force, as both are mediated by the same particle, the photon.
4. Can the Z boson couple to other particles besides photons?
Yes, the Z boson can couple to other particles besides photons. It primarily couples to other particles through the weak force, but it also has a small coupling to the Higgs boson and can interact with other particles in processes such as electroweak interactions and particle decay.
5. How is the coupling of the Z boson to photons measured?
The coupling of the Z boson to photons is measured through experiments that involve colliding particles at high energies and analyzing the resulting data. By studying the properties of the Z boson and its interactions with other particles, scientists can determine its coupling to photons and other particles. The Large Hadron Collider (LHC) at CERN is one of the most powerful tools for studying the Z boson and its couplings.
