Understanding kW and kWh: A Primer
  • Thread starter SuperMiguel
In summary, kW is a unit of power and kWh is a unit of energy, with 1kWh equal to 1kW multiplied by 1 hour. A 300kW generator produces 300kWh of energy each hour. However, on Earth, a year is 365 days, not 356 as mentioned in the conversation. Energy is the more fundamental concept, with power being the rate at which energy is used. The electric company typically counts kWh in 15 minute intervals and multiplies by 4 to get the kW for peak demand.
SuperMiguel
110
Can any of you guys explain what exactly kW is and its relationship to kWh
Like a generator does for example 6gWy but its rated at 2gW Whats exactly does it mean?
I know that kw is power and kwh is energy..
is there a online reference's that would explain this?
Energy is power multiplied by time.
kW is a unit of power, kilo Watt = 1000 Watts
kWh is a unit of energy, 1kWh = 1kW * 1 hour
so if you have a 300 kW generator, how do you find the energy produced by it?
A 300kW generator produces 300kWh of energy each hour. How much energy does it produce in a year of continuous running?
so that would be 300x24x356 = 2628000 kWh per year right?
Think of it this way, power is instantaneous, ie power occurs at the smallest imagineable fraction of time you can possibly consider. So to find energy, you take power and multiply it by some quantity of time. Energy is a way to explain what comes out of power applied for some duration of time.
but then kW is always equal to kWh per 1 hour right?
That would be correct on a slightly different planet. Here on Earth, a year is 365 days. Unless you were counting on some downtime of the generator for periodic maintenance... :biggrin:
That's not a helpful way to think about it. Think of the power as the more fundamental thing. Especially if the power is varying with time, you would need to do an integration to calculate the energy over some time interval.
Another way to look at what a kWh is, is to calculate how big it is in more familiar units of energy. One watt is one J/s, so a kW is 1000 J/s. If you let that power "run" for one hour (3600 s), you get 1 kWh = (1000 J/s)(3600 s) = 3600000 J of energy.
Or think of energy (kWh, BTUs, joules, calories) as the fundamental concept, and power is the rate at which energy is used (Watts, Horsepower, etc)
If the power is constant, yes...
Typically, the electric company counts kWh in 15 minute intervals and multiplies by 4 to get the kW to use in their peak demand, but they could also do an instantaneous reading if they wanted to.
FAQ: Understanding kW and kWh: A Primer
1. What is the difference between kW and kWh?
kW stands for kilowatt and is a unit of power, while kWh stands for kilowatt-hour and is a unit of energy. kW measures the rate at which energy is being used or produced, while kWh measures the total amount of energy used or produced over time.
2. How are kW and kWh related?
kW and kWh are related in that they both measure energy, but in different ways. kW is a measure of power, which is the rate at which energy is being used or produced. kWh is a measure of energy, which is the total amount of energy used or produced over time. One kilowatt-hour is equal to one kilowatt of power being used for one hour.
3. What is the purpose of understanding kW and kWh?
Understanding kW and kWh is important for monitoring and managing energy usage, as well as for calculating energy costs. It can also help individuals and businesses make informed decisions about energy efficiency and renewable energy sources.
4. How are kW and kWh used in the context of electricity?
In the context of electricity, kW and kWh are used to measure the amount of power and energy being used or produced. This is important for determining the size of an electrical system needed to power a building or appliance, as well as for billing purposes.
5. Can kW and kWh be converted to other units of measurement?
Yes, kW and kWh can be converted to other units of measurement. For example, kW can be converted to horsepower, and kWh can be converted to joules or British thermal units (BTUs). Conversion factors can be found online or in conversion charts.
