Double slit experiment with detectors not recording
In summary: So basically this guy, who is calling himself a physicist, is just a crackpot and doesn't know what he's talking about!
tofu_
In the double slit experiment, a beam of electrons forms an interference pattern on a screen after passing through two slits. If you place a detector on one or both of the slits, the electrons do not form an interference pattern.
In this video:
Physicist Thomas Campbell makes the following claim (at 2:45) if you leave the detectors turned on, but you throw away the data from the detectors without looking at it, you get a wave interference pattern on the screen behind the slits.
Is this true?
In this video:
Is this true?
Here is a link to an experiment that was done regarding a "Delayed Choice Quantum Erasure"
http://arxiv.org/PS_cache/quant-ph/pdf/9903/9903047v1.pdf
How is that even possible? I though that the fundamental idea of quantum mechanics is that the act of measurement collapses the wavefunction of the electron and thus makes it behave as a particle, irrespective of whether we acknowledge the presence of the detector being there or not.
The detector here is essentially measuring the position observable X, whose only eigenfunctions are Dirac Delta functions, which gives the wavefunction a highly localised behavior and thus make it exhibit particle nature. How does it matter if we are not looking at the data of the detector? If the detector is there, then the electron should behave as a particle.
Is this true?
No. Once the data is detected by an irreversible process, deleting the data does not induce any changes. It does not matter whether you throw away the data or look at it.
The only thing you can erase are reversible markers. For example you can make the paths in the double slit experiment distinguishable by using polarizers at each slit. Afterwards it is possible to change this polarization without destroying the photon, so you can shift the polarization of the beams originating from both slits such, that they are the same again. As no irreversible process happened, the interference pattern will reappear. In this case you could get which-way information and destroy the interference pattern if you measured the photon at the right position and time, but as you never measure, it persists.
This is very different from actually measuring and throwing away the data, which will never give a persisting interference pattern.
Well, it is very hard to find information about that guy. The only info I found is as follows:
"Tom holds a Bachelor of Science in Physics and Math from Bethany College and a Master of Science in physics from Purdue University, as well as having done doctoral-level work at the University of Virginia. He is the physicist described as “TC” in Bob Monroe’s Far Journeys. Tom began researching altered states of consciousness with Bob in the early 1970s. He and Dennis Mennerich helped to design experiments and develop the technology for creating specific altered states. They were also the main subjects of Bob’s investigations at that time. For the past thirty years, Campbell has been focused on scientifically exploring the properties, boundaries, and abilities of consciousness. During that same time period, he excelled as a working scientist—a professional physicist dedicated to pushing back the frontiers of cutting-edge technology.
Using his mastery of the out-of-body experience as a springboard, he dedicated his research to discovering the outer boundaries, inner workings, and causal dynamics of the larger reality system. In February of 2003, Tom published the My Big TOE trilogy. The acronym “TOE” is a standard term in the physics community that stands for “Theory Of Everything” and has been the Holy Grail of that community for fifty years. My Big TOE represents the results and conclusions of Tom’s personal and scientific exploration of the nature of existence. This overarching model of reality, mind, and consciousness merges physics with metaphysics, explains the paranormal as well as the normal, places spirituality within a scientific context, and provides direction for those wishing to personally experience an expanded awareness of All That Is."
This sounds very much like crackpottery. But besides: if he had evidence that throwing away data alters the interference pattern, why wouldn't he publish it in a scientific journal?
There is another crackpot?:
Professor David P. Jackson
Dickinson College
Dept. of Physics and Astronomy
Carlisle, PA 17013
(717) 245-1073
jacksond@dickinson.edu
This project is funded in part by the National Science Foundation (CCLI grant DUE-0737230) and Dickinson College.
Here is the experimental setup and their conclusions:
"The mystery of the Quantum Eraser is that when we tag the photon so that we can determine which path the photon travels it seems to know that we are watching and only travels one way. However when we erase path information and we can no longer determine which path the photon travels the interference returns!
To say it simply: The photon seems to know when we are watching and behaves differently when we can say where it has traveled."
http://singlephoton.wikidot.com/quantum-eraser
But if this were true, it would be possible to send signals ftl. Makes you wonder how fairly those grants are distributed.
Yes, this guy is trying to support his theory of quantum universal consciousness theory of everything. He has to embellish on the meaning in order to claim physical consistency such a crackpot theory.
The problem with the proliferation of such crackpots is that at the edge of theoretical physics it's hard to explain to many people what is wrong with it, and even involves some things none of us yet understand. It too often allows crackpots to have their cake and eat it to.
I don't see anthing wrong with Jackson's experiment above, even though the phrasing is too cute, but the other youtube one is very confused and without specific experimental details you can't understand what he's talking about regarding the detectors.
However, he's almost certainly wrong if he's claiming conscious observation of the data caused the interference to disappear.
For a proper peer-reviewed double-slit with erasure experiment see http://grad.physics.sunysb.edu/~amarch/
This has interesting details, such as the fact that the which-way information can seemingly be obtained after the photon is detected and still destroy the interference! (Though, if you're happy with a non-local interpretation of quantum mechanics that's not too surprising, as a FTL mechanism can explain how the photon still "knows" about the which-way marker)
This is not really crackpottery, but - well - very simplifying language. He uses a very specialized meaning of tagging and watching which can lead to very misleading interpretations, but he gets the experimental results straight.
This is not really true. The information is not really obtained after detection of the first photon because all information is available only in coincidence counting, when both photons are already detected. What they do is more like a clever kind of filtering process than changing the past.
I gave a (atmittedly very simplifying) rough account of the basic physics behind DCQE (however, based on Kim's paper) in a different thread a rather long while ago, in case you are interested:
https://www.physicsforums.com/showpost.php?p=2241460&postcount=8".
The Walborn paper just introduces a different mechanism of introducing, removing and recovering indistinguishability of both possible photon paths.
Thanks for the clarification, I assumed a ftl mechanism was required, but using this coincidence counting method does seem to complicate the analysis.
Well, if you go into details, you will indeed find that one must assume some nonlocal model to explain some of the experiments performed with entangled particles (depending on your preferred interpretation this can be immediate collapse of the wave function or several different proposed mechanisms - there are enough threads in these forums discussing the different interpretations). You just do not get a possibility for ftl information transfer.
But I don't understand that why does he say that "when we leave the detector on, but don't make any measurements, that is, the magnetic head is moving, but there is no magnetic tape to record the readings of the moving head, then we see an interference/diffraction patter". Has this been proved in any experiment? The part where measurement affects the state of the system is understood, but why does he narrows down the measurement process only to consciousness, while the same effects can also be produced whenever electromagnetic waves interact with matter of any form, whether living or not.
No, it has not been proved in any experiment and it is just a plain wrong claim. Whether there is an consious observer at the end of the detection chain or not does not make any difference.
Yes, at least no classical information transfer, due to the non-deterministic selection of the quantum state.
I do wonder if a more ideal experiment with single (pairs) of photons (or other particles) could be realized, perhaps with the "which-way" particle detected over a much larger distance (so we're talking about several seconds or even minutes) than the "interference" particle so that coincidence counting wouldn't be required and perhaps a full detection screen for the interference pattern could be employed.
ie make the ftl mechanism explicit, since the "which-way" particle won't even be detected for several seconds/minutes after the "interference" particle hits the detection screen. That way you would be sure that some ftl "wave-function" mechanism was operating.
The interference seen is a genuine two-photon interference effect comparable to Hong-Ou-Mandel interference. Therefore coincidence counting is always required to see the interference pattern even if the longer distance taken by the which-way particle corresponds to minutes.
It is only the two-photon state which is coherent. The which-way arm signal is as incoherent as it gets and will therefore on its own never show any meaningful interference pattern (unless you break entanglement).
I don't understand, are you referring to the double-slit experiment I posted? The interference is created by single photons going through a double slit, the entangled partners are used to obtain which-way information only.
This is the most common misconception about DCQE experiments. It is not true that the interference pattern in DCQE experiments is caused by single photon interference and the other photon is just used for which-way information. If that was true, you would never need coincidence counting.
In fact, the light reaching the double slit is spatially incoherent. This means that its wavevector is rather undefined and by just looking at this arm you NEVER see any interference. Low coherence corresponds to a large spread in wavevectors. If you just shone light with well defined wavevector at the double slit, you would see a clear interference pattern. If you just shone light with a different well defined wavevector at the double slit, you would see a different clear interference pattern. However, as the spread in wavevectors is large, you will see a superposition of all possible interference patterns, which corresponds to no interference pattern at all. By using a small detector at one end and a large detector at the other end, you can choose some well defined wavevector at the small detector side. As you have entangled photons, the coincidence counting now acts like a filter. The entangled counterparts detected at the other side which are correlated to the ones detected at the small detector will now also be a subset with a well defined wavevector and therefore this small subset will have a well defined interference pattern. However, it is by no means possible to choose such a subset without doing coincidence counting.
In the experiment I'm referring to the coincidence counts are used just to ensure both entangled photons have passed through the apparatus.
This experiment uses single photon pairs via SPDC.
I think you're thinking of another experiment.
But correct me if I'm mistaken.
Sorry, but: no, they are not. As that page says: "It is not accurate to consider these photons as separate entities, but rather as one. They can travel very far away from each other, but they will not loose their correlation." Even if you completely removed all stray light and had no other background photon detections, you would not see an interference pattern without doing coincidence counting.
This is right, but i would change the emphasis to:
There are indistinguishable two-photon probability amplitudes leading to the same results. It is not necessary that these two photons ever meet for two-photon interference to occur.
No, I am considering the same experiment. Doing coincidence counting in such experiments is NEVER a means of just reducing the background noise due to stray light and other photons which are not part of an entangled pair.
In fact, single and two-photon interference are even complementary as has been shown in "Demonstration of the complementarity of one- and two-photon interference" by Abouraddi et al. (Phys. Rev. A 63, 063803 (2001)), also available on Arxiv.
http://www.bottomlayer.com/bottom/reality/chap2.html
Is this guy also selling crackpottery? It's another claim of a double slit experiment being done wherein the data is thrown out prior to backwall observation. (interference)
Can someone link an experiment where the no-data-before-backwall-observation experiment is actually done? Why are all these guys lying to the QM-noob's faces?
Is this the experiment your looking for?
This is their summery, open for debate-
In conclusion, we have realized a quantum eraser experiment
of the type proposed in ref. [3]. The experimental
results demonstrate the possibility of observing both
particle-like and wave-like behavior of a light quantum
via quantum mechanical entanglement. The which-path
or both-path information of a quantum can be erased or
marked by its entangled twin even after the registration
of the quantum.
Yes, a crack pot.
Too much crack and pot.
The peer-reviewed references he cites (and also the one blandrew just cited) are all valid, but this guy's interpretation of what these mean is a clear case of crackpottery.
Yeah, so?
If there was no stray light and 100% of the photons passed through the apparatus to the detectors you wouldn't need coincidence counting (duh!)
In practice some of the photons won't pass through the slits/polarisers no matter how perfect your apparatus, so you need coincidence counters in any case.
This double-slit eraser stuff can be confusing, but it's not as subtle as you're suggesting here.
It has a perfectly easy explanation in terms of non-local wave-functions without worrying about what happens at the which-way detector (which could be moved off towards infinity without changing what's happening at the interference detector)
Well you've not understood the experiment or its explanation, I don't even understand your point, coincidence counts means both photons were detected, that's all, why would you want to record a non-coincident blip?
It sells more books than real science does.
Many actually believe this. Some simply prefer to believe it. Others got it from from some sloppy wording somewhere, and never actually bothered to investigate their assumptions. Or what they did investigate was the lack of a classical explanation, rather than what observation physically entailed, and assumed that was equivalent. Evidence by the lack of evidence they weren't looking for.
At some levels it's no different from the psychic industry. People actually lose their homes as a result of being taken in by the Barnum effect. It's far bigger business than people realize.
Amit Goswami subscribes to this kind of interpretation. How does he still get work? "Amit Goswami is a theoretical nuclear physicist and member of The University of Oregon Institute for Theoretical Physics since 1968, teaching physics for 32..."
Sorry, but this is plain wrong. You need spatially coherent light to form an interference pattern. The light in one arm of the entangled beams is not coherent enough for that. Even without stray light and every photon detected at the double slit side, you would NOT see an interference pattern at the double slit side alone. If you could, you would be able to send ftl information using a quantum eraser.
If you do not believe me, read Zeilinger's famous review article:
http://www.hep.yorku.ca/menary/courses/phys2040/misc/foundations.pdf"
He also states that the pattern formed behind the double slit by one arm of the entangled beams alone will never show any interference at the beginning of section III.
If you have access to a BBO crystal, just try it out. If you increase the distance between the BBO and the double slit, you will see an interference pattern without the need to perform coincidence counting (well, if you do not have too much stray light of course) and you will not see an interference pattern in the coincidence counting data. If you decrease the distance, you will notice that the direct interference pattern vanishes and the coincidence counting pattern appears. This has also been calculated and experimentally tested in the PHD thesis of Birgit Dopfer, a former PHD student of Zeilinger. Unfortunately the thesis is in German only and has vanished from the web. If anybody still has a copy, please tell me.
Yes, but this is not the reason why you need coincidence counting.
Now you confuse me. It was your point to record a non-coincident blip in an earlier post:
Single photon interference patterns mean that you do not need coincidence counting. Two-photon interferences like in the Hong-Ou-Mandel effect always need coincidence counting. Saying the interference is created by single photons means that coincidence counting is unnecessary or used only to reduce noise. This is NOT the case here.
edit: it took me a while to find some other experimental data, but you can also have a look at post 20 in this thread:
https://www.physicsforums.com/showthread.php?t=186341&page=2"
and the paper attached there for clear experimental data that there is no interference pattern without coincidence counting.
(I lost a longer reply on my netbook, here's most of it again)
No it's not wrong. Zeilinger says (at the beginning of section III) that there is no interference if the entangled partners have path information, this is not in dispute. If the path information is erased then the interference appears. The only way to be sure the path information is erased is to have a coincidence counter tell you what happened to the entangled partner. If there is no coincindence count then we do not know what happened to the entangled partner (it might have got zapped by a cosmic omg particle for all we know) so we may or may not get coherent superposition states for the other particle through the double-slit, and so the non-coincidence blips will mess the interference pattern up (cause noise if you like)
And I don't know why you keep going on about spatially coherent light for single photons, are you suggesting a similar experiment can't be done using neutrons or buckyballs?
Here's a question for you:
1. Suppose I move the detector for the which-way particles to alpha-centuri, then run the experiment with everything else set up exacly as in a previous run which gave us an interference pattern (when matched with coincindence blips).
2. Now, if I stick my data for the interference detector blips on a floppy disk does it contain an interference distribution amongst its data or do I have to wait several years for the photons to reach alpha-centuri before the data on the floppy disk is finalised? (With the data from alpha centuri I assume I can restrospectively do a coincidence match assuming the photons traveled undisturbed at uniform speed)
(I didn't go through your mathematical analysis you linked to earlier in your first post, you may well have correctly analysed the phases or similar at the detectors but I don't see how it's relevant, the explanation for this experiment is that the wave-function is non-local)
Right.
This is the point I (and Zeilinger also) dispute. You assume the only reason for doing coincidence counting is assuring that which-way info gets dumped. I disagree. Let me introduce a simple experiment which points out the difference:
Imagine an ideal experiment. No influence of stray light, ideal photodetectors and such stuff. You again have a double-slit side and the entangled partner on the other which-way side. Now you directly dump the entangled which-way side (in a manner that does not give any which-way information) and are not interested in the exact detections. The assurance that which-way information is lost is enough. If the only sense of coincidence counting was assuring that stray light and noise is reduced and to assure that which-way information is indeed destroyed, this would mean that you should now see an interference pattern in all detections at the detections at the double slit side alone. I say this is not the case.
Now modify this experiment to the delayed choice variant again. The which-way side travels to Alpha-Centauri and the double-slit side has already been recorded. While the which-way particles are moving on, you can choose whether to take which-way information or not and therefore whether you get an interference pattern in coincidence counting or not. Again you detect all which-way particles without any losses. Assuming that ONLY nonlocality of the wavefunction causes the interference pattern to disappear and reappear would mean that in this case your choice at the which-way side alters the detections already made on the double slit side, allowing to send ftl-info. I say this is not the case and coincidence counting is needed to get additional information from the which-way side (k-space information) to pick a suitable subset of detected photons at the double slit side which will show interference.
No, that is not my point. Entangling neutrons or buckyballs should be pretty complicated. The main point of my argument is that the spatial coherence of the subset chosen by coincidence counting is significantly higher than the spatial coherence of the whole set of sdetected photons in one arm without doing coincidence counting and that it is this increase which causes the interference pattern to appear. This is, however, much easier to see in the Kim et al. quantum eraser paper.
Ok.
You will of course have to wait until you also have the data from the which-way side.
See my above example for an experiment where it makes a difference. Nonlocality ALONE is not enough.
  • #31
How do you "directly dump" the entangled which-way side? When the entangled pair leaves the source they have path information (which is equivalent to which-way information) due to momentum conservation, you must erase this information before either photon can show interference through a double-slit. If you "just dump" the which-way side by letting it hit a screen or ignoring it and letting it shoot out into empty space you will not get an interference pattern with the other photon.
You must carefully ensure path/which-way information is erased by passing the photon through some erasure mechanism, and you must check it passed through this mechanism by using a coincidence counter to match it to a partner.
You can't just talk about "dumping" the which-way side. What you really mean is if we can be sure 100% of the which way side is going through the erasure mechanism imagine we dump them afterwards (ie don't bother detecting them afterwards).
But since this 100% ideal situation can't be realized we have to employ a coincidence counter.
I'll skip the rest of the suggested experimental details since this makes it invalid.
I don't understand this, it sounds like you're suggesting that if there is no coincidence count some weird type of photon pair was emitted from the source with properties not consistent with the photons creating the interference pattern (different wavelength/frequencies, wrong directions??)
Of course you wouldn't, are you crazy! Several years later when you get the data back from alpha centuri you can do a retrospective coincidence match based on timings of detection at alpha-centuri and adding the appropriately large offset (assuming the photons traveled undisturbed and at uniform speed to alpha-centuri)
The floppy disk data isn't going to magically change when the photons hit the detectors at alpha centuri.!
The point is, that the photons traveling to alpha centuri have had their which-way information erased, so it doesn't really matter what happens to them after this, but (to repeat myself for the umpteenth time) we'd like to know which photons these had as entangled partners to extract our interference pattern from the floppy disk data (which will contain a lot of detections for photons whose entangled partner didn't make it through the erasure mechanism)Once the which-way information is erased, the photon hitting the double-slit can split into two wavelike coherent paths and interfere with itself.
The point of suggesting moving the which-way detector to alpha-centuri was to lead on to something much more non-trivial in these experiments which hasn't so far been addressed (afaik)
What if you move the erasure mechanism on the which-way path to alpha centuri?
Copenhaginists will say you still get an interference pattern (yes, with coincidence matching, sigh), but I wonder how big the delay in these delayed choice experiments can b?. Increasing the erasure delay even beyond a few seconds is not acheivable with current technology.
But this would get to the crux of just how non-local is the wave-function? (it breaks einstein locality for sure), and would (in theory) allow a refutaion of the copenhagen interpretation if favor of some non-local pilot-wave type mechanism (where the pilot wave has some bounded type of locality based on communication in higher dimensions or via some other exotic topology or via undetected tachyons etc etc)
This last part sounds speculative, of course, but the reason why "no one understands quantum mechanics" is because no one knows how the wave function enables non-local physics, and we can only speculate.The moral of this debate is that they really should teach pilot-wave interpretations in mainstream physics courses, even if the mechanism turns out to be nonsense in reality, it's hardly worse than the CI and it does enable easy analysis of delayed choice quantum experiments. :smile:
  • #32
You just have to project it into a momentum eigenstate which cannot carry any position information. See figure 3 in the Zeilinger paper which I linked earlier.
Sorry, but this is wrong. You can in principle realize a setup where all of the which-way photons are perfectly dumped at the beginning with which-way information destroyed. This does not invalidate anything.
Ok, just one question. Take incoherent light, maybe some white light source, put it directly in front of a double slit. Will you see an interference pattern? No you won't. The light is too incoherent. This is why Young had to use a pinhole in front of his famous first double-slit experiment. Do you accept this basic physics?
And for this you do not have to wait until you have the data from Alpha-Centauri? I am puzzled what you mean by this.
Exactly! But if it was only nonlocality defining whether you see an interference pattern or not, the recorded data at the floppy would have to change. It obviously does not. THIS is my argument.
You do not seem to get the point. What happens if the which-way data is not erased? You can still erase it 5 seconds before the photons reach Alpha Centauri. If you do this erasure 5 seconds before, you will be able to get the interference pattern. If you do not, you will not. In your picture the detections would have to change. In my description this is not necessary.
They can do so anyway. However without coincidence counting you get a lot of different superposed interference patterns which add up to no interference pattern at all. Only by "filtering" one of these subsets by picking coincidence counts on the other side with some well defined property (usually wave vector), you can pick one of the superposed interference patterns. Have a look at the Kim and Scully quantum eraser paper. There you have two possible paths in which position information is erased. The interference patterns you get in coincidence counting from these two possible paths are exactly out of phase and sum up to no pattern at all. How do you explain this experimental fact in your picture?
Now you are getting into crackpottery. These points have been addressed time and again. My comments and the references I quoted are exactly about this point and the references clearly show that Einstein locality/causality is NOT violated (it is nonlocal, but does not allow information transfer). See also Brian Greene's Fabric of the Cosmos, any paper by Zeilinger, Weihs or Scully for clear accounts why Einstein locality is not violated.
  • #33
For the record let's just say that we have contrary explanations of the coincidence counter's role.
  • #34
I agree.
I will think about an experiment that is capable of directly testing the different models.
  • #35
I have read this entire thread and I'm leaning towards unusualname. The DCQE which is a variant of the QE shows a much deeper interpretation of time that I won't get into.
Just sticking with the standard QE though it is not evident from the sources I have read that the coicidence counter is required in the experiments except for filtering and backup. These entangled photons come out like once every 100 pulses so they are rare enough that without the coincidence counter noise would dominate your results.
In the equations of quantum mechanics I don't know anybody (yet) who has shown that you must employ a coincidence counter.
It is true that you need one for rare single photon experiments in less than ideal light isolation conditions but if you had an ideal lab the need is not obvious.
Indeed it seems like in 1998 Weihs et al showed this. "G. Weihs, T. Jennewein, C. Simon, H. Weinfurter, A. Zeilinger, Phys. Rev. Lett. 81 5039 (1998).
I'm intrigued why though, Cthuga, you are so adamant that it is necessary. I'm not ridiculing you mind you as you sound quite well versed in QM. I am skeptical if anything like you as I have not performed the experiment myself but can only have faith that the data is correct. This is relatively cutting edge and if you have a different set of sources that point to a coincidence counter being needed I would love to read them.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
