tumor
- 126
- 1
Is it safe to drink tap water?
depends which country you're in..tumor said:Is it safe to drink tap water?
Environ. Sci. Technol., 38 (16), 4383 -4389, 2004. Copyright © 2004 American Chemical Society
Alteration of Mammalian-Cell Toxicity of Pesticides by Structural Iron(II) in Ferruginous Smectite
Kara C. Sorensen, Joseph W. Stucki,* Richard E. Warner, and Michael J. Plewa
Abstract:
The ultimate concern over pesticides in the environment is their toxic impact on nontarget organisms, including humans. Soil clays are known to interact with pesticides in ways that decrease the concentration of the parent compound in the soil solution (adsorption, sequestration, degradation). These phenomena are generally regarded as beneficial, but toxicological verification is lacking. In this study, mammalian-cell cytotoxicity of four commonly used agricultural chemicals (2,4-D, alachlor, dicamba, and oxamyl) was assessed after exposure to either reduced or oxidized ferruginous smectite (SWa-1). Results revealed that treatment with reduced smectite produced differential effects on mammalian-cell viability, depending on the pesticide. Oxamyl and alachlor reacted with reduced SWa-1 showed a significant decrease in their overall cytotoxic potential. Dicamba reacted with the reduced-clay treatment and generated products that were more toxic than the parent pesticide. Finally, no differences were observed between redox treatments for 2,4-D. The significance of these results is that oxidized smectites have virtually no influence on the toxicity of pesticides, whereas reduced-Fe smectite plays an important role in altering the cytotoxic potential of agricultural pesticides. The Fe oxidation state of clay minerals should, therefore, be taken into account in pesticide management programs.
That is the wrong article. The authors of the article referenced in the ScienceNow report are Plewa, Wagner, Richardson, Thruston, Woo and McKague. Here is the http://pubs.acs.org/cgi-bin/asap.cgi/esthag/asap/abs/es049971v.html (full-text links are at the bottom):Moonbear said:In case anyone is wondering, here is the abstract of the article referenced in the ScienceNow report.Kara C. Sorensen, Joseph W. Stucki,* Richard E. Warner, and Michael J. Plewa
My guess would be that in the small amounts they use, the chlorine-ammonia combination itself genuinely is relatively non-toxic, as the problem turned out to be with the by-products of that disinfection product.Moonbear said:I have to wonder who thought up the idea of a chlorine-ammonia combination for drinking water though...don't environmental engineers have to pass chem 101 that teaches that's a toxic combination?
It has not been published in print yet. To find the article, you have to click on the Research ASAPs tab (in the row of green tabs at the top). http://pubs3.acs.org/acs/journals/toc.page?incoden=esthag&indecade=&involume=0&inissue=0 you can see before-print research web-published daily. (This is research that has already gone through the peer-review process {the ones I saw all say "accepted on [so-and-so date]"}, so it is just as legitimate as the research that has already seen print.) Search the text of the page for Plewa, or scroll down to Aug 17.Hitssquad, did you find the article referenced in Environmental Science & Technology? I went to their site, and there is no Aug 17 issue. There is an Aug 15 issue, but I don't see anything in it by Susan Richardson.
Research is planned to obtain quantitative concentration data for these iodoacids in drinking water. In the nationwide occurrence study, these iodoacids were found only in drinking water from one location that was treated with chloramines (and whose source waters were high in bromide/iodide) (23). Interestingly, the highest levels of iodinated THMs (trihalomethanes) (dichloroiodomethane, bromochloroiodomethane, dibromoiodomethane, chlorodiiodomethane, and bromodiiodomethane) were also observed in this same drinking water at a total of 18.7 g/L (which was 81% of the concentration of the four regulated THMs-chloroform, bromoform, bromodichloromethane, and chlorodibromomethane) (23). These findings are consistent with earlier work by Bichsel and von Gunten that predicted an increased formation of iodinated DBPs in chloraminated drinking water, based on the very slow rate of iodide oxidation to iodate by chloramines, which allows hypoiodous acid (HOI) to ac cumulate and react with natural organic matter to form iodinated DBPs (36, 37). Thus, it is likely that the highest levels of iodoacids (and other iodo-DBPs) will not be in chlorinated drinking waters but in chloraminated drinking waters. This is in stark contrast to the effect chloramine disinfection has on the formation of the regulated chloro/bromo-THMs and haloacetic acids, where chloramination significantly reduces their levels compared to chlorination. As a result, chloraminated drinking waters that have high bromide and iodide source waters will be targeted for this future quantitative occurrence work to determine whether the iodoacids commonly occur in high-iodide, chloraminated drinking waters and at what levels they are present. Ultimately, it will be important to know the levels at which these iodoacids occur in order to assess the potential for adverse environmental and human health risks. It should be noted that the iodoacids identified in this study were from a plant using chloramines only. For plants that have a significant free chlorine contact time before the addition of ammonia (to form chloramines), iodo-DBP formation may not be a problem.
tumor said:So guys, can I drink water from the tap in Toronto or not?You confusing me a lot with your reports and scientific stuff!
Moonbear said:It might depend on the source of your tap water. If it's municipally supplied, it should be fine.
Moonbear said:Bottled water has to be purified too, but I don't know what methods various companies use.
Phobos said:A good point. The laws are strict toward public-supplies, but I'm not aware of any for bottled water companies (treated like a food product perhaps?). But I know those companies do some degree of testing. My guess would be that any physical/chemical treatment is some type of straightforward filtering and there may be no biological disinfection. I'd have to research it (and I suspect that such companies keep that information close whereas municipalities are required by law to make their test results available to the public).
Phobos said:Correct - - the larger the municipality, the stricter the requirements on the drinking water quality...not because city-folk are more important, but because a 1 in 100,000 risk (or whatever) is more significant in a city of millions than it is in a small town of a few thousand.
However, sometimes cities usually have less-clean source waters than small towns so they have to use more disinfection chemicals, which means more DBPs.
Moonbear said:From what I've found, it seems the FDA regulates bottled water as a packaged food product, unless it's sterile water, in which case it gets regulated as a pharmaceutical (probably because most uses of sterile water would be in hospital settings).
A few bottled water companies outline their purification processes. Some start with municipal water and others spring water. It seems most go through a few reverse osmosis filtration steps, one I found had a final ozone treatment step. I think the main thing is they filter out things like the chlorine in tap water to improve taste.
Since they bottle it instead of sending it through long distances of pipelines, they don't need to leave any residual chlorine to keep it disinfected on the way to someone's home.
Moonbear said:Regarding the source waters and DBPs, the gist of what I got out of those articles I read yesterday is that a particular purification method doesn't always produce the same DBPs, it depends on what's in the source water. So, these studies on DBPs seemed to have identified something at two plants that is unique to their source water and purification method. It seems the results of these studies could be used then to improve water treatment processes to be more tailored to the composition of the source water to reduce DBPs.
What sizes are these DBPs?
Would additional filtration steps remove them?
For example, would one of those charcoal filters people put on their sink faucets do anything to remove them?
What about the reverse osmosis filtration used by bottled water companies?
Since some of these DBPs are only just being identified and standards are still be developed by EPA labs, bottled water companies probably aren't able to test for them any more than municipal supplies can.
Of course, if one spends too much time reading that Environmental Science Technologies journal, you'd be afraid to eat or drink anything. It's all a matter of putting it into reasonable perspective and realizing these studies are meant to help continue improving our water supply, not send us scurrying for bottled water. As Phobos pointed out, the health risk from pathogen contamination is of far greater and immediate concern than the much smaller risk from DBPs, so it's all a trade-off.
Phobos, are there processes being developed that would remove the contaminants that are converted into DBPs prior to chlorination (or any other method of disinfection)? Or at least removing some of the major culprits to reduce their overall levels?
Dasani (coke-cola) water in the UK was just bottled tap water.A few bottled water companies outline their purification processes. Some start with municipal water and others spring water.
Andy Resnick said:NO! Water is poisonous! and can dissolve anything!
http://www.hsegroup.com/hse/text/water.htm
I prefer beer.
Yes, tap water is safe to drink in most developed countries. It is regulated by the Environmental Protection Agency (EPA) and must meet strict quality standards.
Tap water is treated with chemicals such as chlorine to kill harmful bacteria and viruses. It also goes through a filtration process to remove impurities.
In some cases, tap water may contain trace amounts of contaminants, such as lead or pesticides. However, these levels are typically very low and do not pose a significant health risk.
In most cases, tap water is just as safe as bottled water. In fact, some bottled water is simply tap water that has been filtered and bottled. However, it is important to check the source and quality of bottled water before purchasing.
You can check the Consumer Confidence Report (CCR) provided by your local water utility to see the quality of your tap water. You can also install a water filtration system in your home for added peace of mind.
