blenx
- 30
Is position not an observable of a photon?
blenx said:Is position not an observable of a photon?
unusualname said:No, but you can detect the position of its interaction with another particle, the interaction destroys the photon.
blenx said:Here I have a question:
Suppose I emit a light pulse whose length is very short, so we can consider the pulse contains only a few phtons, for example 2 photons.
If this 2-photon pulse interact with an atom at point(x,t) and one phton is destroyed, can we say that the position of another photon at time t is x?
unusualname said:No, you can only say that one photon interacted with an atom at position x at time t
unusualname said:A photon has no rest frame wrt which you could specify its position.
blenx said:Thanks for your answer. But can you tell me why I can't talk about the position of another photon?
The Newton-Wigner position operator is not the only way to construct a position operator in relativistic quantum physics.Fredrik said:It isn't. For massive particles in relativistic quantum field theories, you can construct a position operator called the Newton-Wigner position operator, but this doesn't work for massless particles. (I'm sure there's a good reason why you can't define a position operator for massless particles, but I don't know it).
Andrey said:Well you can talk about the position of another proton; actually you can talk about the position of all protons. Except the fact that you would have to be outside the space-time continuum to do that. It's like a 2D and a 3D plane. The 2D plane doesn't know that 3D plane exist and the 2D plane cannot see all the interactions of 2D plane because it is within the 2D plane itself. It is interacting with 2D plane, it within 2D plane so it's ability to see mupliple positioning of proton becomes limited, in fact imposible. In 3D plane, however, we can see the interactions of protons in a 2D plane. We can see them all. Why because we are no longer percieving reality from a 2D plane. However, not that we steped into 3D plane, we cannot see all the posibilities of 3D plane until we move into 4D plane and so on. think of it like a Russian doll!
Demystifier said:The Newton-Wigner position operator is not the only way to construct a position operator in relativistic quantum physics.
For example, the spatial part of the spacetime position operator inblenx said:Can you show us some examples of other position operators?
I think neither of these arguments is a good argument against position operator of a photon. Let me explain.kexue said:One good reason is that photons are masseless and move at the speed of light and have no rest frame! Then also they are bosons, so you can't tell which are which.
Also, the position operator is a very fishy concept in relativistic quantum physics, since at Compton wave-length there are no single particles anymore, but particles pop in and out of existence. Relativistic quantum physics is a multiparticle theory, that's why the position operator is completely abandoned and instead becomes a parameter to a quantum field. (At least thta's the story in all the standard textbooks and lecture notes.)
Demystifier said:Relativistic quantum mechanics (Bjorken and Drell I) can be well interpreted as a single particle theory, or a theory with a fixed number of particles. It is INTERACTIONS, not relativity, which causes physical particle creation and destruction.
This is simply wrong. A one-photon state is a well defined state in the Hilbert space of relativistic quantum field theory. Even if the number of photons change due to interactions, that only means that the state is a superposition of states with different numbers of particles. But each term in the superposition is well defined (otherwise the superposition itself would not make sense), which means that the states with definite number of particle are well defined.Fwiffo said:and in relativistic quantum (field) theory there is no concept of single photons.
As I already mentioned in a previous post, there are also other definitions of the position operator.Fwiffo said:Other problems are that attempts at a wigner like position operator ...
A 1-photon quantum state is NOT an eigenstate of the operator of electromagnetic field. That means that electromagnetic field is not well defined for a 1-photon state, but it does not mean that the position of such photon is not well defined. Indeed, there exists a 1-photon wave function which is well localized in space at a given time.Fwiffo said:Another approach gives a well localized electric field if the magnetic field is non localized and vice versa. Remember that a photon is an electromagnetic wave.
Demystifier said:Indeed, there exists a 1-photon wave function which is well localized in space at a given time.
Maybe it is not canonical (whatever that means), but there is a way to introduce a position operator that does not depend on interactions. After all, in the Schrodinger picture of quantum theory the operator is something that can be defined BEFORE specifying interactions.Fwiffo said:Regardless of interactions there is no position operator for photons. True localization is less of a problem for free photons, but the operator ( d/dp for example) does not work. Other choises can be constructed for spinless (massless) relativistic particles but a photon position operator is still a problem. The problem is however much reduced in the case of no interactions where some kinds of position operators can be defined (such as the one Hawton uses) . There is as far as I know no cannonical photon position operator.
Demystifier said:Maybe it is not canonical (whatever that means), but there is a way to introduce a position operator that does not depend on interactions. After all, in the Schrodinger picture of quantum theory the operator is something that can be defined BEFORE specifying interactions.
The Appendix ofFwiffo said:Where can I find this?
Demystifier said:The Appendix of
http://xxx.lanl.gov/abs/0804.4564
explains how to calculate the wave function for any relativistic 1-particle state. By choosing an appropriate function c(q), you can obtain any function of space at a fixed time you want, including a delta function. Equations are written for a mass m, but there is no problem to put m=0 in the equations. Equations are written for a spinless particle, but it is not a problem to include the spin as well.
But it is simple. Essentially, all you have to do is to add an additional index to quantities such as a, c and psi. This means that the wave function has a few components, but it can still be localized in the sense that each independent component can be localized. In fact, it should not be surprising, because one usually says that it is relativity or masslessness that causes problems, not the spin.Fwiffo said:Like you said this works for spinless particles. I don't think including spin in this wavefunction is as simple as you make it out to be.
Demystifier said:But it is simple. Essentially, all you have to do is to add an additional index to quantities such as a, c and psi. This means that the wave function has a few components, but it can still be localized in the sense that each independent component can be localized. In fact, it should not be surprising, because one usually says that it is relativity or masslessness that causes problems, not the spin.
In principle yes, but efficiency of such a detector would be ridiculously small. Namely, for such a detector you need an interaction Lagrangian quadratic in photon field, which you can obtain in effective action associated with higher-order Feynman diagrams in QED.unusualname said:Is there any way to measure a photon's position without destroying it?
Let me just say that a similarity between my name and the title of this article is not a coincidence.unusualname said:btw, http://xxx.lanl.gov/abs/quant-ph/0609163 is an excellent review article on QM in general (I believe Demystifier is the author)
Fwiffo said:…… Remember that a photon is an electromagnetic wave.
Fwiffo said:This is your basic wave/particle duality. The photon has wave like properties, these properties obey the maxwell equations (i.e the equations for electromagnetic waves). However it is quantized (a particle property) so two photons cannot interfere with each other in the same way two electromagnatic waves can, this is (i'm not being precise here) the photoelectric effect.
This is true for any particle but the equations are different, electrons follow the schrodinger (or dirac) equations etc...
Confusing? I know!
