Please help me understand a set theory proof.
In the proof that B cannot be in f(x), we assume that there is some y such that y is an element of B and f(y) is B. This is possible because f is onto.But then we show that no matter what y is, it can't be in B. Since we assumed that y was in B, we have a contradiction.
╔(σ_σ)╝
839
Let A be a set and let P(A) denote the set of all subsets of A. Prove that A and P(A) do not have the same cardinality
NOne
The authors proof is as follows:
Suppose there is a bijection f:A -> P(A). Let B= {x[tex]\in[/tex] A| x [tex]\notin[/tex] f(x)}. There is a y [tex]\in[/tex] A such that f(y)= B, since f is onto. If y [tex]\in[/tex] B, then by definition of B we conclude that y[tex]\notin[/tex] B. Similarly, if y [tex]\notin[/tex] B, then we conclude y [tex]\in[/tex] B. In either case we get a contraditon, therefore, no such function exist.This proof probably make a lot of sense but I can't understand it. Why define a set B that only consist of elements of A but is not elements of f(x)? Isn't f(x) supposed to be all subsets of x, which means f(x) contains x and the subsets of x? How can the set B even exist ? I'm completely lost.
Am not sure why the author provides the proof he does and I am having a hard time understanding it. But if I were to attempt it I would have given a counterexample. I know that cardinality is another word for number of elements when we are talking about finte sets.
If i formed a set A= { 1,2} I know that P(A) has subsets [tex]\oslash[/tex],{1},{2},{1,2}
Clearly they do not have the same cardinality. I am not sure if this is enough to prove the proposed statement partly because I didn't even talk about infinite sets. What do you guys think ?
No.
Since f is a function from A to P(A), f(x) must be an element of P(A). Equivalently, f(x) is a subset of A.
A priori, f(x) has no interesting properties whatsoever; it's just the result of a function applied to a value.
Hurkyl said:
No.
Okay, thanks for the clearification. But I still have a problem understading f(x). I believe it is an element of P(A) but what is its "value" ?
Suppose I have A= {1,2}
1 is an elements of A
f(1) = ? what does this even mean ?
Something about this is unsettling to me. From what I understand f is a mapping of a set to another set; why should it even work on elements of a set and not on sets themselves?
f( {1}) = {[tex]\oslash[/tex], {1}} , would make sense to me .
Can you explain a bit more, please ?
Well, there is no explicit definition given for the function, f, so it would be impossible to tell you any value. All you know is that f is a bijection, which is surjective (onto) and injective (one-to-one), and its domain and co-domain.
f is some bijection from A to P(A). i.e., for each element [tex]a \in A, [/tex] we have the element [tex] f(a) \in P(A). [/tex].
There's no one correct answer, because the mapping f has not been fully defined. Right now, we're just supposing there is SOME bijection f. But if it would make things clearer to you, consider the following mapping:
[tex] f: x \mapsto \left\{ x \right\} [/tex]
So [tex] f(1) = \left\{ 1 \right\} [/tex] and [tex] f(2) = \left\{ 2 \right\}. [/tex]
EDIT#2: I was right the first time:
No, that does not make sense. The domain of f is the elements of A and the range of f is the elements of P(A). The type of elements of A is different than the type of elements of P(A). Do you understand?
Okay if that is the case in the proof the author says :
My problem is I don't understand what's going on with the set B.
The elements of B are elements of A but are not elements of f(x). What does an element of f(x) even look like ?
╔(σ_σ)╝ said:
Okay if that is the case in the proof the author says : My problem is I don't understand what's going on with the set B.
f(x) takes an element from A and does SOMETHING to make into an element of P(A). Elements of P(A) are all subsets of A, so it looks like a subset of A.
EDIT: And, the elements of B are not elements of A. It takes its input from each member of A.
[tex] f: x \rightleftharpoons \left\{ x \right\} [/tex]
I understand this.
[/QUOTE]
I understand there is a difference, ofcourse there is. I mean A has elements like 1,2 etc but P(A) has sets as elements.
Like I said, the range of f is P(A). P(A) is the set of SUBSETS of A, i.e., the elements of P(A) are sets themselves. Thus, the elements of f(x) are sets themselves.
e.g., Let A = {1 , 2}. Then P(A) = { {}, {1}, {2}, {1, 2} }.
The point is that [tex] B \subseteq A [/tex]. Thus, we have by definition: [tex] B \in P(A). [/tex] This guarantees us a y such that f(y) = B.
No, f(x) is simply some subset of A. It doesn't have to contain x. The point is that there aren't "enough" x in order for us to "count" all the subsets of A.
If we assume that f is a bijection, then B cannot exist. This is exactly why we have a contradiction, i.e., we realize f cannot be a bijection.
Great, that makes sense!
So B= {x[tex]\in[/tex] A| x [tex]\notin[/tex] f(x)} has elements of A but x is not an element of f(x).
What does this mean ? Does this mean we get x from A but x is not in P(A) ? This make sense the elements are of different types.
Nice, this makes sense.
So basically f since f is onto we have f(y) = B if y is an element of A. I got the contradiction part of the argument but I don't see the point that "there aren't "enough" x in order for us to "count" all the subsets of A."
Basically B does not exist.
It means that for all x such that x is a member of A, you take the elements not in f(x).
EDIT: Actually, is that a typo? x can't be a member of A and not a member of f(x) because the set's elements are completely different.
Okay I just tried to piece eveything together and I think I understand now. By following the assumption that f is a bijection and the definition of B we get that B[tex]\subset[/tex] A
and B [tex]\in[/tex] P(A). Therefore, since f(y) = B, if y [tex]\in[/tex] B then y [tex]\in[/tex] f(y) which is a contradiction . Therefore, B does not exist if f is a bijection. So our assumption must be wrong.
FAQ: Please help me understand a set theory proof.
What is a set theory proof?
A set theory proof is a formal argument that uses the principles and rules of set theory to demonstrate the truth of a given statement or proposition.
Why is understanding set theory proofs important?
Understanding set theory proofs is important because set theory is a fundamental branch of mathematics that is used in many other areas, such as geometry, algebra, and logic. It also helps develop critical thinking skills and the ability to construct logical arguments.
How do I approach understanding a set theory proof?
The best way to approach understanding a set theory proof is to start by familiarizing yourself with the basic concepts and notation of set theory. Then, carefully read through the proof step by step, making sure to understand each statement and how it follows from the previous ones.
What are some common strategies for solving set theory proofs?
Some common strategies for solving set theory proofs include using definitions and properties of sets, logical reasoning, and proof techniques such as direct proof, proof by contradiction, and proof by induction.
What resources can I use to help me understand set theory proofs?
There are many resources available to help you understand set theory proofs, including textbooks, online tutorials, and practice problems. You can also seek help from a math tutor or join a study group to discuss and solve proofs together.
