Is Force Ever a Function of Acceleration in Classical Mechanics?
In classical mechanics, forces are typically not expressed as direct functions of acceleration due to dimensional inconsistencies. The discussion highlights that while acceleration may change over time, forces generally depend on position, velocity, and time rather than acceleration alone. A specific example mentioned involves a string attached to a ball, where the force exerted by the ball on the string can be related to its acceleration. However, the consensus is that force is not commonly measured or plotted against acceleration in standard practice. Overall, the professor's assertion emphasizes the conventional approach to analyzing forces in dynamics.
GreenLRan
In class today, my professor said that you will never find a force that is a function of acceleration.
Why is this?
M\ddot{x}(t) = F(x,y,z,\dot{x},\dot{y},\dot{z},t)
M\ddot{y}(t) = F(x,y,z,\dot{x},\dot{y},\dot{z},t)
M\ddot{z}(t) = F(x,y,z,\dot{x},\dot{y},\dot{z},t)
This is in a classical mechanics / dynamics course
Usually forces vary with time, because acceleration would vary with time. I think he meant that you would not find a function such that F=2a2+a+3 as that would not work dimensionally.
What about a reaction force? For example a string attached to a ball and accelerating the ball, the force the ball exerts on the string is a function of the acceleration of the ball.
Well that is what I am saying, I think your professor meant that you would not usually measure force with acceleration or well plot force against acceleration.
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
