Some results from the Hubble Ultra-deep field
In summary, the Hubble Ultra Deep Field provides astronomers with valuable information about the early galaxies in the universe. However, the data does not allow for a clear conclusion about whether or not early galaxies were sufficient to cause reionization.
Nereid
Staff Emeritus
Hubble Approaches the Final Frontier: The Dawn of Galaxies, a PR earlier today, includes some interesting results, as well as a good insight into how five different teams analysed the data in different ways to arrive at more or less the same, or mutually re-inforcing, conclusions.
From this PR: "Astronomers are now debating whether the hottest stars in these early galaxies may have provided enough radiation to "lift a curtain" of cold, primordial hydrogen that cooled after the big bang. This is a problem that has perplexed astronomers over the past decade, and NASA's Hubble Space Telescope has at last glimpsed what could be the "end of the opening act" of galaxy formation. These faint sources illustrate how astronomers can begin to explore when the first galaxies formed and what their properties might be.
But even though Hubble has looked 95 percent of the way back to the beginning of time, astronomers agree that's not far enough. "For the first time, we at last have real data to address this final frontier — but we need more observations. We must push even deeper into the universe, unveiling what happened during the initial 5 percent of the remaining distance back to the big bang," said Richard Ellis of the California Institute of Technology in Pasadena, Calif.
Astronomy news on Phys.org
Wow, stars with reshift z=20. I'm dying to see them
I just scanned that PR and arrived at an understanding that is a "bit" less monolithinc than your description.
One team said the early galaxies seen are insufficient to cause reionization.
One teams said that the galaxies see are sufficient to cause reionisation.
One team looked at the data, then came up with an "estimate" of how many galaxies are in the field, but can't be seen, and invoking the existence of the unseen galaxies, they then stated that the early galaxies were sufficient to cause reionization.
The other two teams said that the presence of the early galaxies likely had an effect on ionization, and one of those teams comes to the conclusion that reionization happened at different rates and different times, based on the concentration of mass in each region. What effect would this have on the homogeneity of the universe? Interesting question.
We'll let PF readers decide for themselves, shall we?
"The Bunker team identified a list of 50 probable distant galaxies in the Ultra Deep Field [...] Bunker's team claims that the combined ultraviolet light from the galaxies located in the Ultra Deep Field is insufficient to reionize the universe. Perhaps the physics of star formation was different at these early times, or a further, yet more distant population is responsible."
"The Stiavelli team shows that the same objects would be sufficient to reionize the universe, if they possessed much fewer heavier elements — anything heavier than helium — than those of present-day galaxies, and if the early galaxies contained more massive stars. Both these assumptions are reasonable at early epochs, since astronomers know that stars make the metals that exist in the universe. Early on, before most of the stars we see today had been formed, the amount of elements must have been much lower." (my emphasis). That more distant objects (and older ones, locally) have lower metallicities is well established; the specifics for 'ordinary' galaxies at z >= 5 are poorly constrained.
"The Yan and Windhorst team started from the objects that are seen, and then carefully estimated the fraction of fainter galaxies that are not seen, even in the Hubble Ultra Deep Field. They found that the number of dwarf galaxies rapidly increases at fainter levels in the HUDF. [...] Yan and Windhorst conclude that this steep increase of the faint dwarf galaxy population collectively generates enough ultraviolet light to finish reionizing the universe by redshift 6, even if the amount of heavier elements was similar to that of present-day galaxies." (my emphasis)
"The HUDF NICMOS Treasury team (Thompson/Illingworth) has taken the UDF data and other ACS survey data to get the best possible estimate of the relative numbers of bright and faint galaxies around redshift 6, only 900 million years after the big bang. The papers, led by Rychard Bouwens, show that faint galaxies dominate at this epoch, compared to more recent times, and are likely to have played a significant role in the late stages of reionization. The team has also used the HUDF NICMOS data to detect a small sample of galaxies at higher redshifts (at z=7-8), 200 million years closer in time to the big bang. The amount of reionizing light at redshifts 7-8 appears to be lower than what is seen only 200 million years later at redshift 6."
"The Malhotra and Rhoads team have found a "sheet" of galaxies in the HUDF. They find that the galaxy density near redshift z=5.9 (look-back time of 12.5 billion years) is four times the galaxy density in the rest of the surveyed HUDF "core sample." This supports theories of galaxy formation which predict that dense regions should be the first sites of galaxy formation. This evidence for an over density was bolstered by a complementary study, undertaken by Malhotra, Rhoads, and JunXian Wang, which uses the Cerro Tololo Inter-American Observatory to obtain a map of galaxies over a much wider area than the HUDF. Even with its lower sensitivity and more limited coverage in distance, this map shows that "extra" galaxies are spread like a sheet, with the HUDF located near one edge of the structure. "The presence of such structures doubtlessly affected the reionization of the universe, because the ultraviolet light that separated intergalactic hydrogen atoms into protons and electrons would have been more intense where galaxies are more common. It is then likely that reionization proceeded at different speeds in different regions of the early universe," says Rhoads."
In the concordance model, just such inhomogeneity is predicted. You will find lots of papers showing that the inhomogeneity expected from analysis of WMAP data is consistent with that found in both 2dF surveys (galaxies and quasars) and with the first two SDSS data releases (both galaxies and quasars?).
Oh, and the Hubble PR also has links to eight papers which discuss the various teams' findings in much more detail; my scanning of those eight papers leads me to an understanding that is consistent with my statement that 'five different teams analysed the data in different ways to arrive at more or less the same, or mutually re-inforcing, conclusions.'
Thank you Neried for such a clear resume of those papers. One question - Had there been enough time for this structure to form?
Garth
Sky and Telescope also has http://skyandtelescope.com/news/article_1356_1.asp on these findings. There's a quote in this that you may find interesting: " Despite the lack of consensus on whether these dwarf galaxies alone could reionize the universe, independent commentator Richard Ellis (Caltech) pointed to the remarkable agreement on what has been seen. Theorists, Ellis noted, have speculated about this era of cosmic dawn for decades. "We're moving out of era of theory into an era of observation," he said. "This is a milestone. The sequence of deep fields from Hubble and other telescopes have changed the way we do astronomy. We have many unsolved issues, but we have a clear path forward." "
This will certainly be a question to which much effort will be devoted! As several PF posters have noted, the details of how stars and galaxies formed, between z ~1000 (the surface of last scattering) and z = 5 or 6, are important parts of any cosmological model and observations in this regime should provide strong constraints on the models.
What sort of progress on this question do PF members think will be made before the JWST?
I have not crunched the numbers, however a gut feeling is that one problem will be the need for high density i.e. Dark Matter to assist quick gravitational collapse in a relatively hot and therefore relatively high pressure environment on the one hand and the counter effect of the 'anti-gravity' of Dark Energy on the other. It may be that Dark Energy has to be switched on and off as required to make the model work, which will be difficult to explain
- Garth
Related to Some results from the Hubble Ultra-deep field
1. What is the Hubble Ultra-deep field?
The Hubble Ultra-deep field is an image captured by the Hubble Space Telescope of a small patch of space in the constellation Fornax. It is one of the deepest and most detailed views of the universe ever taken, containing over 10,000 galaxies at various distances and ages.
2. How was the Hubble Ultra-deep field created?
The Hubble Ultra-deep field was created by combining hundreds of images taken by the Hubble Space Telescope over the course of 10 days. The telescope's sensitive camera captured faint light from distant galaxies, allowing scientists to study the evolution of the universe over billions of years.
3. What are the major results from the Hubble Ultra-deep field?
The Hubble Ultra-deep field has provided scientists with a wealth of information about the early universe. Some of the major results include the discovery of galaxies at extremely high redshifts (meaning they are very far away and therefore very old), the confirmation of the existence of dark matter, and the ability to study the formation and evolution of galaxies over time.
4. How does the Hubble Ultra-deep field contribute to our understanding of the universe?
The Hubble Ultra-deep field has greatly contributed to our understanding of the universe by providing scientists with a detailed look at the early stages of galaxy formation and evolution. It has also helped to confirm theories about the existence of dark matter and the expansion of the universe.
5. What are the future plans for the Hubble Ultra-deep field?
The Hubble Ultra-deep field has already been revisited and expanded upon several times, with plans for future observations as well. In the future, the James Webb Space Telescope, set to launch in 2021, will also be able to study the Hubble Ultra-deep field in even greater detail, providing further insights into the origins and evolution of the universe.
  • Astronomy and Astrophysics
15K
12K
  • Cosmology
