Weak Electron Interaction: Virtual Photon Effects?
In summary, the conversation discusses the concept of virtual photons and whether the number of virtual photons exchanged between two electrons changes depending on their distance. It is mentioned that virtual photons are unphysical and are just terms in a perturbation expansion. The intensity of interactions and force are also discussed in relation to virtual photons. The conversation then shifts to discussing the use of Coulomb gauge in QED and the article "Quantum Mechanics of Gauge Fixing" is referenced as a source.
scope
61
hi, let's suppose 2 electrons are far away each other and therefore they interact very weakly. i wonder if in such case there are as many virtual photons in the case they are very close to each other? because i know that only 1 electron in complete vacuum generates an electromagnetic field and therefore virtual photons . please reply!
The most important thing to grasp is that virtual photons are unphysical.
They're essentially just terms in a perturbation expansion.
You might as well ask whether, when two combatants glare at each other,
are there more virtual daggers flying between their eyes when they're close
together than when they're far apart?
It's all a bit silly, really.
hi, i do know that they are not physical, but it seems to me logical that further interactions means further virtual photons. if there are more virtual photons that are exchanged and all the rest remains the same, then there are more virtual photons.
the question is whether the intensity(or number) of virtual photons is measured by the field (not really the interactions) or the force(the intensity of interactions)?
It seems to me that every electromagnetic interaction involves an infinite number of virtual photons. To calculate the amplitude for any interaction exactly, we have to sum up an infinite number of terms in the perturbation expansion, each of which has its own Feynman diagram. Higher-order Feynman diagrams include more and more virtual photons.
One can formulate QED in Coulomb gauge which contains the Coulomb potential w/o any sumation over radiative corrections. One has to use the appropriate gauge for this problem.
It is a common misconception (which I see quite often here in the PF) that QED does contain only perturbative photons. This is not correct in general.
In which book is that done?
Please refer to the following article:
Lenz F., Naus H. W. L., Ohta K. and Thies M.
Annals of Physics
Volume 233, Issue 1, July 1994, Pages 17-50
Abstract:
In the framework of the canonical Weyl gauge formulation of QED, the quantum mechanics of gauge fixing is discussed. Redundant quantum mechanical variables are eliminated by means of unitary transformations and Gauss′s law. This results in representations of the Weyl-gauge Hamiltonian which contain only unconstrained variables. As a remnant of the original local gauge invariance global residual symmetries may persist. In order to identify these and to handle infrared problems and related "Gribov ambiguities," it is essential to compactify the configuration space. Coulomb, axial, and light-cone representation of QED are derived. The naive light-cone approach is put into perspective. Finally, the Abelian Higgs model is studied; the unitary gauge representation of this model is derived and implications concerning the symmetry of the Higgs phase are discussed.
FAQ: Weak Electron Interaction: Virtual Photon Effects?
What is weak electron interaction?
Weak electron interaction is a fundamental force of nature that describes the way subatomic particles, specifically electrons, interact with each other through the exchange of virtual photons. It is one of the four fundamental forces, along with gravity, electromagnetism, and strong nuclear force.
What are virtual photons?
Virtual photons are particles that are exchanged between subatomic particles during weak electron interaction. They are considered "virtual" because they cannot be observed directly, but their effects can be measured and observed in experiments.
How do virtual photons affect weak electron interaction?
Virtual photons play a crucial role in weak electron interaction by mediating the force between subatomic particles. They are responsible for the attraction or repulsion between particles, similar to how real photons mediate the electromagnetic force between charged particles.
What are some examples of weak electron interaction in everyday life?
Weak electron interaction is responsible for processes such as beta decay, which is the radioactive decay of atomic nuclei. It also plays a role in nuclear fusion reactions that power the sun and other stars. In everyday life, weak electron interaction is not directly observable, but it is essential for understanding the behavior of matter at a subatomic level.
How is weak electron interaction studied?
Weak electron interaction is studied through experiments using particle accelerators, where high-energy collisions can produce the conditions necessary to observe the effects of virtual photons and other subatomic particles. Theoretical models and calculations are also used to understand and predict the behavior of weak electron interaction.
