Is there a connection between covariance, invariance, and dark matter?
In summary, Covariance and Invariance are two concepts that are related but do not always have the same effects. Covariance implies invariance of all scalar quantities, but invariance does not always imply covariance. Christoffel symbols are covariant, but their covariance is of second order not first order. Building invariants from first order objects is easy, but building invariants from second order objects is less trivial.
Anamitra
621
We consider the equation:
[tex]{\frac {{d}^{2} {x^{\alpha}}}{{d }{{\tau}^{2}}}}{=}{-}{{\Gamma}^{\alpha}}_{\beta\gamma}{\frac{{d}{x^{\beta}}}{{d}{\tau}}}{\frac{{d}{x^{\gamma}}}{{d}{\tau}}}[/tex]
The covariant form is preserved in all coordinate systems. But the Christoffel symbols may work out to produce different functions in different coordinate systems.So covariance does not guarantee invariance,except in the inertial frames.[The Christoffel symbols work out to zero value in the inertial frames]
Query: Does covariance imply invariance?
Covariance implies invariance of all scalar quantities. Covariance does not imply invariance of the components of a tensor of higher rank in an arbitrary basis.
Covariant in this context means "transforms in a particular way (under a coordinate transformation)". If something is invariant it means "does not transform (under a coordinate transformation)". Invariance is a special type of covariance.
In your example you are considering the components of a vector equation. These would be covariant. The components of a tensor are all covariant -- they transform in a "particular way" when you a perform a coordinate transformation. The components of the Christoffel symbols are not covariant.
But the literature can be sloppy when it comes to this. So don't be suprised when something is called invariant when it really should be covariant.
Christoffel symbols are perfectly covariant, though its covariance is of second order and not of first order as it is with vectors and tensors. Building invariants from first order objects is easy. Building invariants from second order objects is less trivial. But it is all just algebra, nothing more.
Would it be appropriate to make the following assertion?
Covariance of the physical laws relates to the invariance of the corresponding tensor equations, notwithstanding the fact that the differential equations coming out of such formulation are not invariant wrt to coordinate transformation.
I am making this assertion in view of the preceding threads as well as the following links:
1) https://www.physicsforums.com/showpost.php?p=3003113&postcount=50
2)https://www.physicsforums.com/showpost.php?p=2999911&postcount=48
Maxwell's Equations,I mean the differential equations, may change their form on coordinate transformation[in view of the previous thread].In such a case it would be very difficult,if not impossible to churn out the wave equation as we know it.This may apply to some erratic matter distribution in the galaxies where the metric coefficients have complicated functional forms. Can this be traced to the cause behind dark matter?
[This is a speculation and not a claim]
FAQ: Is there a connection between covariance, invariance, and dark matter?
What is covariance and invariance?
Covariance and invariance are two concepts in statistics and mathematics that describe the relationship between two variables. Covariance measures how two variables change together, while invariance refers to the property that a mathematical or statistical operation does not change the relationship between two variables.
How is covariance calculated?
Covariance is calculated by taking the product of the differences between each data point and the mean for two variables, and then dividing by the total number of data points.
What is the significance of covariance and invariance?
Covariance and invariance are important concepts in data analysis and modeling. They help us understand the relationship between variables and make predictions based on that relationship. Invariance also allows us to perform mathematical operations without changing the meaning or validity of the data.
Can covariance and invariance be negative?
Yes, covariance can be positive, negative, or zero. A positive covariance means that the variables move in the same direction, while a negative covariance means they move in opposite directions. Invariance, on the other hand, is always positive as it measures the consistency of the relationship between variables.
How are covariance and invariance used in scientific research?
Covariance and invariance are commonly used in statistical analyses, such as regression and correlation, to understand the relationship between variables. They are also used in experimental design to control for variables that can affect the outcome of a study. Additionally, these concepts are important in fields such as physics and engineering to describe and predict the behavior of systems and processes.
