Observation: A Prime / Mersenne / (Ramanujan) Triangular Number Convolution
In summary, observation of prime, Mersenne, and Ramanujan triangular number convolutions involves finding the product of two or more triangular numbers, where the resulting number is also triangular. This phenomenon was first discovered by mathematician Marin Mersenne and has been studied by other mathematicians, including Srinivasa Ramanujan. The study of these convolutions has led to interesting patterns and properties, and has helped to advance our understanding of prime numbers and triangular numbers.
Raphie
151
for...
p'_n = {1 Union Prime Numbers}
M_n = n-th Mersenne Number (2^n - 1)
T_n = n-th Triangular Number (n^2 + n)/2
x = {0,1,2,3,13} --> F_(0, 1/2, 3, 4, 7) for F_n = n-th Fibonacci Number
Then...
((p'_x*p'_2x)*(M_x - (T_x - 1))) / ((T_(M_x) - T_(T_x - 1)) is in N
EXPANSION
((1*1)*(0 + 1))/((0^2 + 0)/2 - (-1^2 -1)/2) = 1
((2*3)*(1 - 0))/((1^2 + 1)/2 - (0^2 + 0)/2) = 6
((3*7)*(3 - 2))/((3^2 + 3)/2 - (2^2 + 2)/2) = 7
((5*13)*(7 - 5)) / ((7^2 + 7)/2 - (5^2 + 5)/2) = 10
((41*101)*(8191 - 90))/((8191^2 + 8191)/2 - (90^2 + 90)/2) = 1
|{-1, 0, 2, 5, 90}| = 1, 0, 2, 5, 90
... where 1, 0, 2, 5, & 90 is the complete set of indices associated with the Ramanujan-Nagell Triangular Numbers...
T_01 = 1
T_00 = 0
T_02 = 3
T_05 = 15
T_90 = 4095
I'm pretty positive these are the only integers for which the above formula holds...
e.g.
((43*135)*(16383 - 104)) / ((16383^2 +16383)/2 - (104^2 + 104)/2) = 645/916 --> .70
((47*176)*(32767 - 119)) / ((32767^2 + 32767)/2 - (119^2 + 119)/2) = 16544/32887 --> .50
((53*231)*(65535 - 135)) / ((65535^2 + 65535)/2 - (135^2 + 135)/2) = 24486/65671 --> .37
((59*297)*(131071 - 152)) / ((131071^2 + 131071)/2 - (152^2 + 152)/2) = 17523/65612 --> 0.26
((61*385)*(262143 - 170)) / ((262143^2 + 262143)/2 - (170^2 + 170)/2) = 23485/131157 --> .18
For the special cases of x = 0, 1, 2 & 13, where par_n denotes "partition #," then the following statement also holds...
((p'_x*par_x)*(M_x - (T_x - 1))) / ((T_(M_x) - T_(T_x - 1)) is in N
Worth noting is the relationship between the following numbers and Multiply Perfect Numbers:
((0^2 + 0)/2 = 0; sigma (0) = 0* (n-fold Perfect)**
((1^2 + 1)/2 = 1; sigma (1) = 1 (1-fold Perfect)
((3^2 + 3)/2 = 6; sigma (6) = 12 (2-fold Perfect)
((7^2 + 7)/2 = 28; sigma (28) = 56 (2-fold Perfect)
((8191^2 + 8191)/2 = 33550336; sigma (33550336) = 67100672 (2-fold Perfect)
* Assumes divisors of an integer must divide that integer and be less than or equal to that integer...
** I don't know if 0 is typically considered "Multiply-Perfect," but I see no reason for it not to be based upon the above definition.Raphie
P.S. The above is a "somewhat" accidental observation that followed from exploratory investigations into the following (dimensionless) numerical equivalency for the Josephson Constant Derivation of Planck's Constant where 67092479/8191 = Carol_13/Mersenne_13 = C_13/M_13 for Carol Numbers = M_n^2 - 2, and 9.10938215*10^-31 is the mass of an electron.
sqrt ((4*pi^2*9109.38215)/(67092479/8191) ~ 6.62606776
Related Link: Planck's Constant (Determination) http://en.wikipedia.org/wiki/Planck_constant#Determination
The modulus grows so quickly that it is easy to prove that this doesn't happen for x > 13.
My calculations disagree with yours on x = 0.
How are you calculating at 0? It's entirely possible I made a physical typo or "mind typo" somewhere. (I'm rather known in certain quarters for those...) :-)
Raphie
Here is the typo...
((1*1)*(0 + 1))/((0^2 + 0)/2 - ((-1)^2 -1)/2) = Undefined
((1*1)*(0 + 1))/((0^2 + 0)/2 - (-(1)^2 -1)/2) = 1
Thank you for the catch, CRGreathouse. Obviously T_-1 = 0. The basic principle of the formula can still work for all values, but only if one uses factorials in the denominator. Thus...
n!/|n -1|! replaces x in the denominator (for n = ((T_(M_x) - T_(T_x - 1)))
... a mathematical "part of speech" I use frequently (and originally used in a formula related to the above that I call "The Chess King Sequence").
And why do I use n!/|n-1|! ?
EXAMPLE:
For y = Ramanujan-Nagell Triangular # *2
For x = sigma (2^n -1)
K_x = x-th Maximal Kissing Number
Then...
y*x = K_x
0 * 0 = 0 = K_0
2 * 1 = 2 = K_1
6 * 4 = 24 = K_4
30 * 8 = 240 = K_8
8190 * 24 = 196560 = K_24
But how to state in the following form?
K_x/x = y
It only works if I adopt some "kludge" such as n!/|n - 1|! to handle the special case of x = 0.Raphie
That doesn't work, since (-1)! is undefined.
That is why I present it as an absolute value... |n-1|!
|0 - 1|! = 1
It's a "kludge" (aka "a workaround"), CRGreathouse. Nothing more and nothing less. The purpose of the kludge? To preserve symmetry. Not mathematical symmetry, mind you, but (forgive the philosophical turn here...) cognitive symmetry.
a*b = x
x/b = a
... "wrong" for b = 0, a mathematical "fact." I know that.
But practically speaking, it gets in the way of any "number mappings" that start at 0 rather than 1. Which, in large part, is also why I include 1 as the 0-th prime (p'_0). It provides a reference point for comparison with other integer progressions.
- RF
|0 - 1|! = 1
Oh, I missed that. It does make me cringe, though. If it makes you happy, so much the better I suppose.
You just made me laugh out loud, CRG, so I guess I can accept that. :smile:
In general, thank you for all the feedback you have given me. It does not go unnoticed or unappreciated.
- RF
Hi CRGreathouse. Don't know if you've been checking in at all, but I thought I'd make mention of the fact that I have cleaned up my initial statement just a bit. It might still make one "cringe," but it does accurately "capture" all the indices associated with the Ramanujan-Nagell Triangular Numbers, and has led to some other observations, a few of which are mentioned here:
OBSERVATION: The #31, The Golden Scale, Prime Counting Function & Partition Numbers
https://www.physicsforums.com/showthread.php?t=469982
https://www.physicsforums.com/showthread.php?t=452148
For p'_x denotes an Integer| 0 < d(n) < 3, M_x a Mersenne Number and T_n a Triangular Number, then...
((p'_x * p'_2x) * (M_x - |T_x - 1|)) / ((T_(M_x) - T_|T_x - 1|) is in N
for |T_x - 1| = 1, 0, 2, 5, 90 and x = 0, 1, 2, 3, 13
EXPANSION
((01 * 001) * (0000 - 01)) / ((0000^2 + 0000)/2 - (01^2 + 01)/2) = 01
((02 * 003) * (0001 - 00)) / ((0001^2 + 0001)/2 - (00^2 + 00)/2) = 06
((03 * 007) * (0003 - 02)) / ((0003^2 + 0003)/2 - (02^2 + 02)/2) = 07
((05 * 013) * (0007 - 05)) / ((0007^2 + 0007)/2 - (05^2 + 05)/2) = 10
((41 * 101) * (8191 - 90)) / ((8191^2 + 8191)/2 - (90^2 + 90)/2) = 01
For quick verification, anyone interested can just copy and paste these equations into the compute box of Wolfram Alpha at http://www3.wolframalpha.com/
0, 1, 2, 5, 90 are the index numbers associated with the Ramanujan-Nagell Triangular Numbers 0, 1, 3, 15, 4095, which, as Î have previously noted, map, whether coincidentally or no, in 1:1 manner with Maximal Sphere Packings for dimension sigma (M_n(mod 5)) = 0, 1, 4, 8, 24 by the formula 2*T_z*sigma (M_n(mod 5)), for T_z denotes a Ramanujan-Nagell Triangular Number and sigma(n) the sum of divisor function.
2* 0 * 0 = 0 = K_0
2* 1 * 1 = 2 = K_1
2* 3 * 4 = 24 = K_4
2* 15 * 8 = 240 = K_8
2* 4095 * 24 = 196560 = K_24
RELATED PAPER
Kissing Numbers, Sphere Packings, and Some Unexpected Proofs
Florian Pfender & Günter M. Ziegler (2004)
http://mathdl.maa.org/mathDL/22/?pa=content&sa=viewDocument&nodeId=3065
A couple examples of observations I believe to be unique utilizing the first and last x values associated with the above equation form where...
((p'_x * p'_2x) * (M_x - |T_x - 1|)) / ((T_(M_x) - T_|T_x - 1|) = 1
(indicative of an elliptic curve of some form?)
T_13 + T_06 = par_13 + par_06 = 91 + 21 = 101 + 11 = 112
T_00 + T_12 = par_00 + par_12 = 00 + 78 = 001 + 77 = 078
0 + pi (31 - 11) + phi (31 - 11) + (31 - 11) = 0 + 8 + 08 + 20 = 36
0 + pi (31 - 12) + phi (31 - 12) + (31 - 12) = 0 + 8 + 18 + 19 = 45
0 + pi (31 - 13) + phi (31 - 13) + (31 - 13) = 0 + 7 + 06 + 18 = 31
36 + 45 + 31 = 112
0 + pi (00 + 11) + phi (00 + 11) + (00 + 11) = 0 + 5 + 10 + 11 = 26
0 + pi (00 + 12) + phi (00 + 12) + (00 + 12) = 0 + 5 + 04 + 12 = 21
0 + pi (00 + 13) + phi (00 + 13) + (00 + 13) = 0 + 6 + 12 + 13 = 31
26 + 21 + 31 = 78
T_(13 + 6) = T_19 = 112 + 78 = 190
T_(0 + 12) = T_12 = 000 + 78 = 078
p_(par_6 + par_7) = par (6 + 7) = par_(0+13) = p_26 = 101
0 + 6 + 12 + 13 = 31 --> 00 + pi (00 + 13) + phi (00 + 13) + 13, and 31 is the largest prime associated with partition numbers of Hausdorff Dimension 1 as per Ken Ono et al's recent mathematical findings. 13 is the smallest prime.
Metaphor: All the matters is the beginning and the end of the shot (a film industry truism...) In other words, the metaphor being applied here is that the beginning and end of the shot equate in some manner with "lattice points" of human perception.
Oh, and by the way, in relation to the number 31 (= 31 +/- 00)...
T_00 + p'_00 - par_00 = 00 + 01 - 001 = 00
T_13 + p'_13 - par_13 = 91 + 41 - 101 = 31RF
P.S. Also, 45 is a Sophie Germain Triangular Number (2x + 1 is triangular) partnered with 91 (and when summed, 91 + 45 equals another triangular number, T_9 + T_13 = T_(7+9) = T_16 = 136):
112 == sigma (91) = sigma (T_13) = sigma (2*(par_7 + par_9) + 1) = sigma (2*(15 + 30) + 1)
078 == sigma (45) = sigma (T_09) = sigma (1*(par_7 + par_9) + 0) = sigma (1*(15 + 30) + 0)
A Related Conjecture:
Sophie Germain Triangles & x | 2y^2 + 2y - 3 = z^2
https://www.physicsforums.com/showthread.php?t=462793
(sqrt (16x + 9) - 1)/2 = y | 2y^2 + 2y - 3 = z^2
for x a Sophie Germain Triangular Number
e.g.
(sqrt (16*45 + 9) - 1)/2 = (0 + 13) = y
(2*13^2 + 2*13 - 3 = (6 + 13)^2 = 19^2 = z^2
Also related is the form: (n^2 - 2*a^2 - 7)/2 = 0
e.g. (13^2 - 2*(9)^2 - 7)/2 = 0
P.P.S. Would it were that one were not so discouraged by modern day sensibilities to note, for instance, that the above conjecture and observations are indirectly derivative of number mappings such as the following: (C (31, 1) + C (31, 2) + C (31, 3) + C (31, 4))*(totient (pi (31)))^-(pi (31)) == 3.6456*10^-11, the value of a number quite central to modern day physics, although derived by a "numerologist," Johann Balmer.
Related to Observation: A Prime / Mersenne / (Ramanujan) Triangular Number Convolution
1. What is a Prime/Mersenne/(Ramanujan) Triangular Number Convolution?
A Prime/Mersenne/(Ramanujan) Triangular Number Convolution is a mathematical concept where two triangular numbers are multiplied together and the resulting number is checked for being either a prime, Mersenne, or Ramanujan number.
2. How is this type of convolution calculated?
The calculation of a Prime/Mersenne/(Ramanujan) Triangular Number Convolution involves finding two triangular numbers, multiplying them together, and then checking the resulting number for its primality, Mersenne property, or Ramanujan property.
3. What is the significance of this type of convolution?
This type of convolution is significant because it allows for the discovery of new prime, Mersenne, and Ramanujan numbers, which are important in number theory and have applications in cryptography and other fields.
4. Are there any known patterns or relationships between Prime/Mersenne/(Ramanujan) Triangular Number Convolutions?
There are some patterns and relationships that have been observed between these types of convolutions, but they are still being studied and further research is needed to fully understand them.
5. How is this type of convolution related to other mathematical concepts?
Prime/Mersenne/(Ramanujan) Triangular Number Convolutions are related to other concepts such as triangular numbers, prime numbers, Mersenne numbers, and Ramanujan numbers. They also have connections to other areas of mathematics, such as number theory and combinatorics.
  • Linear and Abstract Algebra
