Photon Average Energy in a Cavity Resonator
In summary, the rms EM field within a cavity resonator, excited in a single resonant mode by a current probe of fixed rms amplitude, is known to rise linearly with time.
Q-reeus
1,115
The rms EM field within a cavity resonator, excited in a single resonant mode by a current probe of fixed rms amplitude, is known to rise linearly with time; eg. http://www.jpier.org/PIER/pier78/15.07090605.Wen.pdf", sections 5.2, 5.3, fig's. 6, 10. (Normally it is a fixed driving voltage, increasingly opposed by a rising internal cavity field, that applies, resulting in an exponentially decaying rms current. Over a relatively short time interval that can always be compensated by ramping up driving voltage, and we assume that applies here - fixed rms current simplifies the picture). As the probe is pumping in a fixed rms photon rate, it follows that photon density d and field rms amplitude A rise in direct proportion. Field rms energy density W is proportional to A2, so simple maths requires average energy per photon W/d is not the fixed value E = hf for an 'isolated' photon but rises linearly with time to typically a far higher value. The specific time independent proportionality factor will be a function of such things as frequency and cavity mode.
This evidently necessary finding conflicts sharply with standard QED, where the energy in an EM wave is simply the sum of the individual quanta (photons), eg. http://math.ucr.edu/home/baez/photon/odd-ques.htm" , where John Baez proposes:
"First let's think of light as being classical. Then the energy density is (E2 + B2)/2,...So the energy density is something like A2...On the other hand, let's think of light as being made of photons. The energy of a photon is E = hbar w where hbar is Planck's constant and w is the angular frequency,.. So the energy density should be hbar w d, where d is the average number of photons per cubic meter. So we should have A2 = hbar w d
Does that make sense? The lower the frequency, the more photons we need to get a particular energy, so that part makes sense. It's sort of odd how the number of photons is proportional to the square of the amplitude; you mighta thunk it would just be proportional."
Having a layman's knowledge of QM and QED, the circuitous route then taken is one I could not follow at all well.
That this standard QED relation applies generally - to both free-space radiation and fields confined within a cavity resonator was gleaned from "Cavity Quantum Electrodynamics; The Strange World Of Light In A Box" - S.Dutra. A 'plain english' statement on p48, following eq'n 2.148, relating there to a plane wave, reads:"...just as in the cavity case, we will get a Hamiltonian that equals the sum of the energies of each photon plus an infinite term..." (The latter is the zero-point field, irrelevant in context). In the context of say a dipole antenna radiating into free-space, this standard picture makes perfect sense - photon numbers and power are in proportion, and both are conserved overall. Hence energy per photon is invariant IN THIS SETTING.
But as was found earlier, the wheels fall off in the context of an excited cavity - energy per photon is anything but fixed. It should be emphasized at this stage - conservation of energy is never in question in any setting discussed here. PARTITIONING of energy is at issue. Whether or not 'coherent state' has any explanation here, there is a further consequence that seems truly bizarre. Suppose the cavity is a length of hollow waveguide several wavelengths long. Let the probe current be switched off after a time when the computed average energy per photon is very much greater than E = hf. Let one end of the waveguide be suddenly opened, turning it into an antenna. In a little more than twice the guide wave traversal time, the internal cavity field will have emptied into free-space, creating a burst of radiation propagating away in an increasingly spherical wavefront. Total wave energy and photon count are in this free-space setting both invariant, so that energy per photon is fixed but much greater than the 'usual' value. Something is very wrong - at very large distance from the source where only individual photons of energy E = hf might normally be encountered, what will actually occur? Will 'super energetic' photons be found, or will they actually fission en route to eventually leave 'normal' photons only. Or does the concept of photon lose validity in such a case. Certainly there is never a dilemma in the classical EM setting. It only arises when trying to fit a consistent field-as-photons picture. Or am I missing something basic in the original cavity setting? There's too much evidence in favor of the photon as real to ditch it. Need help - what's the answer?
You may cosider the cavity material in it's configuration as a harmonic storage capacitor which must charge and discharge with changing conditions.
Nice to have some feedback - was getting used to the idea this one would sink out of site with zero comment! Cavity 'material' being typically vacuum - had in mind a section of end-shorted hollow metallic waveguide as resonator. Basically you seem to be saying treat the cavity field as virtual photons not real - ie quasi-static not radiative; yes? That doesn't seem right here. To energize a section of shorted waveguide a wave having a non-zero Poynting vector must propagate from source probe (assumed to be at one end of the guide), and then multiply reflect back and forth in constructive phase so as to produce that linear rise in amplitude with time. If the guide length is a number of wavelengths long, the linear rise will actually be in a series of steps, but averaged over time yields a linear envelope. The test of whether virtual or real photons apply is surely, what happens when the energized cavity is opened to the environment? If virtual photons there will be no propagation, if real they will escape. That answer is I think clear. You could also think of the case of a cavity as a multi-wavelength radius spherical metallic shell centered about a dipole antenna. The antenna is clearly radiating real photons that then reflect off the shell wall to form a standing wave field that again builds up over time with a linear envelope. Thoughts?
Q-reeus : Think about this, the photon ( quanta ) propagates as one fundamental harmonic in free false vacuum with the limited ability of inducing a harmonic in mass where that harmonic's wave length in shorter than 2 times the Planck wave length, and interacts with mass determined by the information embedded in the masses total structure ( dimensional structure as a harmonic resonator and through it's electromagnetic interaction, as in rate of change in induced propagation.). Photons are a pure single fundamental wave length form of interaction, which resonates with inertial mass.
Where did you get all this from!?
Q-reeus : From years of hard work. The article appears to reach into some of my findings. Not that I can produce the a proof, but I have studied for years the electromagnetic photon's interaction with inertal mass through harmonics. I do not wish to misslead you, but it does have some logic.
FAQ: Photon Average Energy in a Cavity Resonator
What is a photon?
A photon is a fundamental particle of light that carries energy and has zero mass. It is the basic unit of electromagnetic radiation and is responsible for all light and other electromagnetic waves.
What is a cavity resonator?
A cavity resonator is a device that uses the principles of resonance to enhance the amplitude of an electromagnetic wave. It consists of two mirrors facing each other, creating a confined space for the wave to bounce back and forth, resulting in an amplified signal.
How is the average energy of photons calculated in a cavity resonator?
The average energy of photons in a cavity resonator is calculated by dividing the total energy of all the photons in the cavity by the total number of photons present. This can be expressed using the formula E = hν, where E is the energy of a single photon, h is Planck's constant, and ν is the frequency of the wave.
What factors affect the average energy of photons in a cavity resonator?
The average energy of photons in a cavity resonator is affected by the frequency of the electromagnetic wave, the size and geometry of the cavity, and the number of photons present. The higher the frequency and number of photons, the higher the average energy.
How does the average energy of photons in a cavity resonator relate to the intensity of the electromagnetic wave?
The average energy of photons in a cavity resonator is directly proportional to the intensity of the electromagnetic wave. This means that as the intensity of the wave increases, the average energy of photons also increases. This relationship is important in understanding the behavior of light and other electromagnetic waves in resonant cavities.
