How to Prove the Sign-Preserving Property for a Continuous Function?
  • Thread starter Thread starter goodheavens
    Property
To prove the sign-preserving property for a continuous function, one can utilize the definition of continuity. If f is continuous at a point c and f(c) > 0, then there exists a neighborhood around c where f(x) remains positive. The proof involves selecting ε = f(c)/2 to establish that for all x within this neighborhood, f(x) will be greater than 0. The same reasoning applies if f(c) < 0, ensuring that f(x) will also be negative in the corresponding interval. This approach effectively demonstrates the sign-preserving nature of continuous functions.
goodheavens
how do you prove the sign-preserving property?
it says here that.
If f is continuous at a, and f(a) < 0, then there is an open interval I containing a such that f(x) < 0 for every x in I.
For a proof, simply take the open interval (2f(a),0) for the challenge interval "J" in the definition of continuity.
i don't get it :(
:sorry my previous post was a mistake :)
Please show us your work.
The idea of the proof is to use the fact that if f is continuous at c and f(c)>0 then there exist a neighbourhood of c such that f(x) >0 .
That neighbourhood is what you have to find.
Try using the definition of continuity.
i saw a similar problem to this one and I am not sure if this works
using the \epsilon - \delta definition we have
l x-c l < \delta \Rightarrow l f(x) - f(c) l < \epsilon
then they used \epsilon = f(c)/2
lf(x)-f(c)l < f(c)/2
-f(c)/2<f(x)-f(c)< f(c)/2
f(c)/2 < f(x) < 3f(c)/2
f(x) > f(c) > 0 .
but i don't know how \epsilon = f(c)/2
I have restored your second post because it is exactly what you want.
The whole idea of "continuity" is that "if x is close to a, then f(x) is close to f(a)." In particular, if f(c) is positive, and f(x) is close to f(c), then f(x) must be positive also.
Why f(c)/2? If f(c)> 0 then f(c)/2> 0 also so every number between f(c) and f(c)/2 is positive. Find \delta&gt; 0 so that if |x- c|&lt; \delta (that is, so that c- \delta&lt; x&lt; c+ \delta, then |f(x)- f(c)|&lt; f(c)/2. That is the same as saying that -f(c)/2&lt; f(x)- f(c)&lt; f(c)/2 and, adding f(c) to each part, f(c)/2&lt; f(x)&lt; 3f(c)/2. Since f(c)/2 is positive, so is f(x). In other words, f(x) is positive for all x in the interval c- \delta to c+ \delta.
thank you sir
i forgot to mention that the interval was (a,b)
Your interval involves c and delta. (a, b) is simply the delta neighbourhood of c.
You cannot determine the interval in advance. Once you have found a "\delta" for whatever \epsilon you choose (as long as f(c)- \epsilon&gt; 0), a= c- \delta and b= c+ \delta
the interval (a,b) was actually one of the given data.
thank you
thank you
Well you changed the question! :-P
In the new question b does not exist.
The new question is a minor variation of the previous question. The only different is that c is now a and f(c) <0. This is okay since c was assumped to be abitrary.
The same prove you presented will work but your \epsilon = \frac{|f(a)|}{2}.
yeah cause its the same as in this https://www.physicsforums.com/showthread.php?t=460116 that would be double posting :)
so this is the final proof that i made for the previous question.
Let \epsilon > 0
Since f(c) > 0. then \frac{f(c)}{2} > 0 . use \epsilon = \frac{f(c)}{2}
l x-c l < \delta \Rightarrow l f(x) - f(c) l < \frac{f(c)}{2}
c - \delta < x < c + \delta \Rightarrow \frac{-f(c)}{2} < f(x) - f(c) < \frac{f(c)}{2}
\Rightarrow \frac{f(c)}{2} < f(x) < \frac{3f(c)}{2}
\Rightarrow f(x) > \frac{f(c)}{2} > 0
Thus, f(c) > 0
if i made a mistake please tell me . thank you
This is correct.
Let \epsilon > 0
Thus, f(c) > 0
Weren't you trying to prove that f(x) is greater than 0, using the fact that f(c) is greater than 0? It seems that your final statement should be "Thus, f(x)>0".
oh yeah. haha thank you :smile::
  • · Replies 26 ·
  • · Replies 40 ·
