How do i find domain of influnce?
  • Thread starter gtfitzpatrick
  • Tags
    Domain
In summary, the conversation discusses determining the characteristics curve and general solution for the equation x^{3}\frac{\partial{u}}{\partial{x}} - \frac{\partial{u}}{\partial{y}} = 0. The homework question also asks for finding the solution and domain of influence when u(x,0) = \frac{1}{1+x^2} and proving that the solution is not defined when y>\frac{1}{2x^2}. The conversation also includes a discussion on the method of characteristics and finding the particular solution, which is u(x,y) = \frac{1}{1+(y - \frac{1}{2x^2})^{2}}. The notes provided by hunt_mat
gtfitzpatrick
379
determine the char. curve and gen. sol. for x[tex]^{3}[/tex] [itex]
[/itex] - [itex]
[/itex] = 0
find sol and domain of influence when u(x,0) = [tex] \frac{1}{1+x^2} [/tex]
show sol is not defined when y> [tex] \frac{1}{2x^2} [/tex]
so [tex] \frac{\partial{y}}{\partial{x}} = \frac{-1}{x^3} [/tex]
and [tex] \frac{\partial{u}}{\partial{x}} = 0 [/tex]
which gives u(x,y) = [tex]F( \frac{1}{2x^2} - y) [/tex] is the gen solution right?
then sol. at u(x,0) = [tex] \frac{1}{1+x^2} [/tex]
[tex] \frac{1}{1+x^2} [/tex] = [tex]F( \frac{1}{2x^2} - y) [/tex]
= [tex]F( \frac{1}{2x^2}) [/tex]
which gives x = +/- 1 am i right in this? and how do i find domain of influnce?
Much better way to to set:
[tex]
\dot{x}=x^{3},\quad\dot{y}=-1\quad\dot{u}=0
[/tex]
with the initial condition:
[tex]
x(0)=r\quad u(0)=\frac{1}{1+r^{2}}
[/tex]
i don't understand what you are doing?
[tex]
[/tex]
Is that not what i did, then solved [tex]
\frac{\dot{y}}{\dot{x}} = \frac{-1}{x^3}
[/tex]
but then...
From my equations you have:
[tex]
-\frac{1}{2x^{2}}=s+r,y=-s,u=\frac{1}{1+r^{2}}
[/tex]
so substitute to get u=u(x,y)
im getting
[tex]
u(x,y)=\frac{1}{1+(y - \frac{1}{2x^2})^{2}}
[/tex]
but I am still not sure about this, but this is the particular solution right?
This is the correct solution, well done.
what happens in first order PDE is that your initial condition is propagated along the characteristics.
Thanks hunt_mat for your help, and patiance!
Im still not sure of a few things,
so the characteristics are [tex]
\frac{dx}{dt} = \dot{x}=x^{3}, \frac{dy}{dt}=\dot{y}=-1, \frac{du}{dt}=\dot{u}=0
[/tex]
the general solution is
[tex]
u(x,y)=y - \frac{1}{2x^2}
[/tex]
and the particular solution is
[tex]
[/tex]
but I am not sure to about the domain of influence or how to
\frac{1}{2x^2}
[/tex]
also in the book it gives the solution as u = [tex] \frac{1-2x^2y}{1+x^2-2x^2y} [/tex] which try as i might i cannot seem to make mine fit
Hi, I wrote some notes on the method of characteristics which I have included in this post. It is possible that the book you have is giving you trhe wrong answer, this happens sometimes. I just checked the answer with mathematica and you have the right answer.
What d you understand about domain of dependance?
  • characteristics.pdf
thanks Mat for the notes, there is a lot of stuff in there that our lecturer hasn't covered yet. I didnt see anything in there about the domain of dependance, and i have nothing in my notes on it either and the more i try to find about it on www the more confused i get...
is the dom. of influ. just?
[tex]
u(x+t,y+t)=\frac{1}{1+((y+t) - \frac{1}{2(x+t)^2})^{2}}
[/tex]
FAQ: How do i find domain of influnce?
What is the domain of influence?
The domain of influence is the set of variables or factors that can affect the outcome or behavior of a particular system, process, or phenomenon.
How do I determine the domain of influence?
To determine the domain of influence, you need to identify all the potential variables or factors that may have an impact on the system or process. This can be done through research, experimentation, or expert knowledge.
Why is it important to know the domain of influence?
Knowing the domain of influence is important because it allows us to understand the potential factors that can affect the outcome of a system or process. This can help us make informed decisions and predictions, and also identify potential risks or limitations.
Can the domain of influence change over time?
Yes, the domain of influence can change over time. This can happen due to various reasons such as changes in the environment, new discoveries, or advancements in technology. It is important to continuously reassess the domain of influence to ensure accurate understanding and predictions.
How can I minimize the influence of certain variables?
The best way to minimize the influence of certain variables is through proper control and manipulation. This can be done through experimental design, where one variable is changed while keeping all other variables constant. Additionally, identifying and understanding the relationship between variables can also help minimize their influence.
