Defining a Flow: What's the Best Way?
In summary, there are multiple definitions of a flow, also known as a dynamical system. Arnold defines it as a pair consisting of a set called the phase space and a set of t-advance mappings, while the Wikipedia article defines it as a function of the form g(_,x). The same article also mentions a real dynamical system, which is a tuple with an open interval in the real numbers, a manifold locally diffeomorphic to a Banach space, and a continuous function. Wikipedia defines a flow as the evolution function of a global real dynamical system, and Scholarpedia gives the name flow to a global real dynamical system itself. The definitions may differ in their level of detail and approach, but they all describe the concept
Rasalhague
1,387
I'm wondering which of the following definitions of a flow is best. Is there one primary, rigorous, general definition of which the others are informal shorthands, or are the differences no more then superficial differences in convention?
(1) Arnold, in Ordinary Differential Equations, defines a (phase) flow1 as a pair (M,{gt}) where M is a set called the phase space, and {gt} the set of all t-advance mappings gt : M --> M. And gt = g(t,_), where g is the evolution function of the dynamical system, as defined by Wikipedia: Dynamical system.
(2) The aftoresaid article, in the section "General definition", gives the name flow2 to functions of the form g(_,x), which it calls "the flow through x".
(3) The same article, in the section "Geometric cases" tells us: "A real dynamical system, real-time dynamical system or flow3 is a tuple (T, M, Φ) with T an open interval in the real numbers R, M a manifold locally diffeomorphic to a Banach space, and Φ a continuous function."
(4) Wikipedia: Flow, defines a flow4 as the evolution function of a global real dynamical system, that is, one for which T = R.
(5) And Scholarpedia: Dynamical systems gives the name flow5 to a global real dynamical system itself.
Are the definitions as a tuple, such as Arnold's, rather superfluous? By this I mean, isn't the existence of M and its relationship to the functions g or gt already part of the definition of those functions? Is that why it's okay to define a flow, or indeed a dynamical system in general, as its own evolution function? Or are the defininitions which take this approach shorthand definitions which miss out information necessary for a completely general and rigorous definition of a dynamical system?
Mathematics news on Phys.org
Related to Defining a Flow: What's the Best Way?
1. What is a flow in scientific terms?
A flow, in scientific terms, refers to the movement of a substance or energy from one point to another. This can include fluid flow, such as the flow of water or air, or the flow of electricity or heat.
2. How can a flow be defined?
A flow can be defined as a continuous and smooth movement of a substance or energy. It can also be defined in terms of its direction, speed, and volume.
3. What factors influence the definition of a flow?
The definition of a flow is influenced by various factors, including the properties of the substance or energy being moved, the environment in which the flow occurs, and any external forces acting on the flow.
4. What is the best way to define a flow?
The best way to define a flow depends on the specific context and purpose of the definition. Generally, a flow can be defined by its characteristics, such as its velocity, rate of flow, or direction, or by its function, such as its role in a system or process.
5. Why is it important to define a flow accurately?
Defining a flow accurately is important in order to understand and predict its behavior and impact on a system or process. It also allows for effective communication and analysis in scientific research and engineering applications.
  • General Math
9K
  • Classical Physics
11K
