Why is there still mostly hydrogen in pop I and II stars?
In summary, the idea that every atom in our bodies came from an exploding supernova may not be entirely accurate. While heavy elements are indeed produced in stars and supernovae, most of the hydrogen in the universe has never been in a star. The intergalactic medium holds the majority of the mass in the universe, and over time it collapses to form stars, planets, and other objects. So while some hydrogen may come from supernovae, it is not the primary source for most of it.
DaleSwanson
352
I've heard in the past something along the lines of "every atom in your body came from an exploding supernova". Yet, I can't see how that could be true when there is still such an abundance of hydrogen. Wouldn't any hydrogen in a star prevent it from reaching supernova stage?
Assuming hydrogen can't come from supernova, my next question is how did it avoid being captured in a star for the first few billion years of the universe? If I had to guess, I'd say that it is spread so thin that it simply takes billions of years for gravity to weakly pull it into a forming star. And, despite it being so thin, the volume is so enormous that there is enough of it to form stars when it finally does coalesce.
I've been thinking about this for a while, but in the process of typing it out, I feel I may have answered my own question. I guess maybe I just misheard the original quote, or it was exaggerated. Still maybe there is something going on that I'm missing, and it really is possible for hydrogen to survive to supernova stage.
Space news on Phys.org
There's still hydrogen in the outer layers. Basically, very heavy stars end up with an iron core (which is inert) and a sequence of progressively lighter elements moving outward, with nuclear fusion going on at the boundary of every layer. Once the iron core gets to the point that it can no longer provide enough pressure to support its weight, it collapses and goes supernova.
That said, I don't think it's necessarily the case that the hydrogen came from supernovae. But the rest of the atoms did.
Indeed most of the atoms (and thus most of the hydrogen atoms) in the Universe have never been in a star or in a supernova. All heavy elements are produced in stars (but carbon, for example, is mainly produced in the atmospheres of AGB stars, not in supernovae). The intergalactic medium holds the vast majority of the mass in the universe, but slowly this matter all collapses into galaxies, stars, planets, people and so on. So, most of your hydrogen is not necessarily processed through stars.
Primordial abundance is the short answer. Most of the progenitor mass for newly forming stars is still predominately hydrogen. Dying stars polute this mix with metallicity, but, not significant extent. Most of the mass of our galaxy is still locked away in this mix of polluted primordial gas - e.g.,
http://www.sciencedaily.com/releases/2010/05/100526111230.htm
Your reasoning is largely correct. The reason why there is still mostly hydrogen in pop I and II stars is because hydrogen is the most abundant element in the universe. It is estimated that about 75% of the mass of the universe is made up of hydrogen. This is because during the Big Bang, the universe was filled with incredibly hot and dense plasma, and the simplest and lightest element, hydrogen, was formed in abundance. As the universe expanded and cooled, this hydrogen was able to clump together due to gravity and eventually form stars.
In the early universe, there were no heavy elements like carbon, oxygen, and iron, which are necessary for life and are also formed in supernovae. These elements are created through nuclear fusion in the cores of stars and are then released into the universe when the star dies in a supernova explosion. So, while it is true that every atom in our bodies came from a supernova, the hydrogen that makes up the majority of our mass was already present in the early universe.
As for your question about how hydrogen avoided being captured in stars for the first few billion years of the universe, you are correct in thinking that it was spread out thinly and took a long time for gravity to pull it into forming stars. In addition, the process of star formation is a complex one and not all regions of the universe were equally conducive to star formation. Some areas may have had higher concentrations of heavier elements, making it easier for stars to form, while others may have had lower concentrations, resulting in a slower formation of stars.
In summary, the abundance of hydrogen in pop I and II stars is a result of its abundance in the early universe and the slow process of star formation. While it is possible for hydrogen to survive to supernova stage, it is not the only element present in stars and is not responsible for the majority of their mass. I hope this helps clarify the concept for you.
Related to Why is there still mostly hydrogen in pop I and II stars?
What is the composition of pop I and II stars?
Pop I and II stars are mainly composed of hydrogen and helium, with trace amounts of heavier elements like carbon, nitrogen, and oxygen.
Why is there a higher abundance of hydrogen in pop I and II stars?
Pop I and II stars were formed earlier in the history of the universe, when the abundance of heavier elements was much lower. This means that these stars were primarily made up of the elements that were most abundant at that time, which were hydrogen and helium.
How does the composition of pop I and II stars affect their lifespan?
The presence of heavier elements in pop I and II stars affects their ability to fuse hydrogen into helium. The presence of heavier elements acts as a catalyst, making the fusion process more efficient and therefore extending the lifespan of these stars.
Do all pop I and II stars have the same composition?
No, there can be variations in the composition of pop I and II stars depending on the location and conditions in which they were formed. Pop I stars, which are younger and found in the disk of our galaxy, may have a slightly higher abundance of heavier elements than pop II stars, which are older and found in the galactic halo.
How does the composition of pop I and II stars impact the formation of planets?
The presence of heavier elements in pop I and II stars can affect the formation of planets. These elements provide the necessary building blocks for rocky planets to form, which is why pop I stars are more likely to have planets with solid surfaces compared to pop II stars.
  • Astronomy and Astrophysics
  • Cosmology
