Does the formation of a black hole start with QM?
In summary, the existing theory of black hole formation starts with a massive star running out of fuel and collapsing due to the lack of heat pressure to counter gravity. This results in the formation of an event horizon and a black hole. The details of what happens at the core of the collapse are still not fully understood, but quantum mechanics predicts the presence of non-zero vacuum energy which can produce virtual particles and potentially microscopic black holes. As the black hole grows, it can continue to consume matter and grow larger. However, there is still no complete theory of quantum gravity to fully explain the process of black hole formation. Some theories propose that the singularity at the center of a black hole can be avoided, but this is still an area of active research
superpaul3000
62
Most people on this forum know the basic theory of black hole formation. When a massive star runs out of fuel there is no longer enough heat pressure pushing out against the gravity pulling in and the star collapses. The density of the core and resulting remnant become so large that nothing, not even light, can escape. This forms an event horizon and something we call a black hole.
However, I have not found much more information than that. I was curious as to the details of what is going on at the core of the collapse in the formation of the black hole. I tried to understand this process with the known laws of physics. This of course means one must consider QM in the picture.
So QM predicts that there is some non-zero vacuum energy randomly producing virtual particles that are continuously created and then annihilate with each other. It is also possible that microscopic black holes form from these quantum fluctuations but since they are so small they evaporate through hawking radiation very quickly. These mini black holes are forming all around us all the time and presumably also forming at the cores of collapsing stars. So my understanding would be that given a critical density of matter, one which could be realized during this collapse, the mini black hole gets close enough to particles of matter to suck them into it. The bigger it gets the slower it evaporates and the faster it grows. The final result is a supernova with a black hole remnant at its center.
Is this an existing theory of black hole formation? Are there other theories that describe the details of black hole formation?
The existing theory of black hole formation does not start with a microscopic black hole. The essential point is that quantum effects are no longer strong enough to counter gravity so that the collapsing star remnant (if it is massive enough) has a small enough volume so that the escape velocity is greater than the speed of light.
I think some insight can be gained from looking at the Schwarzschild interior metric. If we consider the time component only-
[tex]d\tau=\left( \frac{3}{2}\sqrt{1-\frac{2M}{r_0}}-\frac{1}{2}\sqrt{1-\frac{2Mr^{2}}{r_0^{3}}}\right)dt[/tex]
where r0 is the radius of the spherical mass. If we consider a neutron star that has just exceeded the TOV limit at 3 sol mass through accretion, r0 will gradually reduce. Considering M being a constant and r0 reducing, when r0 reaches 9M/4, [itex]d\tau[/itex] at r=0 (i.e. the centre of the neutron star) becomes zero. As r0 becomes less than 9M/4, a radius where [itex]d\tau=0[/itex] begins to move outwards from the centre, any volume of space within this radius is spacelike and because there are no stable radii in spacelike spacetime, this will induce the collapse of matter within to a form of singularity. This radius where [itex]d\tau=0[/itex] will continue to move outwards as r0 reduces until they both meet at 2M and the interior solution becomes the vacuum solution.
The existing theory of black hole formation does not start with a microscopic black hole. The essential point is that quantum effects are no longer strong enough to counter gravity..
I think that's correct.
a bit more detail:
yes. Essentially when a mass of sufficient size (say a star) begins to compact, as when nuclear reactions subside, the gravitational attraction of the mass begins to confine electrons and electron degeneracy pressure opposes (fights) the collapse...if mass is sufficient, the electron "cloud" collapses and even neutron and proton degeneracy pressure in the nucleus of the matter cannot oppose sufficiently strong gravity...everything is "crushed" and the matter destroyed as a singularity is formed...
Try wikipedia for "degeneracy pressure"...A great book with probably 50 or more pages discussing this specific phenomena is Kip Thorne's BLACK HOLES AND TIME WARPS...find a used paperback cheap...no complex math, lots of physical insights and explanations...
However, here is no complete theory of quantum gravity yet, combining QM and GR, so there are still issues to resolve...
I talked to Martin Bojowald today seeing as he would have some knowledge in the matter. I think stevebd1 was getting at the same thing. It's not that the black hole forms as a point at the center of a collapsing star, but rather when some spherical region of space centered at the core has enough mass within it, its surface becomes an event horizon. If this event horizon formed inside a feeding neutron star, an outside observer would see the surface of the neutron star become more and more red shifted at a slower and slower rate until it appeared to be a black hole. I find it kind of fascinating that even though at the center of the collapse there is zero gravity due to vectors canceling out, the matter still can have a black hole forming around it.
I guess that is what I was looking for in terms of what the current theory is. I'm still not entirely convinced that it is what is really happening. That model predicts a singularity at the center of the black hole which is problematic. I think the theory with mini black holes could avoid a singularity and avoid the information loss paradox.
I'm not sure just what point you make.
The absolute horizon forms at the singularity then spreads smoothly to the instantaneously appearing relative horizon ..at the critical circumference.
Here is how Kip Thorne describes the singularity...
The object the center of black hole... is the region where gravity becomes infinitely strong causing the laws of physics as we know them to break down...The Schwarzschild "singularity" ...is the critical circumference is nothing but a klocation where things can fall but out of which nothing can come...which Rindler gave the critical circumference a new name...the horizon.
and on page 477 somehting I did not remember:
In the singularity the laws of quantum gravity destroy time, leaving space alone and vulnerable...and the laws of quantum gravity then convert space into a random probabilistic foam...in the froth, space does not have any definite shape (that is, any definite curvature, or even any definite topology). Instead space has various probabilities for this, that or another curvature and topology.
FAQ: Does the formation of a black hole start with QM?
1. What is QM and how does it relate to black hole formation?
Quantum mechanics (QM) is a branch of physics that describes the behavior of particles at the subatomic level. It is used to study the interactions between particles and their fundamental properties. In the context of black hole formation, QM plays a crucial role in understanding the behavior of matter and energy at extreme densities and temperatures.
2. Can QM explain the formation of a black hole?
QM alone cannot fully explain the formation of a black hole. It is only one aspect of the larger picture of how black holes are formed. QM can help us understand the initial stages of black hole formation, such as the collapse of a massive star, but other factors such as general relativity and thermodynamics also play important roles.
3. How does QM differ from classical mechanics in terms of black hole formation?
Classical mechanics, which is based on Newton's laws of motion, is used to describe the behavior of macroscopic objects. QM, on the other hand, is used to describe the behavior of particles at the microscopic level. In the context of black hole formation, classical mechanics fails to fully explain the behavior of particles at high densities, whereas QM can provide a more accurate understanding.
4. Are there any fundamental particles involved in the formation of a black hole according to QM?
Yes, according to QM, the fundamental particles involved in the formation of a black hole are quarks, which are the building blocks of protons and neutrons, and leptons, which include electrons and neutrinos. These particles interact with each other through the four fundamental forces (gravity, electromagnetism, strong nuclear force, and weak nuclear force) to form the dense core of a collapsing star, leading to the formation of a black hole.
5. How does QM explain the extreme gravitational pull of a black hole?
According to QM, particles with mass have a corresponding wave function that describes their probability of being in a certain location at a certain time. When a massive star collapses into a black hole, the particles at its core become infinitely dense, which means their corresponding wave function also collapses. This results in an extremely strong gravitational pull, as predicted by general relativity, which is consistent with our observations of black holes.
