Entanglement Experiments: Sources & Detection
In summary: It seems that the results of the experiment are not influenced by the sequence of the events. This suggests that the concept of cause and effect is lost in the experiment.
yuiop
3,962
In another thread https://www.physicsforums.com/showpost.php?p=3143182&postcount=34 it is stated that:
Experiments show that particles can be entangled that have never interacted. QM predicts this, but your ideas wouldn't. Also, particles can become entangled after they are detected. Hardly the kind of thing that would happen if there was a common event responsible for entanglement.
So far all entanglement experiments I have read about, have a single common source, usually a pump laser passed through a BBO crystal. Can anyone provide references for actual experiments that demonstrate entanglement of particles that have never interacted or demonstrates that particles that were not entangled before detection, become entangled after detection?
And of course there is the entanglement of identical particles, which usually doesn't do much but can change the energy of a multi-electron atom (there's the "exchange energy" when the requirement that the exchange of fermions should change the sign of the wavefunction, from whence also comes the Pauli exclusion principle). So for example, when a new electron that just got created, say in a pair creation episode, arrives in a white dwarf, it immediately encounters degeneracy pressure because of its entanglement with all the other electrons already there. Of course, the above language is fundamentally incorrect because it pretends we can say which is the electron that is the new arrival, which in fact we cannot-- it gets lost in a sea of indistinguishable electrons, which is one of the most prevalent forms of entanglement. I would say it requires no "interaction" for it to be present, it is an expression of the fact that at some level, the creation of any new electron makes reference to whatever information is contained in the entire electron distribution everywhere in the universe, in the sense that no individual electron is allowed to carry its "own information" independently of all those others, since they are all indistinguishable.
ThomasT said:
These papers were referenced in DrC's Entangled "Frankenstein" Photons paper:
T. Jennewein, G. Weihs, J. Pan, A. Zeilinger, Experimental Nonlocality Proof of Quantum
Teleportation and Entanglement Swapping (2002).
http://arxiv.org/PS_cache/quant-ph/pdf/0201/0201134v1.pdf
R. Kaltenbaek, R. Prevedel, M. Aspelmeyer, A. Zeilinger, High-fidelity entanglement
swapping with fully independent sources (2008).
http://arxiv.org/PS_cache/arxiv/pdf/0809/0809.3991v3.pdf
regard the first paper it seem that the secuence of the events has no influence on the results, can't change it, the causality it lost.
"Thus depending on Alice’s later measurement, Bob’s earlier results either indicate that photons 0 and 3 were entangled or photons 0 and 1 and photons 2 and 3.
This means that the physical interpretation of his results depends on Alice’s later decision."
FAQ: Entanglement Experiments: Sources & Detection
What is entanglement and how is it created?
Entanglement is a phenomenon in quantum physics where two or more particles become connected in such a way that the state of one particle is dependent on the state of the other particle, even when they are separated by a large distance. Entanglement is created through a process called quantum entanglement, where two particles interact and become correlated with each other.
What are the sources of entangled particles used in experiments?
The most common sources of entangled particles used in experiments are photon pairs produced through various methods such as spontaneous parametric down-conversion, quantum dots, and superconducting devices. These sources generate pairs of photons that are entangled in their polarization or energy levels.
How is entanglement detected in experiments?
Entanglement can be detected through various methods, such as Bell inequality tests or quantum state tomography. In Bell inequality tests, the entangled particles are measured in different ways and the results are compared to see if they violate certain inequalities. In quantum state tomography, the state of the entangled particles is reconstructed by performing measurements in different bases.
What are the applications of entanglement experiments?
Entanglement experiments have a wide range of potential applications, including quantum communication, quantum cryptography, and quantum computing. Entanglement allows for secure communication and information processing, as well as enabling more efficient algorithms for certain computational tasks.
What are the challenges in performing entanglement experiments?
One of the main challenges in performing entanglement experiments is maintaining and controlling the entanglement between particles. This requires precise control over experimental conditions and minimizing external influences that can disrupt the entanglement. Another challenge is the fragility of entanglement, as it can easily be disturbed or lost through interactions with the environment.
