What Is the Best High-Density Liquid That's Cheap and Safe at Room Temperature?
  • Thread starter gothamxi
  • Tags
    Liquid
In summary: Glycerol is not as dense as water, so the pressure head won't be as high. It's also not as non-toxic, so there is a greater risk that it would spill and get into a person's eyes or lungs.
gothamxi
So I am trying to find a liquid at room temp., preferably with a low viscosity, non-toxic and non-acidic, that has a specific gravity greater than 1.5 and is fairly cheap. Tall order?
I have done a little research and my best bets seem to be Copper Sulfate Pentahydrate, Zinc Chloride, or possibly Sodium Hydroxide(but that's caustic). NaCL solutions seem to max out around 1.2-1.3, and sugar solutions around 1.4 at room temp.
I think Copper Sulfate might do the trick, but I cannot figure out what is the highest possible density achievable around room temperature. The specific gravity is 2.284 but it's solubility is pretty low, maybe 300-500g/L?
Does anyone know this off-hand or have other chemical suggestions?
Chemistry news on Phys.org
Hi
You know that Copper Sulfate is toxic.
Yes, but I'm not going to be taking a bath in it or be drinking it. I mean, I don't want something as toxic as mercury. I basically need something that I can survive through if it spills. It will take more than copper sulfate to kill me!
Seriously, though, the non-toxicity is just an added bonus.
Hi
Chloroform its density is 1.483 g/cm3
It's really not much denser than sugar solution. Sugar water doesn't make you pass out if you breath in vapors either. Might be fun though.
Hi
Can you clarify the purpose even offer the assistance required
highly water soluble tungstates such as sodium metatungstate have been traditionally used as high-density liquids. you can get above a specific gravity of 3 easily if i recall correctly using this kind of solution.
True again, but sodium metatungstate goes for like $800/kilo. There is just no pleasing me right?
The idea is to create a low-cost & fairly safe pressure equalizer with a column of fluid. A denser fluid means I can achieve the same pressure head with a shorter column. I don't want the viscosity to be very high because the column may need to rise and fall, and I want that to happen relatively quickly.
It may need to have a volume of about 5-10 liters if I use water.
no. sodium metatungstate is much cheaper than that. that is probably the price from redistributors like Sigma or Alfa selling small quantities.
some data from a distributor:
http://www.heavy-liquid.com/brochure_en.pdf
for example, 50 kg can be had for $1k from this american distributor http://www.alibaba.com/product-free/100628785/Sodium_Tungstate.html which is only $20 per kg
and much cheaper from china and india. also much cheaper if you buy in ton quantities.
but it sounds like you don't need nearly this much. there are no shortage of redistributors who I'm sure would be happy to quote you for, say, 10-20kg or so.
No kidding! I've seen alibaba come up in a lot of searches but it never looked that legitamate. I'll have to look into this.
Still though, does anyone know the max density of copper sulfate pentahydrate solution at room temp. I'm not a chemist and I couldn't find it anywhere. Copper sulfate is pretty easy to obtain.
Try googling barium sulfate.It has a high density and amongst other things is used in barium meals where the patient drinks some of it.
It's insoluble in water and alcohol...
Barium sulFIDE is soluble but..."BaS is quite poisonous, as are related sulfides, such as CaS, which evolve toxic hydrogen sulfide upon contact with water. "
Solubility around 20g/100g of water, density around 1.2 g/mL. It doesn't want to get much higher than that at room temp. Solubility goes up for higher temperatures, so I guess the density of boiling solution can be much higher, but it won't help.
golden syrup,treacle,tomato sauce,non drip paints,long alkane or kenes eg fuel oil.
Too bad about copper sulfate...thanks for the info though (love the hair).
golden syrup/Treacle=slow as molasses+specific gravity of 1.4ish?
tomato sauce and paint will just gum everything up
I don't know any fuels or fuel oils with densities much greater than water. Maybe I just am not looking hard enough?
These are all generally very viscous though which is the opposite of what I am looking for.
Why have you not considered mercury? I'm guessing its either for safety or financial reasons.
Yes exactly. Both are issues really, even though I would only need 1/13th the volume compared to if I used water.
Carbon tetrachloride? Perhaps not the safest substance in the world, but with reasonable care can be acceptable.
I suppose keeping a vat of molten Platinum is out of the question?...
Kidding aside, is there a reason that Glycerol wouldn't work? It's not 1/13th, but it's 1.261 g/cm³ compared to water, it's cheap, and it won't kill you.
wazani said:
Hi
I don't know but from his name I think he may be a colleague of Mr. Bruce Wayne.
In that case, definitely molten platinum.
The other possibility is he is an enemy of Mr. Bruce Wayne. :devil::eek:
What's a really nice green element that isn't radioactive or caustic? :smile:
Gallium?
DrDu said:
Gallium?
I'll take a pound of that, stat! :wink:
P.S. How did I know that I'd get an answer here? :-p
Well, it is certainly not exactly cheap (Ga prices have risen enormously during this year). But alloys like Galinstat (Gallium-Indium-Tin) are liquid down to -19 degrees and have explicitly been designed to replace mercury.
Sorry, I made a promise to a semiconductor that I'd only see Gallium Arsenide... no offense to Ga-Ir-Tin! :wink:
Still... I think you make a good point, and better expensive than lethal.
I guess that's enough off topic discussion. Thread locked. If someone wants to add something ON topic - please contact me by PM.
To add to the topic:
DrDu said:
A cheaper alternative now occurred to me:
A solution of Cesium formate, which is used in oil drilling and has a density of up to 2.4 g/cm^3 for an 80% solution.
FAQ: What Is the Best High-Density Liquid That's Cheap and Safe at Room Temperature?
What is "Cheap high-density liquid"?
Cheap high-density liquid refers to a liquid substance that has a high density but is relatively inexpensive to produce or obtain. It may also be referred to as a low-cost high-density liquid.
What are the properties of cheap high-density liquid?
The properties of cheap high-density liquid vary depending on the specific substance, but in general, it will have a high density, meaning it is more compact and heavy compared to other liquids. It may also have a high viscosity, making it thicker and more resistant to flow. Additionally, it may have a high boiling point and be less volatile.
What are the common uses of cheap high-density liquid?
Cheap high-density liquid has a variety of uses, including in industries such as manufacturing, construction, and transportation. It can be used as a coolant, lubricant, or solvent, and is often found in products such as paints, adhesives, and cleaning solutions.
How is cheap high-density liquid produced?
Cheap high-density liquid can be produced through various methods, such as chemical synthesis, extraction from natural resources, or refining of crude oil. The specific production process will depend on the type of liquid and its intended use.
What are the potential drawbacks of using cheap high-density liquid?
While cheap high-density liquid may be cost-effective, it may also have potential drawbacks. These can include environmental concerns, as some substances may be toxic or harmful if not handled properly. It may also have limited availability or require specialized equipment for handling and storage.
