How do sound and gravity interact?
In summary, sounds are not affected by gravity the same way that light is. The speed of sound depends on the density of the medium and all other things being equal, a greater gravitational field will result in a greater speed of sound.
no idea
93
Is sound affected by gravity/
In a sense, yes. The speed with which sounds moves through a medium depends upon the density of the medium (generally, the more dense the medium, the faster the speed of sound). All other things being equal, a greater gravitational field will result in a greater density and so increase the speed of sound.
Sound is NOT affected by gravity in the same way light is. Sound moves through the physical medium and so depends upon how gravity affects that medium while light moves through the "fabric of space" which is, in sense, gravity itself.
The speed of sound in a gas depends not only on the density, but on the pressure. In fact it depepnds on the ratio of pressure to density, it goes up with increasing pressure, and down with increasing density.
http://hypertextbook.com/physics/waves/sound/
There are several forms of the equation for the speed of sound, the one I'm referring to is:
c = sqrt(gamma * pressure / density)
here gamma is a thermodynamic property of the gas, the adiabatic constant. The pressure and density speak for themselves.
The above equation can also be found in Goldstein, "Classical Mechanics".
For an ideal gas, the ratio of pressure / density depends only on temperature and the molecular weight of the gas.
So on earth, the speed of sound varies with altititude, but this is almost entirely because temperature varies with altitude.
More on the formula for the speed of sound in an ideal gas can be found at:
http://hyperphysics.phy-astr.gsu.edu/hbase/sound/souspe3.html#c1
The most fundamental formula for the speed of sound in a uniform medium is that it is proportional to the square root of the medium's elasitc property, the bulk modulus, divided by its density.
c=sqrt(B/rho)
If you consider the media to be a distributed spring-mass system, the bulk modulus represents the "spring" part of the anology, and the density represents the "mass" part of the anology. It makes a intiutive sense that making the springs stiffer increases the speed of sound, and that making the mass heavier decreases the speed of sound.
One more question here struck me as I read this thread. Is there a particular particle to be associated with sound waves? Because sound waves is essentially energy which causes comp. and rarefractions among the particles around it, and these particles can be anything, water, iron etc. But is there a unique particle to be associated with sound waves? like how photons are associated with light?
Though speed of the sound will increase in the medium with large mass(b`cos of gravity). Will the density of the fields increase the speed ? Let`s say there is air around the huge mass. will the speed of the sound increase in the surrounding region?
HallsofIvy said:
...through the "fabric of space" which is, in sense, gravity itself.
That doesn't feel right to me. I can't quite put my finger on it, but I don't think gravity is spacetime. It just feels wrong. (no offence to anyone)
Gravity to me, feels more like a current that we're caught in; maybe passing through the fabric; I don't know. All I do know for sure is that I know nothing.
I personally think that "spacetime" is like the fabric pulled tight (in some places), and gravity kinda flows, causing ripples and folds in it like a stream would around a scarf.
BTW~ John <--- New guy. I'll finish reading so I can catch up. Nice to meet everybody.
I'm actually looking to find out more about how sound and gravity interact. I'll get back to it now.
Related to How do sound and gravity interact?
1. How does gravity affect the speed of sound?
Gravity does not directly affect the speed of sound. Sound travels at a constant speed in a given medium, such as air or water, regardless of the presence of gravity. However, gravity can indirectly affect the speed of sound by changing the density of the medium, which can alter the speed of sound.
2. Does sound travel differently in areas with varying levels of gravity?
Yes, the speed of sound can vary slightly in areas with different levels of gravity. This is because gravity can affect the density of the medium, which in turn can affect the speed of sound. However, the difference in sound speed due to varying gravity levels is typically very small and not noticeable to the human ear.
3. Can gravity affect the pitch of sound?
No, gravity does not directly affect the pitch of sound. Pitch is determined by the frequency of sound waves, which is not affected by gravity. However, gravity can indirectly affect the pitch by changing the density of the medium and altering the speed of sound, which can then affect the frequency and pitch of the sound.
4. Is sound affected by the gravitational pull of objects in space?
Yes, the gravitational pull of objects in space, such as planets or stars, can affect how sound travels. In the vacuum of space, sound cannot travel as there is no medium for it to travel through. However, in areas with some atmosphere, such as on a planet or moon, the gravitational pull can affect the density of the medium and therefore the speed of sound.
5. Can gravity affect the loudness of sound?
No, gravity does not directly affect the loudness of sound. Loudness is determined by the amplitude of sound waves, which is not affected by gravity. However, gravity can indirectly affect the loudness by changing the density of the medium and altering the speed of sound, which can then affect the amplitude and loudness of the sound.
