The solutions and question make NO SENSE AT ALL
  • Thread starter flyingpig
In summary: So you plug in the information and get the result. There is no minus sign because direction is already accounted for.
flyingpig
2,579
A coil formed by wrapping 50 turns of wire in the shape of a square is positioned in a magnetic field so that the normal to the plane of the coil makes an angle of 30 degrees with the direction of the field. When the magnetic field is increased uniformly from 200uT to 600uT in 0.4s, an emf of magnitude 80mV is induced in the coil. What is the total length of the wire?
solution
http://img163.imageshack.us/img163/5214/73297833.th.png
Uploaded with ImageShack.us
First of all the equation is wrong, shouldn't it be [tex]\varepsilon = -\frac{d\Phi}{dt}[/tex]?
Secondly where did they get 4lN = length from?
Also you can't have "imaginary" length numbers
Geometry? What is l, what is N?
That's what it is. ε = -dΦ/dt, where Φ = BA*cosθ, B is magnetic field strength, A is the area. The cosine is there because you want the area perpendicular to the magnetic field. And if you have a coil with N loops, then Φ = NBA*cosθ. Since the change is uniform, delta can be used instead of d/dt.
l is the side of the square, N is the number of turns
they have used ε = -dΦ/dt
here - is just for direction which you can figure out anyway ... so ignore it
now l is edge length of square ... now as "da_nang" said ... Φ = N B A cosθ
now just rearrange to get l
and perimeter = length of each square = 4l
and there are N squares so total length is 4Nl
what does that mean?
How can you just "get rid of it", I thought the math actually takes care of the minus sign.
- sign tells about direction
- rest about mag
so find mag by formula and direction by lenz law
no need to consider - sign ... it has no mathematical flaw
In other words - you are asked about length of the wire, doesn't matter if it is winded CW or CCW.
Related to The solutions and question make NO SENSE AT ALL
1. What is the purpose of "The solutions and question make NO SENSE AT ALL"?
The phrase "The solutions and question make NO SENSE AT ALL" is nonsensical and has no specific purpose. It may be used as an example of illogical or confusing language.
2. Why is it important to make sense in scientific research?
Sense-making is a crucial aspect of scientific research as it allows for clear and logical understanding of data and findings. Without making sense, research and experiments would lack validity and reliability.
3. How can scientists ensure that their solutions and questions make sense?
Scientists can ensure that their solutions and questions make sense by carefully planning and conducting their experiments, using reliable methods and data, and critically analyzing their findings. Collaboration with other scientists and peer review can also help in ensuring sense-making in research.
4. Can nonsensical research have any value?
While nonsensical research may not have any scientific value, it can still serve a purpose in artistic or creative contexts. It may also be used as a humorous or satirical commentary on scientific practices and language.
5. How can we avoid using nonsensical language in scientific communication?
To avoid using nonsensical language in scientific communication, it is important to be clear, specific, and precise in our language. Avoid using jargon or overly complicated terminology, and always strive for logical and coherent explanations and arguments.
