Relation between Higgs boson and graviton
In summary, the Higgs boson and the graviton are both involved in gravity, with the Higgs carrying mass and the graviton carrying the gravitational interaction. However, the Higgs does not give other particles their mass and does not 'carry mass'. It is the vacuum expectation value of the Higgs field that is responsible for particle masses, not the Higgs boson itself. While there have been alternative theories proposing both the graviton and a spin 0 scalar particle, they have been inconsistent with observation. The purpose of the Higgs is to break electroweak symmetry, but it does not have a specific purpose in nature.
dimsun
27
The graviton (spin 2) and the Higgs boson (spin 0) are both involved in gravity. The Higgs carrying mass, and the graviton carrying the gravitational interaction. On the internet I red that a lot of people wonder if there is a connection.
In electroweak interaction the forces are carried by the photon, the Z and the W's.
In gravity the force is quantum mechanically supposed te be carried by the graviton.
In electroweak interaction the electric and weak charge is transferred by some of the bosons.
The Higgs boson is the carrier of the masscharge and gives the other particles their mass.
If a Higgs boson interacts with a particle then the strength is determined by the restmass of that particle. If a graviton interacts with a particle then the strength is determined by mass and it's momentum forming a four factor. So a Higgs boson will not interact with a photon because a photon has no rest mass. But a graviton will interact with a photon because a photon has momentum.
What is the difference between the Higgs boson and the graviton?
Can the Higgs and the graviton be both part of a bigger model in whicht they are fused into one system, just like the W/Z-bosons and the photon are fused into electroweak interactions?
For example the graviton compared to the photon and the Higgs compared to the W+ and W-.
For gravity you can forget about any special role played by ther Higgs. Gravity (classically) couples to the energy-momentum tensor to which ALL fields (including massless fields) contribute; gravity does NOT only couple to mass.
The Higgs field looks special only if you split it into its vacuum expectation value plus its fluctuations (= the Higgs particles). But if you do not split the field it looks like an ordinary scalar field and its contribution to the energy-momentum tensor is by no means special.
The graviton (spin 2) and the Higgs boson (spin 0) are both involved in gravity. The Higgs carrying mass, and the graviton carrying the gravitational interaction. On the internet I red that a lot of people wonder if there is a connection. The Higgs boson is the carrier of the masscharge and gives the other particles their mass.
dimsum, unfortunately many of the things you read in the media may give this impression. The Higgs boson has nothing to do with gravity. It does not give other particles their mass, and does not 'carry mass', whatever that means. There have been alternative theories of gravity proposed that include both the spin 2 graviton and a spin 0 scalar particle, but they have been shown to be inconsistent with observation. Note that such a scalar must be massless if you want it to have a long range effect, which the Higgs is not. With a mass at least 115 GeV the interaction of the Higgs with the mass of other particles would only have a range of about 10-16 cm. The purpose of the Higgs is not to 'carry mass' but to break electroweak symmetry.
Mass belongs to the gravitomagnetic system while the other charges, like electric charge, weak charge and color charge do not. Mass generates gravity, so what do you mean?
Is it better to say that the higgs boson generates the masses of the vector bosons? Or can you explain what you mean?
So there are others speculating the same idea.
This is very interesting, because the quanta of the Yang Mills field must also be massless. Because a lot of particles have mass, the Higgs mechanism was invented. So turn it the other way around, if for some reason we first found the heavy Higgs particle. That is not in accordance with the theory you referred to above. So to explain why the Higgs has mass, unlike the theory you refer to, we could explain that by making a model with heavy W+ and W- and Z bosons. It is the chicken or the egg problem.
In nature nothing has a purpose. You can't say that even when some phycisist or mathematicians invents a theory or model with a pecular mechanism to explain something, that it has a purpose. So if the Higgs will be found, then it is part of nature. And we have to model that.
dimsun said:
Mass generates gravity, ...
As I already said: it's energy-momentum that acts as a source for gravity and every field contributes to the energy-momentum tensor, not only the Higgs and not only massive particles. There is absolutely nothing special regarding the contribution of the Higgs field or other massive particles.
Almost wrong. The interaction with the Higgs field give particles their mass.
I think what Bill_K wants to say is that it's the vacuum expectation value of the Higgs field that is responsible for the particle masses. But the Higgs boson is not the vacuum expectation value but a "quantized fluctuation" on top of this vacuum expectation value.
Therefore it's correct that the Higgs boson has nothing to do with the article masses; the masses are due to the coupling to the Higgs field.
Indeed, even though "nothing to do with particle masses" is quite a strong statement for a particle which comes from the excitation of the field which give the particles their mass.
I think you're still misunderstanding the point. The excitations of the Higgs field around the vacuum expectation value is *not* what gives particles mass! The vacuum expectation value itself (which arises from a Higgs self-interaction) and other fields' coupling to this expectation value is what gives particles in the SM inertial mass.
Furthermore, as people have repeatedly tried to make clear, none of these things have a direct relation to gravitation, in which it is the combined energy-momentum tensor which couples. In addition, there are sometimes (esp. for symmetry broken gauge fields) a selection of energy-momentum tensors which may be employed --- mathematically these correspond to addition of total derivatives onto the Lagrangian, and do not alter the dynamics.
I believe that it is you who did not understand me.
True, it is not the excitation that give the particles their mass, it is the vacuum expectation value. However, I would say that the statement that the Higgs has nothing to do with gravity and not give particle masses is misleading in such a general discussion.
As I said several times: massless photons, massive quarks, Higgs bosons etc. all contribute to gravity. There is nothing special about any of these particles and/or fields.
Related to Relation between Higgs boson and graviton
1. What is the relation between the Higgs boson and the graviton?
The Higgs boson and the graviton are both elementary particles that are predicted by the Standard Model of particle physics. The Higgs boson is responsible for giving mass to all other particles, while the graviton is the hypothetical particle that carries the force of gravity. Therefore, the Higgs boson and the graviton are related through their roles in the fundamental forces of nature.
2. How does the Higgs boson interact with the graviton?
The Higgs boson and the graviton do not directly interact with each other. The Higgs boson interacts with other particles through the Higgs field, while the graviton interacts with other particles through the force of gravity. However, the Higgs field is thought to play a role in the mechanism of how gravity works, which could suggest an indirect interaction between the Higgs boson and the graviton.
3. Can the Higgs boson and the graviton be observed or detected?
The Higgs boson was first observed in 2012 at the Large Hadron Collider (LHC) in Switzerland. However, the graviton has not yet been directly observed or detected. It is a hypothetical particle that is predicted by theories of quantum gravity, but experiments to detect it are still ongoing.
4. How does the existence of the Higgs boson affect our understanding of gravity?
The discovery of the Higgs boson confirmed the existence of the Higgs field, which is thought to play a role in the mechanism of how particles acquire mass. This has implications for our understanding of gravity, as it suggests that the Higgs field may also play a role in the mechanism of how gravity works. However, further research and experiments are needed to fully understand this relationship.
5. Are there any current theories or research on the relation between the Higgs boson and the graviton?
There are many theories and ongoing research on the relation between the Higgs boson and the graviton. Some theories propose that the Higgs boson may be related to the graviton through the process of spontaneous symmetry breaking, while others suggest that the Higgs field may be a crucial component in the unification of all fundamental forces, including gravity. The LHC and other experiments are continuing to study and gather data on these potential connections between the Higgs boson and the graviton.
