Conservation Laws vs a Spinning 'Disk Brake'
In summary, the conversation discusses the possibility of violating conservation of energy and momentum using a spinning hollow right circular cylinder and a modified disc 'brake' setup. The first experiment is revised to include finite compressibility, leading to the conclusion that by applying transverse pressure, an overbalancing wheel can be created. The second experiment involves a cyclical process that results in a net gain in angular momentum and rotational kinetic energy. However, this violates conservation of linear momentum in any other inertial frame. It is also noted that the forces at the compression point are not truly horizontal, which can lead to a slowing of rotation. The use of high-end math theorems is discouraged unless specifically applicable to the scenarios discussed.
Q-reeus
1,115
A while back I piggy-backed onto another thread (and then withdrew it as being out of place) an example of a system possibly violating the conservation of energy and momentum (angular momentum directly) - a spinning hollow right circular cylinder placed under frictionless axial compression. Many of you will remember it, but only one attempt at a detailed response was offered, and no firm conclusion. Anyway, by means of a cyclical process exploiting the path-dependent system properties, it was argued angular momentum and kinetic energy could be built up indefinitely - all by exploiting the Relativistic properties of pressure applied to a solid transverse to the direction of motion. A simplifying assumption was notional 'incompressibility' of the cylinder, which although used in many such gedanken experiments without any fuss, might owing to the 'controversial' conclusions, be somehow considered suspect here (and indeed finite compressibility does admit to a counteracting effect, but not one that 'balances the books'). So now for mark II - finite compressibility allowed, and where now both continuous and cyclical 'violation of fundamental physics' seem possible:
Consider then a typical disc 'brake' setup, modified in that the pair of 'brake' pads that clamp with equal and opposite force to the flat surfaces of the disk, are notionally frictionless; functioning to apply transverse pressure to the disk area under the pads but inducing no appreciable braking torque. Take the disk rotation axis as horizontal, and the pads placed such that a line drawn between their center of pressure and the disk spin axis connects horizontally also. Initially suppose the disk is unclamped and spun up to some constant rotational speed. Earth's gravity acts on the disk but by symmetry there is no resultant torque about the spin axis. Now apply transverse pressure via the pair of pads. Compressive stress and strain acts on the patch of disk under the pads, so therefore an appreciable elastic energy density over some volume, hence an increased mass, proportionally essentially to the square of the applied pressure. Additionally, there is formally at least an additional contribution from the first power of the transverse pressure alone, independent of any elastic deformation. So we have in effect an 'overbalancing wheel' - via transverse pressure there is induced more mass on one side of the disc than the other. Coupled to Earth's gravity this gives rise to a steady torque about the spin axis and thus rotational free
energy' - depending of course on the rotational sense. That's the steady part.
As for the rotating cylinder first mentioned, we could also arrange a cyclical process in which the disk is spun up unstressed and then spun down stressed. Taking advantage now of the increased inertial mass when stressed there is a net gain in both angular momentum and rotational KE per cycle. And given that the system as a whole is gaining mass/energy, clearly in any other inertial frame conservation of linear momentum fails, and angular momentum becomes completely arbitrary.
One might initially entertain one further 'violation' - in the steady rotation regime the patch of increased mass is subject to continual centripetal acceleration and centrifugal force, suggesting the system will move off in direct violation of conservation of linear momentum in that frame. However we note that there will be 'fringing' at the leading and trailing parts of the transverse stress field induced in the disk - hence symmetrically disposed longitudinal components of stress exist. Formally then we suppose these longitudinal components allow 'back reaction' forces at the entry and exit regions according to Fbr = -dp/dt = -v*dm/dt (m being that from integrating over the non-uniformly stressed regions), which although equal in magnitude by symmetry, are not exactly collinear, and so a net resultant opposes the centrifugal part. An exact analysis would not be easy, and full cancellation is only a hypothesis here. Given what else here does not seem to hold 'as expected', there may be room for some doubt!
Wow, so is there some obvious flaw to all this? Constructive feedback welcome but please, avoid using high-end maths theorems unless they are applied to the specifics of the scenarios given above. :zzz:
Your error consists in assuming that the forces at the compression point are horizontal. The motion of the disc at that point is downward. Above the point the disc is uncompressed, and compressed below it. To become compressed, it must be forcibly driven through the point. The brakes will have to exert a force with a small upward component, and this will tend to slow the rotation.
It would be helpful to indicate to which part of my entry is being discussed, but I will take a reasonable guess and say it is the middle portion dealing with steady rotation of a clamped disk acted on by gravity. True there must be strain associated with stress, and so the disc under the pads takes on, very very slightly, an 'hour-glass' shape. But it is symmetric - repulsive forces one end is balanced by oppositely acting repulsive forces the other. The unstated assumption here was that the disk material experiences no hysteresis - no internal friction. Hence the flow of matter through the stressed region is conservative wrt purely elastic deformations. To assume otherwise then flow of a notionally inviscid fluid within a vertical tube section having a Venturi shaped portion would also experience a net upward force - violating the conservation of energy purely at the Newtonian level! Sorry, but off to bed.
Q-reeus said:
Anyway, by means of a cyclical process exploiting the path-dependent system properties, it was argued angular momentum and kinetic energy could be built up indefinitely ... so is there some obvious flaw to all this?
Yes, it violates the conservation of energy and momentum. Discussions of perpetual motion machines are aginst the rules of this forum.
Related to Conservation Laws vs a Spinning 'Disk Brake'
What are conservation laws?
Conservation laws are fundamental principles in physics that state that certain physical quantities, such as energy, momentum, and angular momentum, remain constant in a closed system. This means that they cannot be created or destroyed, but can only be transferred or converted into other forms.
What is a spinning "disk brake"?
A spinning "disk brake" is a mechanical device used to slow down or stop the rotation of a spinning disk or wheel. It works by applying friction or resistance to the spinning disk, which causes it to slow down and eventually come to a stop.
How do conservation laws apply to a spinning "disk brake"?
Conservation laws apply to a spinning "disk brake" because they dictate that the total energy and momentum of the system must remain constant. This means that the energy and momentum of the spinning disk must be transferred to the brake in order for it to slow down or stop.
What happens to the energy of the spinning disk when the "disk brake" is applied?
When the "disk brake" is applied, the friction and resistance between the brake and the spinning disk causes a transfer of energy from the disk to the brake. This causes the disk to slow down and eventually come to a stop, while the brake heats up due to the conversion of kinetic energy.
What is the role of conservation of angular momentum in a spinning "disk brake"?
Conservation of angular momentum states that the total angular momentum of a system remains constant in the absence of external torques. In the case of a spinning "disk brake", the angular momentum of the spinning disk is transferred to the brake, causing it to slow down and eventually stop. This conservation law helps to explain why the disk does not suddenly stop rotating when the brake is applied, but instead slows down gradually.
