Understanding Point Particles: The Mainstream Physics Perspective
In summary, at the subatomic level, particles such as electrons and quarks are considered to be point-like objects, with no discernible structure at the shortest distances we have been able to probe. While some theories propose that these particles may have some structure at higher energies, current mainstream physics accepts them as point particles. However, there are concerns about the consistency of treating particles as points, as it may violate principles such as relativity. String theory proposes that particles are actually 1-dimensional strings, rather than 0-dimensional points. There are also fundamental limits, such as the Planck scale, which suggest that there may be a bottom level of structure that we cannot probe. While recent experiments have shown spherical symmetry in electrons to a high degree
Physics-Learner
297
hi,
there seems to be some conflicting information when i do research on the net. point particles consist of electrons, quarks, and some others.
but many articles say they don't take up space. that i don't buy. i can buy that we haven't or even can't uncover what sort of shape they really have.
but to me, a point is just a mathematical construct.
what is the accepted mainstream physics belief in this regard ?
At the subatomic level there is nothing that is more correct than mathematical constructs. We can measure the influence of the particles forces, such as the electromagnetic force coming from an electron, but where do you draw the "boundary" for the particle? In fact, there is no such thing. An electron is not a tiny sphere. It is a wave packet. It has uncertainty in position and momentum at all times. Yet at the same time, this wave packet occupies a volume of space. Does this volume of space constitute the boundaries of the electron? I can't say.
The particles we regard as elementary - electrons, quarks, etc - are, as far as we can tell, point objects. That is to say, at the shortest distances we have been able to probe they have no discernible structure. Shortest distance corresponds to highest energy, and the energy reached by the large Hadron Collider of 7 TeV corresponds to a distance of about 10-18 cm.
You can either accept that they are really points, or you can hope that at a higher energy some structure will emerge. Maybe they are bound states of other, even more fundamental, point particles. If not, then you will then have to wonder how to describe an extended object mathematically, because quantum field theory only describes point objects. For a particle with finite size you'll have trouble maintaining consistency with relativity, because if an electron has structure, light will take a finite amount of time to get from one side of it to the other. When it interacts with a photon say, there will be a time lag before the other side can become aware. What happens in the meantime? You'll need to invent a quantum theory that is nonlocal. And then after that you'll still need to describe whatever material the electron is made of.
This could turn out to be the case as we probe shorter and shorter distances, but no one is holding his breath. So far, treating elementary particles as point particles is quite satisfactory.
Agree with all the above, but would like to add the following. While current particle theory considers particles to be point-like and experiments have not shown otherwise, in certain circumstances one can sensibly talk about the 'dimensions' of a particle. For example, the minimum uncertainty wavefunction has a wavelength
[tex]\lambda = \frac{h}{mc}[/tex].
This is known as the particle's Compton wavelength. If you try to localize the particle within a smaller region, then the momentum [itex]p > mc[/itex] and pair production will result. So the Compton wavelength can be considered the smallest effective region within which a single particle state can be localized.
An interesting recent study came out claiming that electrons were almost perfect little spheres:http://www.wired.com/wiredscience/2011/05/electrons-are-near-perfect-spheres/" . I take some issue with this story because it's been embellished a bit for the popular science media -- from what I can tell, the group did not (could not) conclude the shape of the electron based on their experimental setup and findings. They found instead that the electron possessed spherical symmetry to a high degree of precision. This is an excellent result, but does not imply that electrons are indeed spherical -- in fact, a point-like mass is also spherically symmetric.
And don't forget about our friend string theory, which proposes that fundamental particles are 1 dimensional strings rather than 0-dimensional points.
So the Compton wavelength can be considered the smallest effective region within which a single particle state can be localized..
Yes, but it's not the size of the particle. Note that due to the 1/m, neutrinos, which are believed to be point particles, have the largest Compton wavelength of all. With a mass estimated as a fraction of an eV, the Compton wavelength of the electron neutrino is about 1000 times as big as an atom. Axions, if they exist, are hypothesized to have a mass in the μeV range, implying a Compton wavelength the size of a pingpong ball.
Bill_K has given an excellent answer. A few more random points to add to what he said:
String theory is what you get when you try to make a quantum-mechanical theory in which the fundamental particles *aren't* pointlike.
Bill_K gives an argument that finite size is inconsistent with relativity, but zero size is also inconsistent with (classical) relativity. Pointlike objects in relativity are black holes. Classically, a spinning, charged black hole has constraints on its angular momentum and its charge in relation to its mass. Otherwise, there is no event horizon, and we have a naked singularity rather than a black hole. An electron violates both of these limits, but we don't observe that electrons have the properties predicted for these naked singularities. For example, naked singularities have closed timelike curves in the spacetime surrounding them, which would violate causality, but there is no evidence that electrons cause causality violation. When you add in quantum mechanics, you get a different story, but we still end up unable to create a complete and self-consistent picture -- hence part of the motivation for string theory.
Historically, we've kept probing higher and higher energies, which revealed more and more structure inside of the previously known structures. By default, one would imagine that this could continue forever, and there would be no way, even in principle, to prove that we had finally found the deepest level of structure. However, there are fundamental reasons for believing that the process has to bottom out at the Planck scale.
-Ben
Yes, thanks for pointing this out. These cases would fall outside my caveat of "under certain circumstances..." The answer to the OP's question was given by you guys -- particles are represented as 0-dimensional points in the Standard Model, and experiments have not shown otherwise. Just trying to add a little color to the discussion by pointing out that in some cases, the Compton wavelength can be understood as the effective 'size' of the particle. What I have in mind is the scale on which gravitational effects become relevant in a quantum system: if the Compton wavelength of a particle becomes smaller than its Schwarzschild radius, then it will collapse into a black hole. The usefulness of the Compton wavelength as representing the size of the particle in this case derives from analogy with macroscopic objects.
thanks for the posts.
FOlks, some of ye may have seen this article.
http://www.sciencedaily.com/releases/2011/06/110629132544.htm
based on this thread that particles have no discernible structure found yet how did they isolate this electron and examine it?
I thought no-one has ever seen an electron becasue of the uncertainty principle etc...
Are they examining the electron indirectly by measuring its energy it emits or something?
I am not clear on this...thanks
What does detecting an electron has anything to do with its lack of structure? After all, an electron has one very EASILY detected feature - it's charge!
I will also direct you to a recent experiment that tries to detect if an electron has an electric dipole under an external E-field. A detection of such a dipole is an indication that an electron could have a "volume" or an internal structure. And guess what? No such dipole was detected!
https://www.physicsforums.com/showpost.php?p=3323535&postcount=135
Zz.
Thank you ZapperZ :-)
FAQ: Understanding Point Particles: The Mainstream Physics Perspective
What are point particles?
Point particles are hypothetical objects in physics that are considered to have no spatial extension or size. They are often described as mathematical points with no physical dimensions.
How are point particles different from regular particles?
Regular particles, such as atoms and molecules, have a defined size and shape. Point particles, on the other hand, are considered to have no size or shape. They are purely theoretical and are used to simplify calculations in physics.
Can point particles be observed or measured?
No, point particles cannot be observed or measured directly. This is because they are considered to have no physical dimensions. However, their effects can be observed and measured through their interactions with other particles.
How do point particles fit into the mainstream physics perspective?
Point particles are a fundamental concept in mainstream physics and are used in various theories and models, such as the Standard Model and quantum mechanics. They are considered to be the building blocks of matter and play a crucial role in understanding the behavior of particles at a subatomic level.
Are there any limitations to the concept of point particles?
Yes, there are some limitations to the concept of point particles. For instance, they do not take into account the effects of gravity, and the concept breaks down at extremely small scales, such as at the Planck length. Additionally, some theories, such as string theory, propose that particles may have a tiny but finite size.
