How can light have momentum if it has zero mass?
In fact, the equation does not apply to massless objects at all (because if ##m_0=0##, ##p## cannot be defined in the first place). So the correct answer is given by De Broglie's equation, which is derived from the correct equation I mentioned earlier.In summary, the relativistic expression for the momentum of a massive particle is p=mγv. However, this equation cannot be directly applied to massless particles like light, as they always travel at the speed of light and have infinite gamma values. The correct equation for photons is p=E/c, which takes into account the frequency of the photon. This is derived from the universal equation E^2=p^2c^2+m^2
bcrowell
Staff Emeritus
Insights Author
431
The relativistic expression for the momentum of a massive particle is p=mγv. It's possible to get confused if one tries to apply this to a particle with zero mass, since it seems as though the result would have to be zero, and yet we know based on Maxwell's equations that light has momentum. (For example, let a light wave strike an ohmic surface perpendicularly. The electric field excites oscillating currents, and the magnetic field makes a force on these currents that is shown by the right-hand rule to be in the direction of propagation.)
The resolution of the apparent contradiction is that massless particles always travel at c, and γ approaches infinity as v approaches c. That means that mγv can't be evaluated simply by plugging in values for the variables. One could instead use calculus to take the appropriate limit. An easier approach is to use the relation m2=E2-p2 (in units with c=1), which relates a particle's mass, total mass-energy, and momentum. This equation is valid for both zero and nonzero values of m. The result for m=0 is p=E (or, in units with c≠1, p=E/c), which agrees with Maxwell's equations.
The following forum members have contributed to this FAQ:
bcrowell
Space news on Phys.org
bcrowell said:
p=mγv
I don't understand this equation, maybe because it is written as text. Can you please edit your post and clarify it?
Is this more recognizable? $$p = m \gamma v = \frac{mv}{\sqrt{1-v^2/c^2}}$$
The letter in the middle is lower-case Greek "gamma".
Likes afcsimoes
Thank you. It's perfect. Previously gama was dificult to read correctly
Ir seams like Y
According to this formula, the momentum of a light photon is infinity as v=c. This can't be right! De Broglie's formula is p = c/lambda which gives photons a definite momentum.
The formula is valid for massive particles. Photons are massless. The universal relation is ##E^2 = p^2c^2 + m^2 c^4##.
Likes TheArun
The formula actually gives a "correct" answer even for light, but it's not "useful". Here's why:
If you substitute ##m_0 = 0 ## and ##v=c## into the equation, you get an indeterminate, ##p=\frac{0}{0}## . This means that there is no unique answer (every number satisfies this equation) for the momentum if the only information we know is that the rest mass is zero and speed of propagation of the object in an inertial frame is ##c##. This corresponds to reality - all photons have zero rest mass and travel at ##c## (as measured in inertial frames), but they all don't have identical momentum (they theoretically can have any value [classically at least, I don't know if QFT places any restrictions on its values]). Just the mass and velocity do not give us a definite answer in this case, so some other factor must come into picture (a variable not included in the equation ##p=\gamma m_0 v##) which determines the momentum, and this is of course the frequency of the photon, which is included in the well known equation ##E=hf##. Applying De Broglie's hypothesis gives us ##p=\frac{hf}{c}##.
So in a strict sense, the equation ##p=\gamma m_0 v## doesn't give a "wrong" answer when applied to light, it just doesn't give a unique/useful answer.
FAQ: How can light have momentum if it has zero mass?
According to Einstein's theory of relativity, energy and mass are equivalent and can be converted into each other. Light, being a form of energy, has momentum even though it has zero rest mass.
What is the formula for calculating the momentum of light?
The formula for calculating the momentum of light is p = E/c, where p is momentum, E is energy, and c is the speed of light. This formula also applies to particles with zero rest mass, such as photons.
How can light transfer its momentum to objects?
When light interacts with an object, it exerts a force on the object, transferring its momentum. This can be seen in phenomena such as radiation pressure, where light particles transfer their momentum to the surface of an object, causing it to move.
Can light have different momentums?
Yes, light can have different momentums depending on its energy and frequency. The higher the energy or frequency of light, the greater its momentum. This is also seen in the particle-wave duality of light, where photons can have both particle-like and wave-like properties.
How does the momentum of light affect its behavior?
The momentum of light plays a crucial role in its behavior, such as in the phenomenon of diffraction and refraction. The momentum of light also determines its direction and speed when traveling through different mediums, as well as its ability to transfer its momentum to objects it interacts with.
