Can ice go below zero degrees C?
In summary, when an object reaches absolute zero, all of its physical vibrations stop. Its atoms will smear out into a Bose-Einstein Condensate and all of its electrons will be in the ground state.
deepthishan
38
What happens at -273 oC?
(everything under 1atm)
I know about the cooling curve but just wondering what would happen to substances at absolute zero- does the temperature keep reducing/get harder?
Also, how do gases stay in gaseous form in outer space?
Many thanks in advance! :)
nothing much, all kind of vibrations stop. all its electrons will be in the ground state. that's what happens when an object reaches absolute zero.
No.
No physical substance can reach absolute zero. And even near zero, the very substance will change dramatically. Its atoms will smear out into a Bose-Einsteinian Condensate.
Gas is the default state in vacuum. Unbound Solids and liquids can only stay that way when under pressure. Remove the pressure and there's nothing to keep the individual atoms from simply floating away.
Yes, ice can go below 0C.
Just for future reference:
It is not a good idea to ask one question in the title then ask another in the text. You will get much better threads if you just ask 1 question at a time.
Integral
Integral
I suspect he meant 0 K in the title, but found he couldn't change it afterward...
I politely disagree. All sorts of fun things happen near absolute zero: superconductivity, bose-einstein condensation, superfluidity.
As some one stated, below 0ºC the ice can, below -273ºC or 0ºK it can't.
to be fair near -273 it starts doing cool things but I believe it never will reaches 0k as it will be against the Uncertainty principle.
sorry i wasn't clear, when i was explaining what all happens at 0k i meant what would happen if a substance can actually go to 0k. zero entropy concept. and also tell me one thing, if no material can go to zero then the concept of "residual entropy" purely theoretical ??
Why explain what would happen in the case of something that can't happen?
You were clear; it was just wrong.
Residual entropy is indicative of a frustrated system which will likely have an interesting T=0 quantum phase diagram. It is true that the 3rd law of thermodynamics prevents actually achieving T=0, however, it can be shown that these quantum phases will survive into the T>0 region provided h*omega >> k*T (where omega is usually said to be something like the energy of the elementary excitations). The beauty is that the math is much easier when T=0 so you work the theory there and then know it will hold for some region T>0. That's why we care about things like residual entropy despite T=0 being unphysical
It's pretty common to say that absolute zero can't exist since temperature is the average kinetic energy and Heisenberg's unceratinty... etc. However, the impossibility of absolute zero was known well before quantum mechanics and is simply a result of thermodynamics.
The 3rd law is often phrase in terms of entropy (often incorrectly stated as "the entropy goes to zero at T=0") however, even without residual entropy when ever there is a degenerate ground-state you're going to have a non-zero (though tiny) T=0 entropy. Thus I've always found a stronger condition for the 3rd law follows from considering the following definition of entropy:
[tex]S = S_0 + \int \frac{C_x}{T} dT. [/tex]
Looking here was see that the only way the integral converges at T=0 is if the SPECIFIC HEAT goes to zero. I find this a nicer formulation of the 3rd law and it also makes the impossibility of achieving T=0 intuitive. If one imagines cooling a system by taking heat out of it we see that one would need to take out an infinite amount of energy since the specific heat goes to zero, to lower the temperature to zero. Also the closer you get the harder it gets.
Related to Can ice go below zero degrees C?
1. Can ice go below zero degrees C?
Yes, ice can go below zero degrees Celsius. In fact, ice will continue to decrease in temperature until it reaches its freezing point of -273.15 degrees Celsius (or 0 Kelvin).
2. How is it possible for ice to be below zero degrees C?
This phenomenon is known as supercooling. When pure water is in a very clean container and is cooled below its freezing point without any disturbance, it can remain liquid until it reaches a temperature of around -42 degrees Celsius. At this point, it will rapidly freeze into ice.
3. Why does salt make ice melt?
Salt lowers the freezing point of water, making it harder for water to freeze. This is because salt molecules disrupt the formation of ice crystals, causing the freezing point to decrease. This is why salt is often used on roads to melt ice and snow.
4. Can you make ice colder than zero degrees C?
Yes, it is possible to make ice colder than zero degrees Celsius by using special techniques such as supercooling or adding a substance like salt to lower the freezing point. However, once the ice is disturbed or comes into contact with something else, it will freeze at its normal freezing point of zero degrees Celsius.
5. What happens to ice below zero degrees C?
Below zero degrees Celsius, ice will continue to decrease in temperature until it reaches its freezing point of -273.15 degrees Celsius (or 0 Kelvin). At this point, the molecules in the ice will stop moving and the ice will become a solid, with no further decrease in temperature possible.
13K
  • DIY Projects
  • Other Physics Topics
