How Fast Must a Golf Ball Travel to Avoid a Windmill Blade?
  • Thread starter NotaPhysicsMan
In summary, the conversation discusses a physics problem involving a golf ball passing through a windmill at a miniature golf course. The windmill has 8 blades and rotates at an angular speed of 1.25 rad/s clockwise. The diameter of the golf ball is given and the question is to find the minimum speed of the ball so that it will not be hit by the next blade. The conversation discusses different approaches to solve the problem, including finding the time for the blade to rotate and the arc length of the opening between blades. It is also suggested to use the formula v=rw to calculate the minimum speed of the ball. The final conclusion is that the ball must travel its diameter in order to pass through the gap safely, and the
NotaPhysicsMan
146
Hey, any ideas on this double starred, hard question :(
A golf ball passing trhough a windmill at a miniature golf course. The windmill has 8 blades and rotates at an angular speed of 1.25 rad/s clockwise. The opening between successive blades is equal to the width of a blade. A golf ball of diameter 4.50x10^-2 m is just passing by one of the rotating blades. What must be the minimum speed of the ball so that it will not be hit by the next blade?
Ok, my thought is, I need to find time for a blade to rotate theta, and I need the arc length for that. With arc length I have some way to compare the diameter and the space opening between the ball and blade. Lost from that point...
Any ideas, Great!
How far does the ball have to travel?
How big (as an angle) are the gaps in the windmill?
Ok, knowing w, I think I can use theta= w(avg) x time . I don't have time. I have 1.25rad/s. Hold it is this approach right. Ok I have 1.25 rad, 2pie is a full revolution or 360 degrees. There is a 5.02 factor between 1.25 rad and 2 pie. Ok, 1.25 rad is equal to 71.61 degrees. I multiply that by 5.026 and divide by 16 (total equal proportions including space and blade) and I get roughly 22.5 degrees for each gap?
As for how far does the ball have to travel, is that relevant? I mean it just has to travel pass the width of the blade.
You should be looking at things like: There are 8 blades, so there are 8 gaps. That means that each gap is going to be 1/16 of a revolution, or an angle of [tex]\frac{2\pi}{16}=\frac{\pi}{8}[/tex].
Then you can determine the time that the windmill takes to turn that far and so on.
ok, so my way was also corrrect than ... 22.5 degrees is equal 0.39 rad which is equal to pie/8. Now for the next part, time. I'm thinking we can use theta= 1/2 (w avg )t. Since the mill will spin always at 1.25 rad/s the w avg is still 1.25rad/s. Theta = 0.39 rad, I substitute and solve for t.
t = 0.628 s.
Thinking...
ok I figure: need the angular velocity of ball (w) then we could use this value and substitute it into V=rw? so diameter we know is 0.0450, d/2 = r. So, w = theta/time. So, 0.39/0.628 gives 0.621 rad/s. Substitute it into V=rw, V=0.01397m/s?
[tex]\theta=\omega_{avg}t [/tex]
(There's no [tex]\frac{1}{2}[/tex] you may be thinking of [tex]\theta=\alpha_{avg}t[/tex].)
Which will change your time.
Then the ball needs to travel it's diameter in the time. so [tex]v=\frac{d}{t}[/tex]
(This would be a lot easier to explain with drawings.)
Everything sounds good, except I'm not sure I understand the concept, the ball needs to travel it's diameter?
I can try to do ascii art:
Imagine you're looking at the windmill from the top
Then the beginning of the ball crossing will look like this
Code:
 |  Blade (moving down on screen)
o|--> (Ball about to cross)
 | Blade (moving down)
And the end of the ball crossing will look like
Code:
 |o--> (Ball having crossed)
So, if the ball barely scrapes the tail end of the blade before it starts crossing, and barely gets scraped by the blade at the end of the crossing, then it's traveled it's diameter in distance.
Well, the diagrams make some sense, excpet I don't see how both parts of the mill can move down, shouldn't it be rotating so that one side goes up while the other comes down. But yes, I get it now, I thought it was the travel distance before and reaches the mill plus the distance to get pass it.
Thanks!
I was only drawing the bottom parts of the mill that interact with the ball.
If I could remember correctly, this is a question from "Cutnell & Johnson Physics", right? For the golf ball to pass through the gap of the windmill with minimum speed, it must be at the beginning of the open gap before going through it as suggested by the diagram. The distance traveled is the diameter of the ball because this is the minimum distance the ball must travel in order to get itself pass through the gap. From the question, we know the angular speed and can find the angular displacement easily. From these infos, we can work out the time needed for the blade to sweep out the open gap. The time needed here is equal to the time needed for the ball to travel through the gap. Knowing the displament of the ball which is the diameter and the time, we can then calculate the minimum speed of the ball.
Yup Cutnell and Johnson, and thanks for making it even more clear lol, esp the distance/diameter traveled by ball, was a tad fuzzy.
Related to How Fast Must a Golf Ball Travel to Avoid a Windmill Blade?
1. How do I begin my research project?
To start your research project, it is important to first identify your topic and research question. You can then conduct background research to gather information and create a plan for your project. It may also be helpful to consult with a mentor or supervisor for guidance and advice.
2. What are some strategies for organizing my research?
There are several strategies for organizing your research, such as creating an outline or using a note-taking system. You can also group similar information together and use headings or subheadings to categorize your findings. It is also important to keep track of your sources and cite them properly.
3. How can I narrow down my topic?
To narrow down your topic, you can consider the scope and focus of your research question. You can also limit your topic by time period, geographic location, or specific aspects of the subject. Additionally, you can consult with your mentor or supervisor for suggestions on how to narrow down your topic.
4. What resources should I use for my research?
The resources you use for your research will depend on your topic and research question. Some common resources include books, scholarly articles, databases, and websites. It is important to critically evaluate your sources for accuracy, relevance, and credibility.
5. How do I stay organized and on track with my research?
To stay organized and on track with your research, it can be helpful to create a timeline or schedule for completing different tasks. You can also break down your project into smaller, manageable tasks and set deadlines for each one. Staying focused and maintaining a positive attitude can also help you stay on track with your research.
