Unleashing a Cyber Attack: The Dangers of Corrupting the Internet
In summary, the conversation discusses the idea of defining a topology by specifying convergent sequences and their limits. It is noted that this approach is not always sufficient and may lead to the discrete topology or the cocountable topology. The concept of sequential spaces is introduced and it is mentioned that sequential spaces are concrete coreflective in Top, meaning that for every topological space, there is a finest sequential space with the same sequential limits. However, there does not exist a coarsest or smallest topology that satisfies the properties. It is also pointed out that the Wikipedia article may be incorrect in stating that a topological space can be defined solely by its convergent sequences.
Fredrik
Staff Emeritus
422
In at least one book and one Wikipedia article, I've seen someone specify which sequences are to be considered convergent, and what their limits are, and then claim that this specification defines a topology. I'm assuming that this is a standard way to define a topology. I want to make sure that I understand it.
Some of my thoughts: Suppose that we somehow specify all the convergent sequences in a set X, along with their limits, in a way that ensures that all subsequences of a convergent sequence have the same limit. Let F be the set of sequentially closed subsets of X. Then it's easy to show that the following holds: [itex]\emptyset,X\in F[/itex]. Every intersection of members of F is in F. Every finite union of members of F are in F. (We need the requirement about subsequences to prove that last one). So now we define [itex]\tau[/itex] as the set of subsets of X whose complements are in F, and use de Morgan's laws to show that it's a topology. Then we show that if the original specification says that [itex]x_n\rightarrow x[/itex], then every open neighborhood of x contains all but a finite number of terms of the sequence.
Looks good so far, but then I noticed that many different specifications give us the discrete topology, and that when we go in the other direction (i.e. determine all the sequences that are convergent with respect to a given topology), the cofinite topology gives us one of those specifications. Since the cofinite topology is a subset of the discrete topology, I'm thinking that my idea gives us the largest topology that ensures that all the sequences that were specified as convergent, are convergent with respect to the topology. Maybe we want the smallest?
A topology is uniquely determined by its convergent nets; in general sequences do not suffice.
So yes, if you start with a collection sequences with a specified limits, and demand that these are all the convergent nets, then you get a topology whose closed sets are the sequentially closed ones.
Could you elaborate on your last paragraph? I don't really understand what you say about the discrete and cofinite topology. The largest (assuming you mean largest = finest = strongest, so large in the sense of set inclusion) topology making certain sequences converge is the discrete topology, it makes every net converge to every point.
I meant that if [itex]\tau[/itex] and [itex]\tau'[/itex] are topologies on the same set and [itex]\tau\subset\tau'[/itex], then [itex]\tau'[/itex] is "larger". I guess that's what most books call "finer". The trivial/indiscrete topology makes every point a limit of every sequence. Every topology that makes singleton sets open gives us the same convergent sequences as the cofinite topology: the ones such that all but a finite number of terms are the same. The cofinite topology and the discrete topology both have this property.
Consider a few different specifications of "all convergent nets and their limits":
1. No nets are convergent. This makes every set closed (if we define "closed" the way I suggested in post #1), and that makes every set open. This is the discrete topology.
2. The only convergent nets are the constant sequences, and that for each x, the limit of x,x,x,... is x. Every set is closed, so that's the discrete topology again.
3. The only convergent nets are the sequences such that all but a finite number of terms are equal to a specific value, and that value is the limit of the sequence. Every set is closed, so that's the discrete topology again.
On the other hand, if we start with the discrete topology, and define limits (of sequences) using its open sets, as I said above, the convergent sequences will be the ones mentioned in #3 above. And we get the same result if we start with the cofinite topology.
Hm, maybe this gets a bit weird because I've been focusing too much on sequences (rather than nets). I will have to think about this.
It looks like I remembered things wrong when I mentioned a book that specified topologies by specifying the convergent sequences. It was a book that I had only quickly looked at. I just looked again, and he's talking about nets, not sequences. Here. Let's find that Wikipedia article...OK, there it is. It's talking about sequences, so at least I remembered something right.
Hi Frederik!
You touch some very interesting points in your post.
First, in general, sequences do not suffice to know the topology. For example, the discrete topology and the cocountable (not the cofinite!) topology have the same sequential limits, i.e. the eventually constant sequences.
However, knowing all the convergence points of filters (or equivallently nets) IS sufficient to know the topology. This leads (for example) to the study of limit spaces and pseudotopological spaces. If you want, I'll look up the axioms that filter-limits need to satisfy in order for it to be a topological space.
Anyway, and now comes the interesting part of my post, spaces which are defined by sequences are called sequential spaces. And as it turns out, sequential spaces are concrete coreflective in Top (forget this). All that this means is that for every topological space [itex](X,\mathcal{T})[/itex], there is a finest sequential space that has the same sequential limits. How do we construct this: well, define a sequential closed set as a set which contains all the limit points of its sequences. Take these sets as the closed sets of your topology. This defines the finest sequential space that satisfies the properties.
It can be proven that these does not exist a coarsest topology (or a smallest topology) that satisfies our properties.
Finally, the wikipedia article strikes me as wrong. We can not define a topological space by defining its limits. It would be more honest to define the topology by the family of semi-norms [itex]p_{K,\alpha}(\varphi)=\sup_{x\in K}{D^\alpha \varphi}[/itex]. I think this is what the writers of that page wanted.
Yes, that's what I meant as well (larger in the sense of inclusion).
I am sorry, that is of course what I meant (I wrote mistakinly 'discrete' instead of 'trivial'). The finer=larger=stronger the topology, the less convergent nets.
Consider a few different specifications of "all convergent nets and their limits":(...)
I think I understand what you are saying. You seem to be bothered by the fact that the procedures 'convergent sequences->topology' and 'topology->convergent sequences' are not each other's inverse. And as you realized (and as I mentioned), this is because you need to consider nets or filters instead of sequences.
I agree with micromass: I think wiki only tries to say that one gets the structure of a locally convex space via that collection of seminorms {p_i}; this means that the topology is the initial topology w.r.t. the maps [tex]\{x\mapsto p_i(x-a)\}_{i,a}.[/tex]
Yes, I think I understand now that a specification of all sequences that we're going to call "convergent" and the points we're going to call their "limits", doesn't single out exactly one topology from which the original specification can be recovered. But it seems to me that since any intersection of topologies is a topology, there should be a unique smallest topology from which the original specification can be recovered.
Phrases like "know the topology" suggests that you're thinking about a slightly different problem than what I have in mind. You seem to be saying that knowing all the nets that are convergent with respect to some topology, and knowing their limits, is sufficient to find that topology. But what I'm curious about is what happens if we just specify a bunch of nets and call them "convergent", and then specify a bunch of points and call them the "limits" of those nets. I tried to do that with sequences. It seems that not all specifications give us topologies, but if we add the requirement that the specification must be such that all subsequences of a convergent sequence have the same limit, then we end up with a topology.
I haven't had time yet to see what happens if I start with nets instead, but I'll start thinking about it now. It's not immediately obvious to me that every reasonable specification defines a topology. Looks like I'll have to think of something like the requirement about subsequences, but that makes sense for nets. Hm, I have never heard the term "subnet" (other than in the context of IP addresses, and the TV show 24, where computer nerds use it in almost every sentence even though the writers clearly don't know what it means).
Suppose you give a condition that characterizes the convergent sequences in a set X. In general, this does not specify a topology on X uniquely, as you observed. But, if there exists a metrizable topology whose convergent sequences are characterized by that condition, then it is unique (in the set of metrizable topologies) with that property. (Easy to show!)
For instance, for X,Y two top. manifolds, the Whitney weak (aka compact-open) topology on C(X,Y) can be specified without ambiguity (although perhaps not very informatively!) as the unique metrizable topology such that f_n-->f iff f_n-->f uniformly on compact sets. In principle, one still has to show that such a topology exists though!
The problem is that there might not exist a topology with the original specification. Then we take the intersection of the empty set.
Furthermore, if there does exist such a topology, then it is not clear to me that the intersection also has the original requirement. I.e. let [itex]\{\mathcal{T}_i~\vert~i\in I\}[/itex] be the topology such that the convergent sequences are exactly specified, then it is not clear to me that [itex]\bigcap_{i\in I}\mathcal{T}_i[/itex] also has exactly those convergent sequences. There might be more convergent sequences!
I'll think about this for a bit more.
Let me make precise what I mean. Let X be a set and let
lim:{nets in X} ---> {subsets of X}
be a function (which intuitively sends each net to its limit points). There exists a unique topological space with the previous function as the limit of nets, if and only if the following conditions are satisfied:
  • If [itex](x_\alpha)[/itex] is a net that is eventually constantly z, then [itex]x_\alpha\rightarrow z[/itex]
  • If [itex](y_\beta)[/itex] is a subnet of [itex](x_\alpha)[/itex] and if [itex]x_\alpha\rightarrow z[/itex], then [itex]y_\beta\rightarrow z[/itex].
  • Most difficult, the iterated net condition: Let [itex](y_\delta~\vert~\delta \in D)[/itex] be a net converging to z. For each [itex]\delta\in D[/itex], let [itex](x_\epsilon^\delta~\vert~\epsilon E_\delta)[/itex] converge to [itex]y_\delta[/itex], then the net [itex](x_{f(\delta)}^\delta~\vert~(\delta,f)\in D\times \prod E_\delta)[/itex] is a net converging to z.
So if you specify the convergent nets and their limit points, then these conditions specify a topological space iff the previous conditions are satisfied.
A subnet is not so hard to define, although there are slightly different ways which give the same nice properties: a set is compact iff every net in it has a convergent subnet, a net converges to x iff every subnet converges to x, and the like.
I was just watching the last hours of Day 6 of 24, I think I noticed the term sometime: ) I suspect most of the technical talk is nonsense, but it is pronounced fast enough to be somewhat believable...
OK. This follows from the fact that in a metric space "closed=sequentially closed".
This is awesome. Exactly the sort of theorem I thought should exist. I suspected that I would have to include those first two conditions, but the third had not occurred to me.
I find it tolerable most of the time, but it gets annoying at times. The worst one is in episode 4x01. Lucas Haas is stealing software from Adobe and Microsoft when a window opens on his screen (not sure if he did anything to open it), and quickly fills up with lines that look roughly like this:
223h x CF8A BA882A85 2F86A513
The computer is making a weird noise when the scrolling is going on. Something like a clicking sound every 1/10 second, and a little beep every 1/3 second.
Lucas Haas: What the hell is this? Whoa. Melanie, come look at this.
Melanie looks at it for no more than 3 seconds and says: Looks like someone's trying to corrupt the internet.
Lucas Haas: Yeah, but it hasn't started propagating yet. They're just placing the nodes. Look at this! This thing could tank every system in the world!
FAQ: Unleashing a Cyber Attack: The Dangers of Corrupting the Internet
1. What is the concept of "limits first, then topology" in mathematics?
The concept of "limits first, then topology" is a mathematical approach that involves first understanding the concept of limits and then applying it to the study of topology. Limits refer to the behavior of a function as its input approaches a certain value, while topology is the study of the properties of geometric objects that remain unchanged under continuous transformations.
2. How are limits and topology related?
Limits and topology are related in that limits provide a foundation for understanding the continuity of functions, which is a key concept in topology. In topology, continuity is defined as the property that a function preserves the structure of a topological space. This means that if the input values of a function are close together, the output values will also be close together.
3. Why is it important to understand limits before studying topology?
Understanding limits is important before studying topology because it provides a fundamental understanding of the behavior of functions. This understanding is essential in studying the continuity of functions, which is a key concept in topology. Without a solid understanding of limits, it would be difficult to grasp the more complex concepts in topology.
4. What are some examples of limits in topology?
Some examples of limits in topology include the concept of neighborhood, which is defined as a set of points that are close to a given point, and the concept of convergence, which is the idea that a sequence of points can approach a certain limit point. Additionally, the concepts of continuity and compactness also involve limits in topology.
5. How can understanding limits first benefit the study of topology?
Understanding limits first can benefit the study of topology by providing a strong foundation for understanding the more complex concepts in topology. It also allows for a better understanding of the behavior of functions, which is essential in topology. Additionally, understanding limits can help in proving theorems and solving problems in topology.
