Independent equations of maxwell equations
In summary, Maxwell's equations are 8. equations that determine electric and magnetic field. The component of magnetic and electric field are 6.
sadegh4137
72
Maxwell equations are 8.
we need them to determine electric and magnetic field.
the component of magnetic and electric field are 6.
in linear algebra say for solving a system of equation with n free variable, we need n equations to solving it uniquely.
here arises a question and that, why do we need 8 Maxwell equations to determine 6 field component?
with a little attention to wave equation, we can understand they are 6 equations to determine component of field!
with deep thinking to Maxwell equation, can be realized curl and divergence of field appear because of Helmholtz theorem, so the about question in general is true for Helmholtz theorem.
Well, there are actually only 4 "different" Maxwell equations. The integral equations can be transformed to the differential equations and vice-versa.
The number of equations required to determine particular fields depends on the problem at hand. One can make use of various symmetries and/or boundary conditions as well as conservation laws. It is simply wrong to say that we need to use all of Maxwell's equations to determine a given field. Sometimes we can use just one.
no i think take it mistake.
we have four Maxwell equations that two of them are vector equation which each of them has three equations. each of curl equations.
i speak in general case not at special issue with specific symmetry.
There is also the potential formulation of Maxwell's equations. That formulates Maxwell's equations in terms of a scalar potential equation (1 equation in 1 unknown) and a vector potential equation (3 equations in 3 unknowns). That seems to match well the number of equations and unknowns, but then you can do a gauge transformation and get a different set of potentials which describe the exact same fields.
Likes cianfa72
This is an excellent question. With only six unknowns and 8 equations in Maxwell's equations, you would think that two of the equations are either over-specifying the problem and will lead to contradictions, or are linearly dependent on the other equations and are therefore useless.
The answer lies in the fact that there are derivatives in these equations (in the curl and divergence operators) and derivatives destroy information in a sense. The simplest example is if I have the equation df/dx = 3, I cannot uniquely determine the function f. It is f = 3x + C. Yes, a boundary condition can help determine C in this particular case, but when you go to curl operators, boundary condition are not enough. You can think of the curl and divergence operators as orthogonal operators so that their dot product is zero. What this means is that any general vector field has a curling part, a diverging part, and a residual part. To uniquely solve for the vector, we must write down an equation determining its curling part, its diverging part, and its residual part. The divergence equations determine the diverging part of the E and B vector fields in Maxwell's equations, the curl equations determine the curling part of E and B, and the boundary conditions determine the residual part.
By the way, transforming Maxwell's equations into the potentials formulation does not reduce the number of equations (it does reduce the number of useful equations), you still have some equations sitting idly by, such as the Gauge equation.
Strictly speaking, there are always 8 Maxwell equations (when taking vector components separately), and they must all be satisfied no matter how simple the problem. If the problem is an electrostatics problem so that B = 0 and dE/dt = 0, then most of Maxwell's equations reduce down to 0 = 0. True, these equations are not entirely useful, but strictly speaking, they still exist and they still must be satisfied.
Fair point.
Although in actually working with the two vector equations it is usually easier (in my experience) to treat them as vector equations, rather than trying to deal with each component separately, given that we are dealing with curls.
I do take you point, however.
i can't your answer chrisbaird
i ask why do we have 8 equations for determining 6 component of field in ME rather than we have 6 equations in Wave Equations
but you say
WE also consist of vector operation, but they are 6
but you say
I think chrisbaird hit the nail on the head here. In many situations the equations can be shown to have redundancy in them but I do not believe that this is so in general. When you have derivatives, you add extra degrees of freedom in the solution because you lose information (such as the constants when doing a first order differentiation). So to uniquely determine the final solution, you need additional information in the form of boundary conditions.
However, Maxwell's Equations implicitly contain the boundary conditions. Take a look at this simple derivation of the boundary conditions:
http://www.amanogawa.com/archive/docs/EM5.pdf
The boundary conditions are all derived by inspection of Maxwell's Equations. So there must be additional information or constraints imbedded into the equations and this could account for the fact that we have eight equations for six unknowns.
but you say
The wave equations do not completely specify the fields. They are essentially only kinematic. The original Maxwell equations are also dynamic. For example, derive plane waves in vacuum using the wave equations. Now try deriving the relative directions of the E and B fields using only the wave equations. You can't do it. You have to go back to the original Maxwell equations to derive that for plane waves in vacuum, the E field vector, the B field vector, and the wavevector are all mutually perpendicular (in other words the plane is transverse.) This is only one example showing that because the fields wave equations consist of only 6 equations instead of the original 8 in Maxwell's equations, they are incomplete.
Born2bwire said:
...The boundary conditions are all derived by inspection of Maxwell's Equations. So there must be additional information or constraints imbedded into the equations and this could account for the fact that we have eight equations for six unknowns.
Let's be careful. You can derive from Maxwell's equations boundary condition equations linking two adjacent regions, but that is not what I meant. I meant that an actual boundary value must be supplied externally in addition to the Maxwell's equations to uniquely determine the fields. This is the case with any differential equations. Even if the region of interest is unbounded (infinite), we still have to mathematically provide a boundary condition to get a unique solution. The typical one is that the field strengths are finite (or even zero) out at infinity. But this is not why Maxwell's equations contain 8 instead of 6 equations, this is just an explanation of why boundary values are needed. The reason you need 8 equations is because the curl operator does not uniquely determine a field's solution, it only determines the curling part. Put another way, the divergence of the curl is always zero, so the solution to ∇.B = 0 is not some unique function B = Bdiverging but is the infinite set of functions B = Bdiverging + ∇xBcurling where we can choose any Bcurling in the world and the original equation will still be satisfied. So there must be another equation to determine the curling part of the field.
BOTTOM LINE: The concept of 6 linearly independent equations being necessary and sufficient to determine 6 unknowns is only true in linear algebra. When you use curl and divergence operators, you have moved beyond linear algebra.
Yeah I forgot. In the homogeneous isotropic case we still need a single boundary condition which can be provided in the form of the Sommerfeld Radiation Condition. This is an externally derived boundary condition although it is derived from simple deduction.
Nicely explained, chrisbaird.
You can see a paper.
http://arxiv.org/abs/1002.0892
A discussion to contradiction of the number of unknown variables and the number of Maxwell equations
I've only read the abstract, and from that I'd not waste my time to read the paper.
Maxwell's equations can be grouped into two parts, the homogeneous and the inhomogeneous equations. Let's start with the homogeneous ones. These are Faraday's Law of Induction and the absence of magnetic poles (I'm using Heaviside-Lorentz units with [itex]c=1[/itex]):
[tex]\partial_t \vec{E} + \vec{\nabla} \times \vec{B}=0, \quad \vec{\nabla} \cdot \vec{B}=0.[/tex]
From these equations it follows from Helmholtz's fundamental theorem of vector calculus that there exists a scalar and a vector potential such that
[tex]\vec{E}=-\partial_t \vec{A}-\vec{\nabla} \Phi, \quad \vec{B}=\vec{\nabla} \times \vec{A}.[/tex]
Now, [itex](\vec{E},\vec{B})[/itex] is the physically observable electromagnetic field, and the potentials are auxiliary quantities to identically fulfill the homogeneous Maxwell equations. Now, for a given em. field, the potentials are determined only up to a scalar field since if [itex]\Phi[/itex] and [itex]\vec{A}[/itex] define this em. field, also the new fields
[tex]\Phi'=\Phi+\partial_t \chi, \quad \vec{A}'=\vec{A}-\vec{\nabla} \chi[/tex]
lead to the same em. field. To make the solution for the potentials at a given em. field unique, we have to impose a constraint on the four potentials, e.g., the Lorenz-gauge condition,
[tex]\partial_t \Phi+\vec{\nabla} \cdot \vec{A}=0.[/tex]
Thus we have not four but only three independent potentials to describe the em. field.
Now, we have also the inhomogeneous Maxwell equations, namely the Ampere-Maxwell Law and Gauss's Law:
[tex]\partial \vec{B}-\partial_t \vec{E}=\vec{j}, \quad \vec{\nabla} \cdot \vec{E}=\rho.[/tex]
In Lorenz gauge this leads to the wave equations,
[tex]\Box \Phi=\rho, \quad \Box \vec{A}=\vec{j},[/tex]
and the charge distribution and current density have to obey the consistency condition
[tex]\partial_t \rho+\vec{\nabla} \cdot \vec{j}=0[/tex]
such that the Lorenz-gauge condition is valid, i.e., gauge invariance dictates that the electric charge is a conserved quantity. This constraint also immediately follows from the original gauge invariant form of the inhomogeneous Maxwell equations. The em. field at the presence of charges thus has three independent field-degrees of freedom, i.e., the four potentials with one gaug-fixing condition.
For free fields, however, one gauge-fixing constraint is not enough. Using the Lorenz-gauge condition, for free fields one has still the freedom to do a restricted gauge transformation with
[tex]\Box \chi=0[/tex]
This additional gauge freedom can be used to impose another constraint, i.e., the radiation-gauge condition [itex]\Phi=0[/itex], i.e., we then have the two conditions
[tex]\Phi=0, \quad \vec{\nabla} \cdot \vec{A}=0.[/tex]
Thus, for free fields, we only have two independent field-degrees of freedom. Writing the em. fields in terms of plane-wave modes one finds that the free em. field is transverse, i.e., for each wave vector [itex]\vec{k}[/itex] there are two linearly independent plane-wave solutions with [itex]\vec{A} \perp \vec{k}[/itex]. An em. wave has only two, not three, independent polarization states.
The deeper reason for that is the special structure of the massless realizations of the Poincare symmetry of Minkowski space in relativistic quantum field theory.
sadegh. Maxwell's equations consist of 8 equations and 10 unknowns, not just 6 unknowns for the fields.
Ten unknowns comes from including the charge and current density amoung the number of unknowns. There is one unknown for charge density and 3 unknowns for current density.
However, the number of unknowns can be reduced by 2 by introducing the 4-vector potential, A. The magnetic and electric fields are not completely independent, so 6 is too many.
The Faraday tensor, F=dA (see Wikipedia), replaces the 3 electric field components and 3 magnetic field components with 4 independent quantities giving us 8 equations and 8 unknowns.
The charge and current density are not unknowns. If they are unknowns, then everything is unknown and there is nothing to solve.
The Faraday tensor has 16 components (it is a 4 by 4 matrix), but many of these components are redundant. It only contains 6 independent elements, the different spatial components of the E and B fields.
Going back to the OP:
Below, I will refer to both the microscopic and the macroscopic Maxwell equations; if anybody is unfamiliar with these terms, please see the first two tables here: http://en.wikipedia.org/wiki/Maxwell's_equations.
The OP implicitly talks about the microscopic Maxwell equations. At first glance, indeed there seem to be eight scalar equations for only six scalar unknowns; however, this is actually not the case. The reason is that the two divergence equations are not independent of the two curl equations, i.e. the former can be derived from the latter. Simply take the divergence of Ampere's law and you get Gauss' law. Similarly, take the divergence of Faraday's law and you get the law of no magnetic monopoles. Since the two divergence equations are simply consequences of the two curl equations, we find that there are actually only six independent scalar equations for the six unknown scalar field quantities.
For the macroscopic Maxwell equations, by similar arguments, you wind up with six independent scalar equations for twelve (!) scalar unknowns. The remedy is that the constitutive relations give you six more independent scalar equations.
Hope that clears everything up!
chrisbaird.
OK. better said, there are 8 variables and 8 scalar equations.
however, you’re taking the question to another level. For this it’s a lot simpler after having converted maxwell’s equations to differential forms. It’s far more obvious and natural.
charge density, current density and the fields are completely specified by the 4 vector potential for all spacetime points.
the electric and magnetic fields are specified from F=dA. F is the exterior derivative of A. Using J=d*F, the electric charge and current density are specified.** So there are really only 4 independent variables. J=d*F obtains the 4 maxwell equations and d2J=0 4 more. However, the last is a mathematical identity saying there are no magnetic charges or currents.
going backwards, beginning with the charge and current density, is harder. Integration introduces constants of integration. Physically, these are boundary conditions or gauges. I’m not as comfortable with the integral forms, though the resultant gauging is fairly obvious once you have it.
to get F when given J, schematically, *F = ∫J + θ. The gauge θ is a 4x4 tensor with 6 independent terms.
(*F)μν dxμdxν = (∫Jρμν dxρ) dxμ dxν + θμν dxμdxν
with the gauge included, the differential equations are J = d(*F + θ), where dθ = 0.
so, in the typical problems usually encountered where charge and current densities are the "knowns", to get the fields knowing the charge and currents, 6 additional variables need to be specified by setting a gauge or giving boundary condtions.
also, A = ∫F + φ, where φ is a dual vector, so 4 additional independent terms arise.
Aν dxν = (∫Fμν dxμ) dxν + φν dxν
F = d(A+φ), where dφ = 0.
This second gauge is not encountered in the usual problems. It's just known that A is regaugable and probably cannot be directly measured to an exact value, but known only up to a gauge offset.
** reference: exterior derivative, Hodge dual, and “all exact forms are closed”.
For inclusion of magnetic monopoles, 'A' can have complex valued entries, but things are a little more convoluted. F is not only complex but, as I recall, regauges itself, i.e.: *iF regauges F.
This has been bothering me. Doesn't this self-gauging put sevier restraints on magnetic monopole fields? With a little thought, inclusion of magnetic charge seems to place constaints on boundary conditions. This seems a little odd as to how this could occur. This could lead to a no-go theorem for classical magnetic charge, couldn't it?
Hi, this old threads interets me.
Maxwell equation for electromagnetic potential are four formula for four unknowns. we can solve this set of equations allowing gauge freedom.
Is gauge freedom is originated from the fact the four equations are redundant thus only three or less number of equations are independent? Or gauge freedom has nothing to do with independence of the four formula? Advise, please
Regards.
I know this thread is old but I have done some analysis and I need to correct my earlier comments. Maxwell's equations contain six unknowns: Ex, Ey, Ez, Bx, By, Bz and seem to contain a linear set of differential equations consisting of 8 scalar equations. The problem therefore seems overspecified. But in fact, the curl equations of Maxwell's equations (Faraday's law and the Maxwell-Ampere law) contain the other equations (Coulomb's law and the no-magnetic-charge law) up to an arbitary unknown function that is constant in time. The six scalar equations contained in the Maxwell curl equations are therefore the complete set of dynamical linear differential equations. We therefore actually have six equations in six unknowns. The two divergence equations in Maxwell's equations are not useless though - they are needed to uniquely determine the extra term that the curl equations cannot determine. From a mathematical standpoint, the two divergence equations of Maxwell's equations are mere initial conditions, not part of the linear system of dynamical equations. Mathematically speaking then, Maxwell's equations contain six scalar equations in six unknowns (Faraday's law and the Maxwell-Ampere law) as well as initial conditions (Coulomb's law and the no-magnetic-charge law), and all is well. There is no over-specification. Perhaps the confusion arises because the divergence equations are pseudo-static (or instantaneous) so that the initial condition constraints end up being valid for all time, so they don't look like initial conditions. I go through all the math here:
http://faculty.uml.edu/cbaird/95.657%282012%29/Maxwell_Uniqueness.pdf
sweet_springs: Gauge freedom is not a result of some kind of redundancy in Maxwell's equations for the fields, because there is no redundancy in Maxwell's equations for the fields. Gauge freedom is a result of the fact that we are defining the fields in terms of something else non-physical (the potentials). Because the entities are non-physical, we are free to define them however we want (within the usual mathematical constraints of well-behaved functions, etc.) That is the origin of gauge freedom. As an analogy, consider the system of equations:
x2+y2 = 10
xy = 5
I could solve this system outright. But I might find it easier to define the unknowns in terms of new variables. For instance, if I define u = x + y, v = x - y, my system of equations reduces down to:
u2 = 20
v2 = 0
But there is nothing special about my transformation aside from the fact that it makes the math easier. I could have just as easily made the transformation u = x2, v = x2 and arrived at the system:
u + v = 10
uv = 25
I am free to define in terms of new variables how ever I want as long as the new variables do not correspond to physical properties, because they may then be constrained by other laws. So at its heart, gauge freedom is simply a result of the electromagnetic potentials having no physical meaning. Certain choices for the potentials (certain gauges) make the math easier, so they get special attention. Note these concepts are within a classical framework. When you add on quantum considerations (such as the Aharonov-Bohm effect), you can make the argument that the potentials are physical and things get more complicated.
chrisbaird,
Your post (#22) is very similar to my post (#18); however, I like how you refer to the two divergence equations as "initial conditions" (perhaps "boundary conditions" would be a better term, but that's just semantics!). In this light, there seems to be a very important point, which is implicit in our discussions, that we both glossed over. That point is that to derive Gauss' Law from Ampere's Law, one must invoke the Continuity Equation.
But where does the Continuity Equation come from? If we take the two curl equations of Maxwell to be axioms and the two divergence equations of Maxwell to be derived, then the Continuity Equation is an additional axiom that we must add to make the theory physical. But we should note that the Continuity Equation is a relation among the sources, i.e. among our "independent variables" -- it does not add to the "list of equations & unknowns." It seems then that we may consider the Continuity Equation to be a boundary condition that must always prevail.
From the standpoint of applying the Helmholtz Theorem, having equations that explicitly contain the field vectors, or perhaps just for some sort or aesthetic beauty: we consider the fundamental equations of electromagnetism to be the Laws of Gauss, Faraday, Ampere, and the Absence of Magnetic Charge. But perhaps for mathematical simplicity, we should consider the fundamental equations to be the Laws of Faraday and Ampere plus the Continuity Equation.
FAQ: Independent equations of maxwell equations
What are the four independent equations of Maxwell equations?
The four independent equations of Maxwell equations are Gauss's law, Gauss's law for magnetism, Faraday's law, and Ampere's law.
Why are there four independent equations for Maxwell's equations?
The four independent equations were developed by James Clerk Maxwell to describe the relationship between electric and magnetic fields in space. Each equation represents a different aspect of this relationship and is necessary for a complete understanding of electromagnetic phenomena.
What is the significance of the "independent" equations in Maxwell's equations?
The term "independent" refers to the fact that the four equations are not derived from each other, but rather represent fundamental principles of electromagnetism. They are independent in the sense that they cannot be reduced to a single equation.
How are the independent equations of Maxwell's equations related to each other?
The four independent equations are interconnected through the concept of electromagnetic fields. Changes in one field can induce changes in another field, as described by the equations. Together, they provide a complete description of the behavior of electric and magnetic fields in space.
What are some real-world applications of the independent equations of Maxwell's equations?
The independent equations of Maxwell's equations have numerous practical applications, including the design of electronic devices, the understanding of light and optics, and the development of technologies such as radio, television, and wireless communication. They are also used in fields such as medical imaging, remote sensing, and radar technology.
