arianabedi
- 38
This is not a homework assignment, its more of a personal project.
An object (Mass undecided yet) is launched from the North pole of Mars towards the North pole of Sun. It is assumes that Sun, Earth and Mars are in a perfect linear alignment in front of one another and that this assumption remains constant.
With the above said, will the projectile get so much of an influence from Earth's gravity that it goes completely of course or in worst case scenario, impact Earth? Relevant Information:
-From a 3D simulation, using approximate values for diameters of planets (and Sun) and also the average distance of the planets from Sun, I found that the projectile will pass Earth with a distance of 234,803.4 KM , where the strenght of Earth gravity is 0.007 ms-2 , using Formula1, mentioned below.
-Both the Mass (and volume) and the speed of this projectile can be adjusted so the safest launch process is provided (Safe: No impacts with planets or an unwanted trajectory
Formula1 : [tex]g_{h}=g_{0}(\frac {r_{e}}{r_{e}+h})^2[/tex]
[tex]g_{h}[/tex] Strength of gravity at given height.
[tex]g_{0}[/tex] Strength of gravity at Earth's surface (9.81ms-2)
[tex]r_{e}[/tex] Earth's mean radius (6,378 KM)
[tex]h[/tex] Given Height from planet's surface.
My initial attempt was to simply calculate a downward acceleration but since the acceleration increases with distance I was unable to perform any calculation (Just became a freshman at University).
The second attempt was a visual attempt, by drawing semi accurate 2D map of the scenario and try to work with angles but it proved more difficult than the previous attempt.
4. Finally...
I will need to know how much of a bend will Earth's gravitation influence cause. If knowing the mass and speed of the projectile is critical to the calculations, please inform me so I can figure them out, if not kindly provide me with the necessary formulas so I can input numbers.Regards,
Arian.
