Differential Equation related to orthogonal trajectories
In summary, the author believes that the equation for all circles which pass through the given points is: (x+C)^2+(y-C)^2=2+2C^2, and that the solution is a family of circles, all of which have their centers at (1,1) and (-1,-1). However, he is stuck on solving the equation and has found a similar problem which can be solved by using a rotational transformation of the plane.
process91
106
Find the orthogonal trajectories of the given family of curves:
All circles through the points (1,1) and (-1,-1)
I have reduced the problem to finding solutions to the following differential equation:
[tex]y'=\frac{y^2-2xy-x^2+2}{y^2+2xy-x^2-2}[/tex]
I believe the equation for all circles which pass through the given points is:
[tex](x+C)^2+(y-C)^2=2+2C^2[/tex]
Solving for C:
[tex]C = \frac{-x^2-y^2+2}{2 (x-y)}[/tex]
Implicit Differentiation of the original equation:
[tex]2(x+C) + 2(y-C)y'=0[/tex]
[tex]y'=\frac{x+C}{y-C}[/tex]
So, substituting C and taking the negative reciprocal, orthogonal trajectories must satisfy:
And now I'm stuck. The answer in the book agrees with the steps I've taken so far, but I have no idea how to get there from here aside from guessing the answer out of thin air.
Scratch that - read problem incorrectly
Aren't the equations you mentioned circles which have their centers at (1,1) and (-1,-1) respectively? They don't go through those points (I know, "go through" is an ambiguous term at best, but here the author definitely means all circles which contain the points (1,1) and (-1,-1)).
The answer is definitely the solution to that differential equation (I implicitly differentiated the answer given in the book and got my differential equation), but I just can't solve it.
The situation is similar to the other problem you had with a family of circles, those all intersecting at ( -1, 0 ) and ( 1, 0 ). I confirm your result for the circle equation; the graph for the family looks like the set from that other problem, rotated 45º and enlarged by a factor of √2 . I've already checked that the differential equation for the orthogonal set is again not exact. In view of the hour (for me), I'm going to intuit that you have a Bernoulli equation again, perhaps even with the same index n = -1 .
Just wanted to post that I got help with this in another forum, the solution was to take u=x+y and v=y-x, then consider dv/du. This results in a solvable Bernoulli equation. For the record, Apostol does not cover anything even close to this sort of substitution.
That's similar to the idea I finally had this morning (I did say I'm usually little help after midnight...). Since we know how to solve the problem with the intersection points on the x-axis, make a rotational transformation of the plane. We will have ( -1, -1 ) end up at ( -√2 , 0 ) and ( 1, 1 ) go to ( √2 , 0 ) if we use new variables
[itex]X = \frac{1}{\sqrt{2}} ( x + y ) [/itex] and [itex]Y = \frac{1}{\sqrt{2}} ( x - y ) [/itex].
This should eliminate the troublesome xy-terms and produce a re-scaled version of the other problem you did. The method you got from the other folks does this rotation and expands the scale, but the transformed DE still looks similar to the one you did before.
Apostol may be assuming that the student is already familiar with this type of transformation; this is frequently the case in "high-numbered" problems at the end of a section in a textbook. Authors will include such problems which draw on ideas from other branches of mathematics. (This problem is a good example of using the graph of each problem to get ideas for what to try.)
I'm glad you were able to get help from someone.
I think it's possible he was trying to draw on those other ideas, although one of the strengths of this book so far for me has been that it is fairly self-contained. I see that from the graph you could guess that the solution must be a bunch of circles, and get an idea on where their centers must lie. After a few tests of various equations and their derivatives, you are bound to come upon the correct answer, and this is very likely what he expected however I don't like guess/check methods like that.
Thanks again for helping me.
Related to Differential Equation related to orthogonal trajectories
1. What is a differential equation related to orthogonal trajectories?
A differential equation related to orthogonal trajectories is an equation that describes the relationship between two curves that intersect at right angles. It involves the derivatives of the curves and can be used to find the equations of orthogonal trajectories.
2. How do you find the orthogonal trajectories of a given curve?
To find the orthogonal trajectories of a given curve, you can follow these steps:
  1. Write the equation of the given curve in the form of y = f(x).
  2. Find the derivative of the given curve, dy/dx.
  3. Find the negative reciprocal of dy/dx, which will be the slope of the orthogonal trajectory.
  4. Write the equation of the orthogonal trajectory using the point-slope form, y - y0 = m(x - x0), where (x0, y0) is a point on the given curve.
3. Can a curve have more than one orthogonal trajectory?
Yes, a curve can have multiple orthogonal trajectories. This is because the slope of the orthogonal trajectory is determined by the derivative of the given curve, which can vary at different points on the curve.
4. What is the significance of orthogonal trajectories in real life?
Orthogonal trajectories have various applications in real life, such as in engineering, physics, and biology. They can be used to model the flow of electric and magnetic fields, heat transfer, and the growth of biological organisms. They are also used in the design of curved roads, bridges, and buildings.
5. Are all curves capable of having orthogonal trajectories?
No, not all curves have orthogonal trajectories. Only curves that satisfy certain conditions, such as being defined by a differentiable function and having a non-vertical tangent at every point, can have orthogonal trajectories. For example, a circle does not have orthogonal trajectories because its tangent is always perpendicular to the radius, making it impossible for another curve to intersect it at right angles.
