Neutrino Oscillations for Dummies
In summary: I have no idea. It's a hypothetical mass that's much heavier than the electron. In Type II, the neutrinos have no mass at all, and the oscillations are just a result of the neutrinos changing flavor.In summary, according to this article, it is necessary for neutrinos to have non-degenerate mass states in order to produce oscillations. If two neutrino mass states have the same mass, there will be no oscillation between them. It is unknown if right-handed neutrinos exist, and if they do, they may interact with the W and Z bosons. If neutrinos have mass, they are affected by gravity. Finally, if oscillations
DevilsAvocado
91
Neutrino Oscillation for Dummies
If someone has the time to answer these questions, it would be much appreciated.
  • According to Wikipedia http://en.wikipedia.org/wiki/Neutrino_oscillation" is of "interest since observation of the phenomenon implies that the neutrino has a non-zero mass". Does this mean that 100% confirmed oscillation unconditionally 'gives' mass to neutrinos? Or is there still a possibility for mass-less neutrinos to oscillate?
  • I see users in this thread talking about neutrinos changing flavor thru flight, but no measurement is done, right? And 'all' we got before this is the QM wavefunction and a superposition of the three neutrino states, before the measurement, right?
  • AFAICT, there’s a 'phase shift' between the 3 flavors in the wavefunction, and that the traveling distance is what finally sets the probabilities for measuring one flavor, correct?
  • If neutrinos have mass and are only left-handed, that creates 'problems' with the Standard Model and the Higgs mechanism (which need both left- and right-handed versions of the fermion to function), right? But then I read somewhere that "neutrinos are mostly left-handed"...? Has right-handed neutrinos been detected?
  • What’s the main reason neutrinos interact very weakly with 'ordinary' matter? Is it the 0 charge, or the tiny mass?
  • If right-handed neutrinos exist, do they interact with the W and Z bosons?
  • If neutrinos have mass, are they affected by gravity?
  • [Just curiosity, nothing else]
    If it’s confirmed that the difference in mass between the neutrino and other fermions is 500,000 times, and we know that the difference between gravity and the other three fundamental interactions is > 1025; could there be a 'relation' between these two very large 'gaps'... (to the other 'stuff')...?
Thanks
Thanks
Okay, let's try these in order.
  • To get oscillations what's actually necessary is that the neutrinos have non-degenerate mass states. Specifically, the oscillation probabilities will depend on [itex]\Delta m^2[/itex]. So, if two states have the same mass, there will be no oscillation between them. That means that to get the observed number of independent oscillations observed (i.e. more than one), no more than one of the three neutrino mass states can have [itex]m=0[/itex].
  • Yes. At any time, the flavor wave function is a superposition of the three gauge eigenstates (to some approximation - to really do it right, I think you have to think in terms of density matrices); and, it's the parameters of that superposition that oscillate.
  • Approximately. But, the usual treatment assumes an exact energy and momentum for the neutrino. Since particles are actually created as wavepackets with some dispersion in energy and momentum, the pathlength part of the effect should get washed out if the neutrino source is extremely distant.
  • I don't know that "problem" is quite the right way to put this. No matter what you're going to have to add something to the standard model in order to get neutrino masses. The only real question is what that will be and whether the Higgs will actually be involved at all. There are two pretty standard ideas about this (called the Type I and Type II see-saw mechanisms, respectively). In Type I, there are right-handed neutrinos which have the usual sort of coupling to the lepton doublet and the Higgs, but which also have a very large Majorana mass of their own. (Because they're uncharged under all gauge interactions in the theory, they can be their own antiparticles, which allows the definition of this mass term in a fully consistent way.) Then, when EW symmetry is broken a small mixing between the left-handed neutrinos and the heavy left-handed anti-neutrinos is induced, which results in a light state with mass [itex]~\frac{m_{SM}^{\phantom{SM}2}}{M_{Majorana}}[/itex], where [itex]m_{SM}[/itex] is the mass that EW symmetry breaking would create were there no Majorana mass present. In Type II, the lepton doublet couples to a new scalar triplet which has a potential such that EWSB gives it a small vacuum value that interacts with the left-handed neutrino in such a way as to generate a Majorana mass for the neutrino. Either way, none of the new states implied have been observed; but, in Type I the new states are extremely heavy and in Type II they tend to be quite weakly coupled. So, it's not guaranteed that anything should have been seen yet.
  • It's the lack of net electric or color charges. The mass is incidental to this.
  • Purely right-handed neutrinos will not interact with the W and Z at all. The post-mixing heavy neutrinos of the Type I see-saw will interact with the W and Z; but, the interaction strengths will be tiny.
  • Neutrinos are affected by gravity even have they have no mass at all. Gravity couples to all forms of energy, momentum, pressure, etc.
  • Amazingly enough, the gap between the neutrino and other fermion masses is actually quite a bit too small to be explained easily by gravitational effects. The only models I know of that relate the various hierarchies at all have to use extra dimensions to do so.
Parlyne said:
Okay, let's try these in order ...
Many many thanks! Very interesting answers and I have a lot to digest, but I’ll be back, thanks again!
[Isn’t this place just wonderful!? Where else could you get this kind of professional response, this fast!?]
Thanks DA for an instructive post on how to ask a question here. I would like to add another one to your list:
Is there a way to predict the oscillation length of a neutrino?
I think some variables to consider would be initial energy, initial flavor, and the transport medium (e.g. bedrock, vacuum...). The closest I could find was a guy claiming to calculate the probability that a neutrino would oscillate as a function of distance from emission, but that's not oscillation length. It has to do with muon neutrinos like the ones speeding from CERN to Gran Sasso. I don't know if this Fabrice Fleurot fellow is a crackpot or not, and don't want to go around illustrating my question with pretty crackpottery graphs. There are no references on this webpage anywhere. Anyway, an illustration of the probability graph I mention is about 1/2 way down at:
http://nu.phys.laurentian.ca/~fleurot/oscillations/
That page looks like a pretty good technical overview. I don't know that I really have anything to add to that.
Thanks, you’re welcome!
I wish I had a clue... but it’s safest to listen to Parlyne, he’s the only expert here. :rolleyes:
FAQ: Neutrino Oscillations for Dummies
What are neutrino oscillations?
Neutrino oscillations refer to the phenomenon where neutrinos, which are subatomic particles with no electric charge, change from one type to another as they travel through space. This is due to the fact that neutrinos have mass and can interact with each other in a process called flavor oscillation.
Why are neutrino oscillations important?
Neutrino oscillations provide valuable insights into the fundamental properties of neutrinos, which are the most abundant particles in the universe. They also have implications for our understanding of the Standard Model of particle physics and can help us learn more about the structure of matter and the laws of physics.
How do neutrino oscillations occur?
Neutrino oscillations occur when neutrinos travel through space and encounter other particles, such as electrons or quarks. When this happens, the neutrinos can interact and change into different types, or flavors, of neutrinos. This process is governed by the weak nuclear force, one of the four fundamental forces of nature.
What are the different types of neutrino oscillations?
There are three types of neutrino oscillations: electron neutrino to muon neutrino, electron neutrino to tau neutrino, and muon neutrino to tau neutrino. These correspond to the three flavors of neutrinos: electron, muon, and tau. Neutrinos can change into any of these three flavors as they travel through space.
How are neutrino oscillations detected?
Neutrino oscillations are detected by observing the interactions of neutrinos with other particles. This can be done using large detectors, such as underground tanks filled with water or ice, which can capture the faint signals produced by neutrino interactions. Scientists also use powerful particle accelerators to produce neutrinos and study their oscillations in controlled experiments.
14K
