Building Planets: Explaining Expression (??) in Planet Construction
  • Thread starter vaibhavtewari
  • Tags
    Planets
In summary: Bill said. Bill said that if the surface of the planet did not follow the contour, there would have to be some of the planetary surface sticking outside the contour and some of the planetary surface still inside the contour. And then if you took some of the part that's outside and moved it to a place where the surface is inside, you would increase the gravity. So by contradiction, when you can no longer do this, none of the surface remains outside.
vaibhavtewari
65
Hello Everyone,
I kind of followed this document
http://pages.physics.cornell.edu/~aalemi/random/planet.pdf
until on page 3, author explains
What we are trying to due, is build the planet such that each chunk con-
tributes as much as possible to this integrand. So, if we pause for a second
and think about expression (??) as a sort of measure of cost effectiveness, it
isn’t long before we realize that our planet’s surface should correspond to a
constant contour of this expression.
which does not makes too much sense to me. Can some one explain this to me, or give an alternative solution.
Thank You
vaibhavtewari said:
Hello Everyone,
Thank You
"constant contour of this expression" means a surface where that expression ( equation (1) given above the quoted paragraph) is the same at every point.
To maximize the integral that gives you g at some point, while minimizing the used mass, you have to fill the space with mass in the order in which each point contributes to the integral (most contributing points first). So the planet surface will be an iso-surface of the spatial function that gives you the contribution factor for each point.
thanks for replying but this is almost reworded version of the statement...can you show them in equations and math
Thanks
vaibhavtewari, If the surface of the planet did not follow the contour, there would have to be some of the planetary surface sticking outside the contour and some of the planetary surface still inside the contour. And then if you took some of the part that's outside and moved it to a place where the surface is inside, you would increase the gravity. So by contradiction, when you can no longer do this, none of the surface remains outside.
What Bill said.
A very nice problem BTW, with a rather disappointing result: "So, after all that work, in the end of the day, you can only do about 1.03 times better than the sphere if you want to maximize your gravity"
can you show it in math. Like this is the integral, something that is not worded. I am pretty sure any thing in physics that can be worded can be written in equations.
Thanks
Related to Building Planets: Explaining Expression (??) in Planet Construction
1. How do planets form?
Planets form through a process called accretion, where dust and gas particles come together under the force of gravity to form larger and larger bodies. As these bodies grow, they begin to attract more material and eventually form into planets.
2. What factors influence the formation of planets?
The formation of planets is influenced by several factors, including the composition of the protoplanetary disk, the distance from the star, and the presence of other planets or large bodies in the system. These factors can affect the amount and type of material available for planet formation, as well as the stability of the system.
3. How do scientists study planet formation?
Scientists study planet formation through a combination of observations, computer simulations, and laboratory experiments. They use telescopes to observe protoplanetary disks around young stars and gather data on their composition and structure. Computer simulations can also model the formation process and help scientists understand the factors that influence it. Laboratory experiments can simulate the extreme conditions present during planet formation and provide insights into the chemical reactions that take place.
4. What is the role of gravity in planet construction?
Gravity plays a crucial role in planet construction. It is the force that brings together particles in the protoplanetary disk, allowing them to grow into larger bodies. As these bodies continue to grow and attract more material, their gravitational pull increases, eventually forming a planet. Gravity also helps shape the planet's structure and influences its orbit and interactions with other bodies in the system.
5. Can planets form in different ways?
Yes, planets can form in different ways depending on the conditions present in their particular system. For example, some planets may form through core accretion, where a solid core forms first and then attracts gas and dust to form a larger body. Other planets may form through gravitational instability, where the protoplanetary disk becomes unstable and breaks up into clumps that eventually form planets. There may be other processes at play as well, and scientists are still studying and discovering new ways that planets can form.
  • Astronomy and Astrophysics
  • DIY Projects
  • Quantum Interpretations and Foundations
  • STEM Academic Advising
  • Quantum Physics
  • Quantum Physics
