Is SOL infinite? (from its own point of view)
In summary: So in one case the observer would find the distance to be smaller, and in another case the observer would find the distance to be the same.He is saying that the distance between two points is not always the same for an observer traveling near light speed.
Lukas_23
I wondered if just stating that the speed of light is 300,000 km/s in all reference frames does not give the whole picture.
I heard Penrose say that time for light is 0. Wouldn't that mean from its point of view it goes everywhere instantly and thus has infinite speed?
If you're going to say that time for light is zero, then you must also say that distance for light is also zero, and since zero divided by zero is indeterminate, you have to figure out the problem some other way. You cannot jump to the conclusion that it is infinite any more than that it is zero or any other value.
Why is distance zero for light? I know it stems from the equation but clearly light travels so assuming physical laws are everywhere the same, that contradicts that light travels for me but not for itself.
EDIT: Sticking to the math, if 0/0 could be any number this at face value seems to say distance that light travel is any value and it is omnipotent.
Any line of reasoning that leads to the idea that time for light is zero also leads to the idea that distance for light is also zero.
How do you get that distance is any value from 0/0? The zero on the top is distance. The result of the division is speed and you cannot draw any conclusion from doing this calculation.
And I'm not saying that time or distance for light is zero. I'm saying that the whole idea does not lead to anything conclusive.
Yes, the speed is 0/0. But that means it can be any speed because 0*x=0.
So we don't know its speed, it can be anything, and we know its speed to be 300,000 km/s. Where is the mistake here?
a) Relativity: light speed is finite
b) Penrose: "clock" of light is at all times zero.
EDIT: Was Penrose saying the "clock" of light never moves for us?
Did Penrose put quotes around clock? That means he is trying to illustrate that the idea of a clock for light is meaningless and the idea of time for light is meaningless. Can you provide a fuller quote so we can see the context of what Penrose is saying, or a link where we can see it for ourselves?
No, I put the quotes to show an analogy for time - he said just time in a video in an explicit way. As soon as I find it I will post the link.
OK, but I would suggest that you listen carefully to what he says before and after that short sound bite and see if you can figure it out on your own. I'm sure Penrose would never try to convince anyone the light can have a clock or that it can keep track of time. He's probably trying to point out the ridiculousness of the concept.
Start listening at 9:05. He says:
If you wanted to build a clock, you have to have massive entities in it and you have to have particles with mass but in this view everything with mass in it finally decays away; radiates away and there is no way of building any entity which keeps time, and so, although the universe goes on expanding to eternity...eternity to these things in the universe isn't all that long in a sense. If you were a photon, eternity is no time at all.​
So he is pointing out that a photon, since it is massless, has no concept of time, not that eternity is an infinite time or a long time or a short time or zero time or any time at all.
So he did not say "that time for light is 0", as you misquoted him. He said time does not apply to a photon. So my prediction was exactly correct:
How so, I think that depends on how you measure distance.
An observer traveling near light speed between A and B can measure distance by using light, and in that case he will find it is smaller, however if he were to use a surveyor's wheel on a road between A and B he would not find it smaller.
The topic of this thread is about how light could measure its own speed, not how an observer traveling near light speed would measure anything.
Just to clear up one other point of confusion: an answer that is indeterminate doesn't mean that the answer is anything, it just means we have to solve the problem some other way as I stated earlier:
ghwellsjr said:
...since zero divided by zero is indeterminate, you have to figure out the problem some other way. You cannot jump to the conclusion that it is infinite any more than that it is zero or any other value.
So there is no mistake because 0*300,000=0, correct?
FAQ: Is SOL infinite? (from its own point of view)
Is the size of the SOL (our sun) infinite?
No, the size of the SOL is not infinite. It has a defined radius and mass, and although it may seem incredibly large to us, it is not infinite.
Is the lifespan of the SOL infinite?
No, the lifespan of the SOL is not infinite. It is estimated that the SOL will continue to shine for another 5 billion years before it runs out of fuel and dies.
Can the SOL run out of energy?
Yes, the SOL will eventually run out of energy as it consumes its fuel. This is a natural process for all stars and is known as stellar evolution.
Is the SOL the only source of light in the universe?
No, the SOL is not the only source of light in the universe. There are billions of stars in the universe, each with their own light source, and there are also other sources of light such as galaxies, nebulae, and even artificial sources created by humans.
Can the SOL ever stop shining?
Yes, eventually the SOL will stop shining as it runs out of fuel. However, this process will take billions of years and is not something that will happen in the near future.
