Third Order Non-Linear Homogeneous ODE
Compressible
I have derived a 3rd order non-linear ODE with its respective boundary conditions, and I was hoping to get a hint on how to find a closed form solution to it. The equation is given as:
F''' + (1/C^2)*F*F' = 0
Where the primes denote a derivative, and C is just a constant. Any help is highly appreciated!
I think this might help. Write the equation as F''' = -(1/C2)FF'
Now integrate both sides. That will get you a 2nd order DE.
So I tried what you mentioned, and here's what I get (though I think I made a mistake somewhere):
F''' = -(1/C^2)*F*F'
> F'' = -(1/2/C^2)*F^2 + C1 (where C1 is a new constant)
Now, this gives:
F'' + (1/2/C^2)*F^2 + C1 = 0
Assume G = F'
F'' = G*dG/dF
> G*dG/dF + (1/2/C^2)*F^2 + C1 = 0
> G*dG = [-(1/2/C^2)*F^2 - C1]*dF
Integrating both sides gives,
G = sqrt(-(1/3/C^2)*F^3 - 2*C1*F + 2*C2) = F' = dF/dy
Separating variables gives,
dF/sqrt(-(1/3/C^2)*F^3 - 2*C1*F + 2*C2) = dy
But now I have no idea how to take that integral and I'm pretty sure I made some mistakes with the constants. Any suggestions as to where I went wrong and what I can alter?
You said closed-form right? First just write it as:
\frac{dy}{dx}=\sqrt{ay^3+by+c}
Now, suppose I told you there is a special function called the Weierstrass P function such that if:
\text{myxside}=\int_{\infty}^{y}\frac{dt}{\sqrt{4t^3-ct-d}}
then:
y=P(\text{myxside,c,d})
and you just had to make some kind of showing on this thing, could you express your solution in terms of the Weierstrass P function?
then:
Honestly, I'm not familiar with the Weierstrass P function. I have to solve this ODE and apply three boundary conditions to it. I'm not sure how the Weierstrass P function operates to be able to do that.
Looking at it again, I think I found a way to solve the ODE, if the 1/C^2 constant wasn't there. Is there any way to define a new variable F that absorbs that constant value. If I can find a way to do that, then that ODE is easily solvable.
Nevermind. Solved! Thanks for the help!
