student@work
- 2
I am creating a 3D mesh for beam188 elements (L sections).
Method - create keypoints, create lines between KP, define section, apply all relevant properties to the line and mesh the line.
When I view the mesh (/ESHAPE,1) it appears as you would expect with an extruded L-shaped 3D brick-structure (blue solid 'bricks' with corners - I assumed each 'corner' would be a node but this does not seem to be true?)
When I plot nodes, the only nodes that appear are at the ends of the element (ie where I created by original KP)
I CAN however view nodes across the section of the beam by
PREPROCESSOR >> SECTIONS >> BEAM >> PLOT SECTIONS then pick "Node Numbers" from the "Show section mesh?" dropdown. This shows a x-y plot of the beam's cross-section with the nodes and areas.
Can anyone explain, can I view these "Section Nodes" in my global model??
And can I use these section nodes in my global model (to lock elements together)?
Thanks in advance for any info
(If it is not too clear I can explain why I want to do this but tried to keep it as brief as possible)
