Martian Pole Star: Same as Earth's?
  • Thread starter m~ray
  • Tags
    Pole Star
In summary, the Martian north celestial pole is located in the constellation Cygnus and is not visible to the naked eye due to the faintness of the stars near it. It is positioned between the brightest stars in Cygnus and Cepheus. While Earth and Mars have similar axial tilts, their poles point in different directions, making the Earth's pole star, Polaris, unusable as a pole star for Mars. However, due to axial precession, it is possible for Earth and Mars to share the same pole star at certain points in time.
m~ray
31
martian pole stars same as Earth pole stars ?
Astronomy news on Phys.org
The Martian north celestial pole resides in the constellation Cygnus- near the border of Cepheus.
Unfortunately, the stars nearest the pole are too faint to be useful. The closet is approximately a half-degree away and is barely visible to the naked eye. The pole is close to the halfway point between Deneb in Cygnus and Alderamin in Cepheus-- the brightest stars in their respective constellations.
See the following image:
http://img593.imageshack.us/img593/1663/marsnorthpole.th.jpg
Edit:
Here are a couple of links for further information:
http://Earth'sky.org/space/mars-north-south-star
http://en.wikipedia.org/wiki/Astronomy_on_Mars#Celestial_poles_and_ecliptic
my question was different.. your reply answers y Mars doesn't have a good pole star.
m~ray said:
the question i had asked was, why can the polaris (earth's pole star) not be used as martian pole star when both have similar inclination of rotation axis.
While the axial tilts are similar in degree, Mars is tilted in a different direction. Earth is tilted so that its axis points toward Polaris. Mars' points toward Cygnus/Cepheus.
thanks.
Also, it is bad form to completely edit your posts to change their meaning. It creates confusion and makes it hard to figure out what's going on. Just add a new post that contains what you want to say.
Related to Martian Pole Star: Same as Earth's?
1. What is the Martian Pole Star?
The Martian Pole Star, also known as Deneb, is a bright star located in the constellation Cygnus that is visible from the northern hemisphere of Mars. It is used as a navigational reference point by explorers and scientists on Mars.
2. Is the Martian Pole Star the same as Earth's North Star?
No, the Martian Pole Star is not the same as Earth's North Star, also known as Polaris. The two stars are located in different constellations and have different positions in the sky. However, they both serve as useful navigational aids for their respective planets.
3. How does the Martian Pole Star differ from Earth's North Star?
While both stars are used for navigation, the Martian Pole Star appears to be slightly dimmer and less stable than Earth's North Star. This is due to the fact that Mars has a thinner atmosphere and weaker magnetic field compared to Earth, which affects the visibility and stability of stars in the sky.
4. Can the Martian Pole Star be used to determine the direction of North on Mars?
Yes, the Martian Pole Star can be used to determine the direction of North on Mars, just like how Earth's North Star is used. However, due to the differences in the planets' magnetic fields, the accuracy of this method may vary.
5. Are there any other stars on Mars that can be used for navigation?
Yes, there are several other stars that can be used for navigation on Mars, depending on the location and time of year. Some examples include Aldebaran, Betelgeuse, and Rigel. These stars are also visible from Earth and are commonly used for navigation in space exploration.
