swerdna
- 251
Does the relative motion of a thing slow down the relative motion of a thing? Hope that makes sense or you can work out what I mean.
I guess it is essentially what I’m asking. Specifically relative acceleration. Can you give a non-mathematical, simple as possible explanation why it doesn’t?elfmotat said:Time dilation won't cause any acceleration, if that's what you're asking.
twitch1 said:Yup, there it is, nothing new under the sun. What if time dilation isn't a perceived effect, but an actual change in the plane of time?
elfmotat said:What do you mean by an "actual change" ? Time "really is" dependent on your coordinate system. And what do you mean by the "plane of time" ?
Time dilation does not cause the moving thing to move slower. Its speed is the same relative to some other thing as that other thing's speed is to it because there is also length contraction. The two act in concert to yield the same relative speed between the two things whether you consider the first to be moving and the second stationary or the other way around.swerdna said:If time dilation is a consequence of moving and time dilation is essentially “moving slower” then why doesn’t time dilation affect the motion that causes it? How does the time difference of time dilation occur without acceleration?
Time dilation is a phenomenon predicted by Einstein's theory of relativity, where time appears to pass at different rates for objects in relative motion. This means that the faster an object moves, the slower time will appear to pass for that object. Therefore, time dilation does affect the relative motion between objects, as the faster an object moves, the more pronounced the time dilation effect will be.
No, the direction of motion does not impact the amount of time dilation. Time dilation is solely dependent on the speed of an object, not the direction in which it is moving. This is because time is relative and will appear to pass differently for objects in relative motion regardless of their direction of movement.
Yes, time dilation can be observed in everyday life, but it is usually only noticeable at extremely high speeds. For example, on a commercial airliner traveling at a speed of about 500 mph, time dilation is so minuscule that it cannot be detected by humans. However, at speeds close to the speed of light, time dilation becomes more apparent and has been observed in experiments with subatomic particles.
Yes, gravity can also cause time dilation. According to Einstein's theory of general relativity, the force of gravity is not a force at all, but rather a curvature of space-time. This means that objects with more mass, such as planets and stars, have a greater gravitational pull and therefore experience more time dilation. This has been confirmed through experiments and observations of time dilation near massive objects like black holes.
Yes, time dilation can be reversed by changing the relative motion between objects. If an object that was previously moving at a high speed slows down or stops, time will appear to pass normally for that object again. This is why time dilation is considered a relative effect, as it is only noticeable when comparing the time experienced by objects in relative motion.
