Rotation in a Vertical Plane - tension on a bucket
In summary, the tension in the handle of a 4kg bucket of water is 39.2 N at the bottom of a vertical circle with a radius of 2m, and 72 N at the top of the circle. The tension at the bottom is the sum of the weight and mv^2/r, while the tension at the top is 0 because the water is weightless at that point. The centripetal force, mv^2/r, is the force that keeps the bucket in circular motion.
testme
68
A 4kg bucket of water is rotated in a vertical circle of radius 2m at the minimum rate required to keep the water in the bucket. Find the tension in the handle of the bucket at a) the bottom of the circle and b) the top of the circle.
mass: 4kg
radius: 2m
Fnet = ma
Fnet = mv^2/r
a) Well, I'm not sure if I'm doing this right but since we're talking about the tension at the bottom of the circle I took the velocity to be 0 (I think I'm wrong but I'm not sure what else to do).
Fnet = mv^2/r
Fg + T = mv^2/r
-39.2 + T = 4(0)^2/2
-39.2 + T = 0
T = 39.2 N
b) I'm having trouble with this one, so far I have
Fnet = mv^2/r
Fg + T = mv^2/r
-39.2 + T = 4v^2/2
-39.2 + T = 2v^2
Sorry I know it's not much that I've done but I'm out of ideas.
If you have the minimum speed where the water does not come out of the bucket, the water then is 'weightless'. If the water is weightless, what can you say about the water and the bucket together?
Then what happens at the bottom? You have the same two forces but now they combine differently.
Hmm, I'm not really getting what you're trying to say, why is the water then 'weightless' and wouldn't that mean the water and the bucket together have the combined weight of the bucket only?
At the bottom you'd have the same forced but the tension is upwards while gravity is downwards right?
I'm still not sure of how I'm supposed to calculate the tention force though since we don't have a velocity
I'm trying to give you hints without telling you how to do it.
When an object revolves in circular motion like this pail with water in it, there is a force that keeps it in the curved path. That force is mv^2/r. The acceleration part of what makes up the force is v^2/r. If this acceleration just equals gravity, 9.81 m/sec^2, weightlessness occurs. The force outward away from the center of rotation just equals the weight when in the vertical position.
At the bottom, the outward force and weight are in the same direction.
The centripetal force, I believe. So at the top we're saying it only equals gravity? Does that mean there's no tension force at the top?
Wouldn't the two forces be in opposite directions at the bottom?
Sorry, it's just my first question like this.
Here is a picture of the FBD I drew - they're just rough drawings
http://sadpanda.us/images/856185-0K3GF2L.jpg
"The centripetal force, I believe. So at the top we're saying it only equals gravity? Does that mean there's no tension force at the top?"
Yes, you are correct.
You have left out a force in each sketch. It is mv^2/r pointing away from the center of rotation in each case. At the top it points up. At the bottom it points down. So what does this do to the tension at the bottom?
What my teacher told us was that the centripetal force is the combined force that will be towards the center. Isn't that what mv^2/r is? That's what I'm kind of confused about.
At the bottom the tension is the sum of the weight and mv^2/r providing the speed is the same at the top as it is at the bottom.
"What my teacher told us was that the centripetal force is the combined force that will be towards the center. Isn't that what mv^2/r is?"
Centripital force is the force that keeps the pail moving in circular motion. So it is the sum of mv^2/r and the weight.
Okay, so I think I finally got it.
Since we know that the T at the top is 0.
Fnet = mv^2/r
Fg = mv^2/r
One sig fig.. (and using 9.8 m/s^2 for gravity)
40 = 4v^2/2
40 = 2v^2
20 = v^2
v = 4 m/s
Then at the bottom
Fnet = mv^2/r
Fg + T = mv^2/r
Assuming up is positive
-40 + T = 4(4)^2/2
-40 + T = 2(16)
T = 72 N
Thanks a lot for the help.
Related to Rotation in a Vertical Plane - tension on a bucket
What is rotation in a vertical plane?
Rotation in a vertical plane refers to the circular motion of an object along a vertical axis. This can be seen when an object, such as a bucket, is swung in a vertical direction.
How does rotation in a vertical plane affect tension on a bucket?
When a bucket is rotated in a vertical plane, it experiences a centripetal force that pulls it towards the center of the circular motion. This creates tension on the bucket, which is the force that keeps the bucket from flying off in a straight line.
What factors affect the tension on a bucket during rotation in a vertical plane?
The tension on a bucket during rotation in a vertical plane is affected by the mass of the bucket, the speed of rotation, and the length of the rope or string holding the bucket.
How is tension on a bucket related to the speed of rotation?
The tension on a bucket is directly proportional to the speed of rotation. This means that as the speed of rotation increases, the tension on the bucket also increases. This is because a higher speed creates a greater centripetal force, resulting in a stronger tension on the bucket.
Can the tension on a bucket be greater than the weight of the bucket?
Yes, the tension on a bucket can be greater than the weight of the bucket during rotation in a vertical plane. This is because the tension is a result of the centripetal force, which is dependent on the speed of rotation and the length of the rope. As these factors increase, the tension can exceed the weight of the bucket.
