sigurdW
- 27
Alfred Tarski diagnosed the Liar Paradox as arising only in languages that are "semantically closed", by which he meant a language in which it is possible for one sentence to predicate truth (or falsehood) of another sentence in the same language (or even of itself).
To avoid self-contradiction, Tarski says it is necessary when discussing truth values to envision levels of languages, each of which can predicate truth (or falsehood) only of languages at a lower level. So, when one sentence refers to the truth-value of another, it is semantically higher. The sentence referred to is part of the "object language", while the referring sentence is considered to be a part of a "meta-language" with respect to the object language. It is legitimate for sentences in "languages" higher on the semantic hierarchy to refer to sentences lower in the "language" hierarchy, but not the other way around. This prevents a system from becoming self-referential.
How to prove him wrong?
English is a semantically closed language so let's begin by stating the conditions for the Liar to arise:
1 Sentence 1 is not true.
2 Sentence 1 ="Sentence 1 is not true.
Being careful I will not accept sentence 2 on its face value, perhaps its not true?
If it IS true then no harm is done if we declare it to be true...so this is what you should work with:
2 Sentence 1 = "Sentence 1 is not true"
3 Sentence 2 is true.
Now try to derive the Liar Paradox! (I predict you will fail to do so! Will you prove me wrong?)
