How to approach difficult problems?
  • Thread starter Government$
  • Tags
    Approach
In summary, I think that spending time on solving a problem before checking an answer is beneficial in developing problem-solving skills, but it is important to know when to stop.
Government$
87
Hello physics forum.
In last couple of weeks i have been working more difficult problems from Algebra and things are going a bit more difficult where solution is not apparent right away. So i need to spend some time doing one problem until i find a solution. That can be from half an hour to hour or two for one problem. That is not very fast progress and i feel sometimes like i am loosing time and that i am not productive. So the question is how much time should i spend on solving a problem before i check solution at the end of the book? That's how i solve problems from physics. I don't try first alone rather i go straight to the answers and the try to understand problem. I know, that is not a good way of developing my problem skills, because there is going to be time when there won't be an answer at the end of the book and then what? So should i spend hours trying to figure out one problem or after some time i should look for the answers? I usually need a start and after that i can finish a problem by my self.
Thank you
Hey, I can understand the dilemma you are in.
The first step towards better problem solving is knowing the concepts well.
I would request you to go through your textbooks again to understand the chapter clearly if you haven't done so.
After that, sit alone and start asking yourself what have you learned uptil now.Ask yourself frequent why and how questions.
Your theory should be so strong that you should be capable enough to explain the concepts to others.
Once your theory has been made strong problem solving will get easier.(Certainly!)
The next step is that whenever you read a problem, think about it for sometime.
Usually people start writing equations immediately which is not a right way to do esp in physics(and also in math).
Thinking will help you realize what the question actually wants.
Like let's see a simple example of calculating the range of a projectile.
Most students will immediately start writing the equation of motion( and they may get the answer.But it won't happen always and definitely won't help in time management as the difficulty level increases)
The method is to ask yourself is how the particle is moving.what you need to find the range.
The particle is moving like a curve and
You need the horizintal velocity the horizontal acceleration and the time.
Now obtaining horizintal velocity and acceleration is a one step process.
However , obtaining time is not a one step process.
It would require you to think that the time taken will be equal to the time taken by the particle to go up, stop and then come back to the lowest point.(which can be done only if you can visualise the problem)
After this you can start writing the equations to get this.
(that is think first and then write equations and not vice-versa)
(I hope you are aware of kinematics so that this example helps you.)
This is a simple example i sighted which may seem obvious (if you have studied kinematics).
However as the problem gets tougher, those who think at the basic level correctly and effeciently, are usually those who able to adapt and figure out solutions easily and effeciently as the difficulty level increases :-)
Hope this helps
Imo, the best way to learn to solve difficult problems is to learn to solve (i) simple and (ii) medium difficulty problems first. Some books have excercises which are ordered according to difficulty (especially some dedicated excercise books; i.e., not textbooks), with the complexity rising slowly but steadily from task to task, and featuring multiple excercises viewing the same topic and solution strategies from different angles.
For me this was an immensely effective way of getting a routine in standard approaches (which is required to solve difficult problems). If you think that you are not efficient in handling the excercises in your current way, then this may well be true. In that case I highly recommend to look for other textbooks/excercise books which are closer to your way of working: Different approaches work differently for different people, and not all books contain good excercises (in fact, excercises in textbooks are often very poor). Just stop by your local library and look through different books to see what works for you.
Hobin, that's an excellent link :-)
FAQ: How to approach difficult problems?
1. How can I break down a difficult problem into smaller, more manageable parts?
One approach is to start by identifying the main objective of the problem and then breaking it down into smaller sub-problems. You can also try brainstorming and listing out all the components or factors that contribute to the problem, and then tackling each one individually.
2. What strategies can I use to overcome mental blocks when approaching a difficult problem?
Some strategies that can help overcome mental blocks include taking a break and coming back to the problem with a fresh perspective, discussing the problem with others to gain new insights, and trying out different problem-solving techniques such as visualization or analogies.
3. How can I stay motivated when faced with a challenging problem?
One way to stay motivated is to remind yourself of the potential rewards or benefits of solving the problem. You can also try setting small, achievable goals and rewarding yourself as you make progress. Additionally, seeking support and advice from others can help keep you motivated.
4. What role does creativity play in approaching difficult problems?
Creativity is crucial when approaching difficult problems because it allows you to think outside the box and come up with unique solutions. It involves looking at the problem from different perspectives, making unexpected connections, and experimenting with new ideas and approaches.
5. How can I learn from past failures when approaching a difficult problem?
Reflecting on past failures can provide valuable insights and help you avoid making the same mistakes in the future. It is important to identify where you went wrong, what strategies did not work, and what you can do differently. This can lead to a more informed and effective approach to solving difficult problems.
