Equilibrium Ladder Question, can get 1st part but not 2nd
  • Thread starter sweetpete28
  • Tags
    Equilibrium
In summary, a symmetrical ladder of mass 20.8kg is leaning against a frictionless wall, with a horizontal wire connecting the bottom of the ladder to the wall. The tension in the wire is calculated to be 33.9N, but it will snap when the tension reaches 197N. To find the distance a man of mass 78.3kg can climb before the wire snaps, you need to take into account the torque due to the man climbing up the ladder. By setting the torque equal to the tension in the wire and solving for x, the distance is found to be 4.22m.
sweetpete28
80
Equilibrium Ladder Question, can get 1st part but not 2nd!
A symmetrical ladder of mass M = 20.8kg leans against a smooth frictionless wall so the top of the ladder is height h = 6.58m above the floor and the bottom of the ladder is distance d = 2.19 m from base of wall. The floor is also frictionless so a horizontal wire connects bottom of ladder to wall so ladder does not slip.With nobody on ladder, here is what I did to get T, magnitude of tension in wire:
ƩF = 0
F wire = F wall
L of ladder = sq. root of 6.58^2 + 2.19^2 = sq. root of 48.0925 = 6.9348m
Angle θ b/t wire and ladder --> tan θ = 6.58 / 2.19; so θ = 71.59°
Center of mass for ladder = 6.9348 / 2 = 3.46743m
mg down = (20.8)(9.81) = 204.048 N
(6.93487 x sin 71.59°)(F wall) - (3.46743 cos 71.59°)(204.048) = 0
F wall = 33.9 N, so F wire = 33.9 N
Now, suppose wire will snap when the magnitude of the tension is T = 197 N. What is x, the distance a man of mass m = 78.3 kg can climb up along ladder before the wire snaps?
mg down = (78.3 + 20.8) x 9.81 = 972.171
(6.93487 times sin 71.59)(197) = (x cos 71.59)(972.171)
and I get x = 4.22m but this is wrong...
What am I doing wrong here? I know I did first part right (without man on ladder) but what I am doing wrong for this part??
For the second part, you need to take into account the torque due to the man climbing up the ladder. The torque is equal to the mass of the man multiplied by the distance of the man from the wall (which is x). You can then use this torque to calculate the force of tension in the wire. This will be different from the tension in the wire when there is nobody on the ladder. The equation for torque is: Torque = F x dSo, you can rearrange this equation to get: F = Torque / dThen, you can substitute in the values for Torque (the mass of the man multiplied by x) and d (which is x) to get the tension in the wire. Once you have the tension in the wire, you can set it equal to 197N and solve for x.
Related to Equilibrium Ladder Question, can get 1st part but not 2nd
1. What is an equilibrium ladder question?
An equilibrium ladder question is a type of physics problem that involves a ladder leaning against a wall and finding the point at which it will start to slip. It requires determining the equilibrium of forces acting on the ladder.
2. How do you solve the first part of an equilibrium ladder question?
The first part of an equilibrium ladder question involves finding the point at which the ladder will start to slip by setting up and solving equations for the forces acting on the ladder, including gravity, normal force, and friction.
3. Why is the second part of an equilibrium ladder question more difficult to solve?
The second part of an equilibrium ladder question involves finding the maximum weight that the ladder can hold without slipping, which requires finding the coefficient of friction between the ladder and the wall. This is more difficult because it depends on various factors such as the surface material of the wall and the ladder.
4. What are the key factors that affect the stability of a ladder in an equilibrium ladder question?
The key factors that affect the stability of a ladder in an equilibrium ladder question include the angle at which the ladder is leaning against the wall, the weight of the ladder itself, the weight of the person on the ladder, and the coefficient of friction between the ladder and the wall.
5. How can you improve your problem-solving skills for equilibrium ladder questions?
To improve your problem-solving skills for equilibrium ladder questions, it is important to have a strong understanding of Newton's laws of motion, as well as the concepts of forces, equilibrium, and friction. Practicing with different types of equilibrium ladder questions and seeking help from a teacher or tutor can also be helpful.
14K
14K
