Alcubierre
- 80
Hello,
I was unsure if I should post this or on the General Physics thread but since it's about Einstein's gravity, I'll post it here.
All right, so the problem is as follows (from Surely You're Joking, Mr. Feynman!):
I understand the question being asked. My question is, how you would go about to calculate it?
You blast off in a rocket which has a clock on board, and there's a clock on the ground. The idea is that you have to be back when the clock on the ground says one hour has passed. Now you want it so that when you come back, your clock is as far ahead as possible. According to Einstein, if you go very high, your clock will go faster, because the higher something is in a gravitational field, the faster its clock goes. But if you try to go too high, since you've only got an hour, you have to go so fast to get there that the speed slows your clock down. So you can't go too high. The question is, exactly what program of speed and height should you make so that you get the maximum time on your clock?
